JE Pistons gone bad...
Old Jul 4, 2006 | 07:49 PM
  #81
Julian@MRC's Avatar
Julian@MRC
Originally Posted by Spanners
Bashing equipment.. indeed.. I seem to recall it all stemming from an uneducated comment based on Eagle rods made by yourself, and hp claims on a machine with very obvious flaws, 'fudge factors' employed and alot of "tugging of the ol' saus' "
In my professional opinion, I wouldn't run a Dynamics machine if it was gifted to us.
The setup we take possession of in the next few months 2nd hand is US$120k and have been using that same machine now for 3+ years.
Same hp every pull, every gear.. dead head can see hazard light current draw as the lights flash on and off.
No variables for wheel spin, rack down, weight.
I've been building and tuning performance engines in my own business for 6years.
Motors built for customers all over the country and world.
Typically 10-20 Turbo Nissans in my workshop at all times, 3-5 fully forged engines built per month and approx 15-25hr week on the dyno.
Never an engine failure nor a tuning failure.
The fact I don't spend 1/2 my life on here and have hundreds of posts a month, means maybe I have something better to do.
Really, talk about patting oneself on the back..What shop might this be with all those Nissan in it at once?
At any rate enjoy your engine builds mate, I wish you the best of luck..
Perhaps with all of your knowledge you can shed some light on the original topic. Why do you think his JE pistons failed at the skirts?
Old Jul 4, 2006 | 08:01 PM
  #82
tig488's Avatar
tig488
Originally Posted by MRC Motorsports
Back on topic, the issue was a failed JE piston that was obviously a design or material flaw. It really sucks to have to rip apart the motor to see that...
so what happens when arias, pauter, crower, etc, has a bad batch that has a material flaw, granted i doubt it will happen, but nothing is 100%. are you gonna refuse to use their parts as well?
Old Jul 4, 2006 | 08:09 PM
  #83
Julian@MRC's Avatar
Julian@MRC
I guess that could happen...And I guess you can use any variable to any scenario to make your point valid...However all I am saying, which by the way has nothing to do with the original topic and my last post,is that we have personal preferences in parts we use,as does every other tuner shop in the world. Some people here act as if they have stock in Eagle products...
Jesus christ, enough already, why am I getting flamed for voicing my opinion? There is no right or wrong here and Im sick of replying to dumb *** comments..
The "WHAT IF" variable can be liberally applied to any situation and is a typical cop out for ones debate.
Well "what if" the 350z can fly? What if my **** was 14" long? What if dogs could talk? You see how silly it sounds..
This whole retort has nothing to do with a JE piston falling apart in ones motor. Every manufacturer has had failures at one point. Some material related, some design related. Im not saying Eagle rods are garbage, what I am saying is for serious HP motors I would opt for something else....Hell what the hell do we know..
Old Jul 4, 2006 | 08:15 PM
  #84
bigbri's Avatar
bigbri
This is driving me crazy...Everyone just get along...he voiced his thoughts which he has the right to do.....I think eagle rods can handle 800whp+ they have been proven and havn't failed yet so until they do who knows... Everyone smoke a blunt its the 4th Come on look at the compression of the pistons guys..the car was probally beat on before it was sold to the new owner it failed on...who knows if the tune was before he bought it or after....there are 2 many vairables to blame JE.....They were all motor high comp pistons made for the z 3 years ago what did you expect...don't blame JE he was probally tracking the car and there was some slight or major detanation..look what happened....
Old Jul 4, 2006 | 08:26 PM
  #85
failsafe306's Avatar
failsafe306
Jesus christ.....
What, now you're bringing religion into this??
Old Jul 4, 2006 | 08:45 PM
  #86
RevLimitZ's Avatar
RevLimitZ
WOW! what a freakin thread. All I'll say is that when I do my motorbuild, I will have Carrillo rods and Arias pistons. My targeted hp is only 450-500 but who knows, I may want more later and I want internals that'll support higher #'s. Doing it once, doing it right.
Old Jul 4, 2006 | 09:22 PM
  #87
Nathan's Avatar
Nathan
Back to the original subject:
I have just had another look at that piston on page 1
There is no cutout in the lower skirt on 1 side to clear the oil squirters like the OE & other aftermarket pistons.
Now I can't measure the piston by the photo but there is very little clearance in this area & maybe the piston has just touched.
Arias made up a batch of pistons for the Z where there was a clearance problem in this area.
Old Jul 5, 2006 | 12:18 AM
  #88
Spanners's Avatar
Spanners
Think you may be onto somethign Nathan..
OWNER: is there any witness mark on the squirter in any way? What cold clearance (if known)?
It looks very similar to the orginal YFZ yamaha pistons from JE which did exactly the same thing.
Lighter, but all load applied to thrust faces of skirt due to no support at pin ends.
Old Jul 5, 2006 | 03:59 AM
  #89
gringott's Avatar
gringott
Interesting piston discussion.
Old Jul 5, 2006 | 05:57 AM
  #90
Julian@MRC's Avatar
Julian@MRC
Interesting..Good point, but was the squirter broken off?I highly doubt the piston skirt would crack before the squirter.Now the skirt could have come in contact with the crank shaft, and cracked as a result.We had one OEM piston due something similar due to a bent rod.The rod bent and shortened the clearance on one end and caused it to whack the crank shaft,which produced a god aweful "tapping" noise..
Old Jul 5, 2006 | 06:46 AM
  #91
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
IIRC, all of his oil squirters were intact. KTaylor is a customer of mine.
Also, I've seen pistons sheer the squirters right off, with barely a nic on the piston. The squirters are very brittle, and snap off with very little force.
Old Jul 5, 2006 | 02:02 PM
  #92
Nathan's Avatar
Nathan
As the photo clearly shows no cut out on the piston, then the piston skirt has been machined shorter to allow for clearance.
Conclusion: Big **** (HP), Short skirt, Large crack.
Those sort of girls will always let you down
Old Jul 5, 2006 | 02:06 PM
  #93
Sharif@Forged
Forged Performance
LOL..very true.
When the pistons are machined, the skirt isnt cut shorter, it's just tapered another 30-40 thou in order to clear the squirter. I can't tell in that picture.
seagrasser
Oct 11, 2015 03:27 PM
B Esquire
Sep 24, 2015 07:52 AM
hardkicks
Sep 20, 2015 12:28 PM
