TN GUY'S how is your A/C
Old Jun 20, 2006 | 03:47 PM
SoFla350z's Avatar
SoFla350z
its not all aluminum, theres about 16" or so thats rubber, that runs right by the downpipe
Old Jun 20, 2006 | 03:56 PM
sentry65's Avatar
sentry65
the burninator
so what are people wrapping? The aluminum section I'm assuming or all of it? Does that help with cold AC or just to protect the line from burning a hole in it?
Old Jun 20, 2006 | 04:15 PM
SoFla350z's Avatar
SoFla350z
The rubber section of the line, the aluminum is not going to melt
Old Jun 20, 2006 | 04:51 PM
G3.5T's Avatar
G3.5T
Mines working great thus far. Nice and cold
Old Jun 20, 2006 | 05:28 PM
g35pm's Avatar
g35pm
Had to get mine fixed. Both took a dump while doing dyno runs. Got a new bottom one through t'netics warranty, the top was an install error.
Don't use that exhaust wrap to cover the rubber part of the line. It is designed just to keep heat in exhaust pipes, not shield hoses from heat. I used this foil-like, ribbed insulation that I picked up from a Dave Turner's Motorsport (race shop) in SD. I double wrapped it. Has been working fine for a few months. Even lasted through 100 degree temps driving to/from vegas recently.
Old Jun 20, 2006 | 06:07 PM
SoFla350z's Avatar
SoFla350z
On the top hose i used 1 layer of the included self adhesive foil backed insulation, and two layers of thermotec , im not so sure that the exhaust wrap knows whether its holding heat in or out of something.
Old Jun 20, 2006 | 06:09 PM
MIAPLAYA's Avatar
MIAPLAYA
It does....although what do I know...mine has never had an issue.
Old Jun 26, 2006 | 09:29 AM
Peking's Avatar
Peking
Well before the wrapped line that is next to the exhaust side of the turbo (that was originally wrapped crappy went), then the line that is below/next to the intake side of the turbo went bad.
Got both replaced and the wrapped line, wrapped better (a couple of weeks ago at CPRace)...
But nope, trip to MD over the weekend... Then smoke, and some coolent spraying.
From what we can tell, got so hot with the long trip and some driving into boost that either one happened after the other or happened at the same time.
A/C line blew causing the smoke with all the hot exhaust pipes, then with the pressure causing that coolent hose to give spraying some into the bay.
I say this because A/C worked before, and after not anymore lol. And that all the hoses, lines, etc... All seem fine.
So going to Sharif@ForgedPerformance this week, and get the A/C line or lines replaced AGAIN.
Then one weekend take off all the pipes, heat wrapping them, and then buying that turbo blanket.
So all in all, the long *** drive with going into boost... Alot of heat with the A/C wrapped line laying up against the exhaust side pipe were the cause.
And hopefully I will avoid this in the future
Old Jun 26, 2006 | 09:34 AM
Miraclekidjr's Avatar
Miraclekidjr
I would give up my A/C just so I could legitimately post in this thread
Old Jun 26, 2006 | 11:13 AM
Gumpdriver's Avatar
Gumpdriver
NO problems here.
Old Jun 26, 2006 | 12:01 PM
disturbed2483's Avatar
disturbed2483
a/c what a/c it stopped working after my install and just been to lazy to fix but will do soon its getting to hot. :/
Obadabot
Jun 18, 2023 11:31 PM
Alexreyes
Sep 30, 2015 11:30 PM
