shop got the heads off....head lift ?
Old Jun 21, 2006 | 03:41 PM
booger's Avatar
booger
Default shop got the heads off....head lift ?
Shop got the motor out and heads off today . I went up to look to see where the heads were leaking at . All three Cyl. on the drivers side broke the head gasket seal on the intake manifold side . Not in between the Cyl.'s
The drivers side also looked to be running slightly leaner than the passengers side. Does the Utec or the AEM EMU's control individual cyl. injector pulses ?
Old Jun 21, 2006 | 03:45 PM
phunk's Avatar
phunk
CJ Motorsports
AEM does individual cyl tuning IIRC, but your better off fixing the imbalance then you trying to tune around it!
was your longblock all stock when this happened?
Old Jun 21, 2006 | 03:50 PM
booger's Avatar
booger
No..SGP Short block , 8.5 CP's ,Pauter , ARP's stock trq. . Running 13 to 14 psi with the Vortech . I had the o2 bung on the passenger side . We are going to move it to the X pipe , or the drivers side if it will not reach the X .
Forgot to add , 550's and return fuel
Old Jun 21, 2006 | 04:27 PM
Weqster's Avatar
Weqster
id double check and make sure all surfaces are true. Possibly sunk sleeve? What were the symptoms that made you pull the heads in the first place?
Old Jun 21, 2006 | 04:30 PM
booger's Avatar
booger
Water pushing out of the motor and filling the overflow tank when boosting . They are going to check the sufaces of the block and heads
Old Jun 21, 2006 | 04:49 PM
Weqster's Avatar
Weqster
if all checks out, id recommend getting the heads o-ringed while they are off. ALso id prolly torque the ARPs up another 10ft-lbs and get a retune with more conservitive timing maps.
Goodluck man.
Old Jun 21, 2006 | 05:07 PM
booger's Avatar
booger
Arp L19 head studs trq.ed to 90ftlb's , and Cametic [ Cowsworth ] head gaskets
Old Jun 21, 2006 | 07:09 PM
meatbag's Avatar
meatbag
Thats what you had, or what you are getting?
Old Jun 22, 2006 | 04:26 AM
booger's Avatar
booger
WHats going in now . May change to the HKS head gasket
Old Jun 22, 2006 | 05:50 AM
meatbag's Avatar
meatbag
Ive been looking at switching my HG to the HKS one since its coming out anyways for some other stuff.
Old Jun 22, 2006 | 06:49 AM
MIAPLAYA's Avatar
MIAPLAYA
If you would please take some pics of the HKS headgasket when you get it. According to their site it has o rings built in. I hope thats true and if it is it might be the headgasket to get from now on..
Old Jun 22, 2006 | 06:55 AM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I'll be getting my HKS gasket today (into my hot little hands). I'll try to take some pics and post them.
Booger, sorry to hear that. This head lift stuff definitely came to light after you and I (and many of the brethren) built teir motors. I too am putting in the HKS hg and L19 studs.
Old Jun 22, 2006 | 07:02 AM
MIAPLAYA's Avatar
MIAPLAYA
Are you guys also installing Overzealous' lift bolts thing?
Old Jun 22, 2006 | 07:06 AM
booger's Avatar
booger
Charles
By "imbalance" do you mean.... making sure that it's rich enough on the drivers side , which would mean running really rich on the passenger side . Or do you mean evening out the air flow to both sides ? If you meant air flow how do you go about it with the plenum we are stuck with ?
Old Jun 22, 2006 | 07:12 AM
USED's Avatar
USED
Wow, I'd def look at timing also. Was this block sleeved? We've been running 20 psi (w/ less timing) on pump for a while w/ no issues on CP's and crowers on OE head gaskets. The heads are tied down with ARP's @ their trq specs.
What were your timing numbers at?
Old Jun 22, 2006 | 07:32 AM
booger's Avatar
booger
Not a sleeved block . Timing was taken out gradually , 1/2 degree for every 1 psi to 10psi then pulling 6 @ 11psi .... 7 @ 12psi .... 8 @ 13psi . Pulling 8 degree's from 5900rpm's [ 13psi ] when my belt starts to slip and boost wavers from 13 to 13.9psi
Im logging the knock sensor and at one time I did see some big changes in volts from it and pulled a little more timing to what is stated above . After that Ive never seen a change volt after . Remember this is on a SC
Old Jun 22, 2006 | 07:52 AM
USED's Avatar
USED
What are you using for EMS?
Old Jun 22, 2006 | 03:38 PM
booger's Avatar
booger
The Split Second box
Old Jun 22, 2006 | 03:41 PM
booger's Avatar
booger
Mia
there was NO signs of the gasket failing between the Cyl.'s . But yes I am installing them just incase it does help some .
Old Jun 22, 2006 | 03:48 PM
t32gzz's Avatar
t32gzz
I am currently putting in the L19's and Cometic HG's as well. I have heard about the HKS HG, but have not seen one yet. I would love to see pics. How long does it take to get one? Anyone have them in stock?
