head gasket, with turbonetics
Old Jun 27, 2006 | 11:16 PM
faster than u's Avatar
faster than u
Default head gasket, with turbonetics
ok i know i asked this question befor but im still want to know more, i really dont think it will cost that much money to put the cometic head gasket, but wouldnt it be smart, lower the compression stay on like 9 pounds and not really have to worry about your rods going through your block. I want to know why people just dont do this to be safe.
Old Jun 28, 2006 | 01:56 AM
KDW2002's Avatar
KDW2002
you're right.. It would be a very good idea to put in cometic HG and L19 studs, yes they wont be that expensive.. But the mad install time will run you quite a few bucks!
Old Jun 28, 2006 | 04:00 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Not worth it on stock internals...
Old Jun 28, 2006 | 04:15 AM
VashZ350's Avatar
VashZ350
get yourself a different headgasket... the one from Nissan sucks, mine blew on me with the TN kit installed
btw I'm goin' with HKS headgasket
Old Jun 28, 2006 | 06:20 AM
MIAPLAYA's Avatar
MIAPLAYA
I would go with the HKS headgasket and L19 studs of you are going to pull the heads off.
Old Jun 28, 2006 | 06:32 AM
booger's Avatar
booger
Your one of the few people that has blown a head gasket with the stock gasket that the motor hasnt been apart . Nissan seem to get the head sealed up pretty good.
Old Jun 28, 2006 | 09:27 AM
VashZ350's Avatar
VashZ350
I'm special lol
Old Oct 12, 2006 | 08:38 PM
Mr_pharmD's Avatar
Mr_pharmD
if I have 96mm pistons and I want cosmetic gasket, will I get the 96mm gasket or a 98mm due to the overbored piston?
Old Oct 12, 2006 | 09:32 PM
lemansz20's Avatar
lemansz20
Cometic sux, If I wouldve known what Ive know now I would have gotten an hks headgasket. Evos, IS's, supras, ME all have trouble with failing cometic headgaskets. If I hadnt gotten warranty for mine, I wouldve just got the hks. Dont take your chances, and if you do do it just get the hks.
Old Oct 13, 2006 | 07:56 AM
Enron Exec's Avatar
Enron Exec
Pull 2 more degrees of timming when you reach peak boost and live with 10 less rwhp. Your motor's chance of survival would quadruple.
Just FYI for some of the folks that think the head lift issue is because 75 ft-lb is insufficient and they must have 90+ ft-lbs on the head bolts. There have been stock block, from valve cover to the oil pan, K20's and K24 running 600+ rwhp and 30+ psi. Their open deck blocks are not that much different from ours. Higher boost and power does not necessarily lead to head lift. It is the heat and pressure from too much timming. To prevent headlift you want to reduct the maximum cylinder pressure created and you do that by not tunning to the ragged edge. Sure, if you want an all out race motor and get that last 10-20 rwhp, get the biggest studs and bolt, but if your on a daily driver and want your motor to last... id reccomend you tune it appropriatley.
Old Oct 15, 2006 | 05:15 AM
silver nismo's Avatar
silver nismo
+100, man the problem with the z is the rods the pistons can hold a lil more but we I mean who ever have after market pistons and rods find it not worth to pay labor twice add to that lower comp. means more boosting..... so back to the subject change the internals more worth of thinking of other things to do, and for a perfect job i would say... "pistons, rods, HG, and L19, ARP mai stuff. Now thats what i call a good job not excellent but a good safe 1.
Pleask
Dec 21, 2021 03:17 PM
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
