Help! Steel Braided Oil Lines from Spindle Housing to...Where?
Old Aug 11, 2006 | 01:08 AM
AParshall04's Avatar
AParshall04
Default Help! Steel Braided Oil Lines from Spindle Housing to...Where?
I did not get any instructions with my turbo kit so after looking at everything i wasnt sure about where to connect my steel braided Oil feeds or lines (i'm assuming that's what they are) from my the two spindle housings. I talked to Richey @ technosquare today and he mentioned a part i need that hooks up around the alternator...but i was pretty confused. If there is a part like that i did not get it so I'm hoping i can maybe buy it at a automotive parts store. If you guys can chime in with where to hook it up, what the part looks like, where to put the part, where i can buy it, and any pictures that would be AWESOME.
Also just to clarify, i am not referring to the oil lines that connect the spindle housing to the oil pan.
Thanks,
Alex
P.S. i can get pictures for you guys of the lines if needed.
Old Aug 11, 2006 | 01:15 AM
AParshall04
Here's some ghetto photo shop showing the difference between the hole where i hook up my oil line to the oil pan and the steel braided line im confused about running parallel to the red photoshop paint.
Old Aug 11, 2006 | 02:21 AM
BrokeZ's Avatar
BrokeZ
I think i can come to save the day. I have the full pdf for the PE TT kit. Let me know if you want it, which you probably will.
Old Aug 11, 2006 | 04:33 AM
gringott's Avatar
gringott
In my kit they go to a block next to the oil filter, that is where the oil comes from and returns to the oil pan. I think Cheston has a diff. setup, mine might be because the block is used for a temp sensor. It is generic "manifold" type block that allows the oil lines and sensor. The pdf BrokeZ has may have diff setup then I.
Old Aug 11, 2006 | 09:14 AM
BrokeZ's Avatar
BrokeZ
email sent!
Old Aug 11, 2006 | 02:19 PM
AParshall04
Score!!!!! Thanks brokeZ!
Gringot what you described is EXACTLY what i was thinking i would need. Basically an adaptor that goes where the oil filter goes and then you attach the oil filter to the adaptor?
Old Aug 11, 2006 | 03:37 PM
gringott's Avatar
gringott
Actually, that would work, however, look in the manual that BrokeZ gave you and you will see a photograph of what I have, which is a metal block. I have attached the picture but it is small.
Attached Thumbnails Help! Steel Braided Oil Lines from Spindle Housing to...Where?-oil-block.jpg
Old Aug 11, 2006 | 05:30 PM
AParshall04
Where can i get this magic metal block!
Old Aug 12, 2006 | 02:41 AM
G352NV's Avatar
G352NV
http://cgi.ebay.com/ebaymotors/OIL-F...14819491QQrdZ1
Old Aug 12, 2006 | 05:44 AM
tig488's Avatar
tig488
you could buy that sandwich plate but all you need is an oil feed line split block, or T fitting.
Old Aug 12, 2006 | 06:48 AM
AParshall04
Would most automotive stores carry at least one of the above mentioned items that would work with my car? I really dont have time to wait for shipping.
Old Aug 12, 2006 | 03:02 PM
AParshall04
I realized it would be optimal to actually run these steel braided lines to a small oil cooler - correct? That will be my first choice if i fine one like that at the automotive store i go to. This automotive store should at least have something, i mean shoot, they carry amsoil, redline, and royal purple...heh
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
