TN Installed - I could fry an egg on my hood
Old Sep 20, 2008 | 05:50 PM
  #41
Nexx's Avatar
Nexx
Originally Posted by ChrisCJ99
So quick question guys.... I know it's going to get hot under the hood REGARDLESS, but is it really bad or UNHEALTHY for anything if I don't run my TN kit with any kind of heat shield?
holy ancient thread batman!!! how the hell did you dig this one up?
Old Sep 20, 2008 | 05:58 PM
  #42
ChrisCJ99's Avatar
ChrisCJ99
Just did a search on "heatshield" So any advice?
Old Sep 21, 2008 | 07:23 PM
  #43
SpoilsofWar's Avatar
SpoilsofWar
I didn't use the included heatshield for about 500 miles or so when I first put my kit. Its not really going to "hurt" anything. But, your IATs will be hotter then they would be if you used it since the charge pipe passes so close to the turbine section.
I put a PTP turbo blanket on, I would recommened it.
Old Sep 21, 2008 | 07:29 PM
  #44
ChrisCJ99's Avatar
ChrisCJ99
But that will only effect performance a bit, right? Just curious if too hot of an air intake will be bad for the engine
Old Sep 21, 2008 | 08:22 PM
  #45
SpoilsofWar
What are you trying to accomplish by not using any sort of heat shield or turbo blanket?
Its not going to hurt your engine. I would be more worried about things contacting the turbo and melting (vacuum lines, wiring, etc). But if you have all your stuff routed safely clear of the turbine section, you will be fine. Especially if you just street drive your car and aren't in boost 95% of the time.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
