direct comparison: HKS vs OEM Headgasket
Old Jun 26, 2006 | 10:57 PM
phunk's Avatar
phunk
CJ Motorsports
Default direct comparison: HKS vs OEM Headgasket
I took a look at my HKS headgaskets today, and put together a mini article including several side by side pictures of the HKS unit and the OEM unit.
Sorry, I do not have a cometic gasket around. If you have any information on how the cometic unit differs from the OEM unit, please feel free to post.
http://www.cj-motorsports.com/headgaskets.htm
Old Jun 27, 2006 | 04:14 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Very nice writeup and pics, Ive read the HKS and Cometic HG's are very similar.... Edit-HA I just read your other reply in the other post. How much better are the HKS over the Cometic?
Old Jun 27, 2006 | 06:04 AM
phunk's Avatar
phunk
CJ Motorsports
i am pretty sure that the HKS gaskets are the only ones available that employ the stopper ring. I have used cometics on the FI Vipers at work and in Hondas and never noticed anything of the sort. I could be wrong, but I am pretty sure they are very alike the stock gasket.
Old Jun 27, 2006 | 06:51 AM
Alberto's Avatar
Alberto
Cranky FI Owner
What do the stopper rings provide over the stock design? As you can tell I dont know much about head gaskets....
Old Jun 27, 2006 | 06:53 AM
MIAPLAYA's Avatar
MIAPLAYA
Better pressure dispersion around the cylinders and better sealing over all...headlift=gone
Old Jun 27, 2006 | 06:54 AM
phunk's Avatar
phunk
CJ Motorsports
exactly. when you uniformly compress the headgasket with a perfectly flat cylinder head, the pressure will be greater around the combustion chamber as the folded over stopper ring adds the thickness of another layer just right around there.
Old Jun 27, 2006 | 06:59 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Thanks for the info guys, I will add the HKS gasket to the new engine over the cometic.
Old Jun 27, 2006 | 07:34 AM
t32gzz's Avatar
t32gzz
Great review Charles. I think HKS needs to reinstate your dealer status. I was under the impression that the Cometics also had a stopper ring and were not just a multi layer gasket. Can anyone confirm?
Old Jun 27, 2006 | 11:18 AM
phunk's Avatar
phunk
CJ Motorsports
I just looked at a set of gaskets that Cometic supplies us with for our twin turbo Vipers, and there is no stopper ring, or any type of ring. They are much like the OEM Nissan gaskets only with a coating applied to the entire surface.
Old Jun 27, 2006 | 11:55 AM
vq35carel's Avatar
vq35carel
Default If anyone is need of these head gaskets contact me.
I can get these head gaskets if you guys would like. pm me for more info.
Old Jun 27, 2006 | 04:56 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Charles,
What an awesome article!
Old Jun 27, 2006 | 05:50 PM
t32gzz's Avatar
t32gzz
Charles, you didn't order an extra set did you? If you have an extra you can get rid of, pm me.
Old Jun 27, 2006 | 08:55 PM
phunk's Avatar
phunk
CJ Motorsports
funny you should ask... i actually did. when i called to check the status on them, they had said to me that they didnt get my order... so i sent in another PO. Then the next day a set shows up, obviously from the first order... but unfortunatly i called and told to forget about the other set.
send me a PM if you are having trouble finding them... there is a wholesaler/retailer that i have been dealing with for 6 years that is great... if they dont have it they are only a short from from HKS and usually get the stuff same or next day. I used them for everything HKS before I was direct, and use them again now that I am no longer direct.
Old Jun 28, 2006 | 05:26 AM
ktown z's Avatar
ktown z
I wonder if they will have the hks gasket with a 100mm bore. Let's pray.
Old Jun 28, 2006 | 05:14 PM
Weqster's Avatar
Weqster
Cometic make a gasket with inbuilt o-rings.
i know its not a VQ, but this is my honda-head with o-rings installed.
350z82
Oct 1, 2015 06:25 PM
