Another MRC MasterPiece!
Originally Posted by Enron Exec
Do you think a divorced wastegate would have helped?
if you mean external, yes i think that would help, that way, turbine backpressure wouldnt be in the equation. that project is in development now.
Originally Posted by MIAPLAYA
I'm sure there are. But for 30k miles? Out of box as MRC stated?
Joedirt should chime in... But, last time I remember, he has put in ~25K miles on APS ST so far. If I remember correctly, he upgraded his actuator, tuned his unichip and has water injection. I don't think he touched the fuel delivery system however.
Doesn't sound like an out of box setup to me...
that number can be reached with the out of box setup with nothing more than a tune. That said, the tq on such a tune would very high and hard to run for an extended amount of miles. We have seen that hp number on numerous APS TT setups, considering they run the same fuel and ems, it is very doable
Originally Posted by Sharif@Forged
I hope you dont really believe that, Craig. Most shops are lucky to make an average 10%-12% margin on their parts sales, after CC fees, and free shipping and such. I dont call that a raping.
I know that most distributors aren't the ones making the big bucks. There are some manufacturers out there that jack of the price on some items FAR beyond the cost put into them. I think it's funny how Z owners see a brand name fiberglass lip kit and think $800 is an excellent deal. Also, for instance, a company designs a crappy intake manifold with no R&D involved, polish it, and charge ten times the expense required to produce it. People still rush out to buy this stuff...
Originally Posted by taurran
It was mostly meant in jest. No offense intended, Sharif.
You know what I mean...
Before I got into the Performance auto business, i was in the consumer products manufacturing business. The amount of capital that goes into designing and producing a product is enormous.
For instance, we would sell a product for $.50, that would cost as about $.10 to make. At first glance, we are making a killing selling that product...right? But our bottom line operating profits were some of the lowest in the industry....about 10% operating profit. Sometimes, we forget about all the expense lines on a typical P/L such as overhead, materials cost, plant and equipment allocations, packaging, marketing costs, etc..etc. That stuff adds up quickly. By and large, I think Z owners get quality products, at reasonable prices. Also, mass producing an item brings the costs way down. There are 100's and thousands of Honda's out there, so I am sure a test pipe is far cheaper to product for those vehicles, vs. the a 350Z, which is a much smaller market.
Just some food for thought.
Originally Posted by tig488
by divorced, do you mean divorced inside the downpipe, or external?
Didnt someone run an APS ST w/o an exhaust and still had trouble holding boost? If so then i cant believe back pressure is the culprit. Im beginning to think its the local high pressure comming out of the exhaust turbine and its relatively short distance to the wastegate flap that is inhibiting the actuator to have complete control over the wastegate. Otherwise, id have to say that internal wastegates are just plain no good for high boost. WRXs and STis have had this problem forever. The high HP scoobs all go with external wastegates. The shop that worked on my car mentioned of welding the stock APS internal wastegates shut and doing an external wastegate within 3 minutes of opening the APS boxes and looking at the turbos, this was about 2 years ago. They where also the ones that mentioned "they should have had divorced wastegates," as well.
Actually i ment the inside. When looking at the exhaust turbine side, u can see the "exhaust turbine wheel" and the "wastegate flap". Around that is the flange to where the dowpipe bolts on to. I was wondering if a simple divider between the "exhaust turbine wheel" and the "wastegate flap" would help the wastegate close and hold boost like we want it to.
i did run my car with no exhaust, the boost did hold better, and response was better but it was loud as hell. plus my datalogger wasnt working, but i do feel exhaust backpressure has a tiny part in the issue.
what i think is the biggest problem is the turbine housing in general, i believe its too small. the exhaust outlet is only 2.5 inches and youve got 3.5L flowing into it. i think there is too much exhaust gas flowing into it, causing the pressure to build up inside the housing, once the flapper opens, it has a hard time closing due to the pressure inside the housing. my fabricator is working on an external wastegate setup right now.
you can see it in the following pictures, the smaller picture one has a totally seperate smaller pipe welded in and entering the downpipe downstream, the other pic shows the divorced section. in these pics, its the pipe in the center of the pic.
Actually my shop dropped the exhaust and the boost stabilized. we then replaced the fujistubo exhaust i was running for a jic ti. wanted something quieter so i eventually went with the aps st exhaust. shouldve got that one in the first place. now the turbo spool is waaaay louder than the exhaust.
Peter from aps said on another forum site they are in the process of fabricating an external wastegate setup for the aps st. this should help people out alot especially if you dont want to buy the aps exhaust.
I was looking at the TT kit and they didnt show a divorced wastegate. In their explanation of exhaust back pressure they did use another turbo with divorced wastegates though.
I was running the stock exhaust (yes I know stock=suck!)for a few weeks till my APS ST Exhaust came in, what a difference.....
thats the thing, there is no "FIX" if there was nobody would have the problem. just so happens everybody else does. how many aps singles have MRC installed and what % are holding boost?
Originally Posted by beastie
Hey Mia,
Imagine if you were a customer of this guy and had a problem with anything.... With all the double talk and lies... Damm glad I have my car at Forged!
