Another MRC MasterPiece!
Old Aug 26, 2006 | 09:09 AM
JasiJ's Avatar
JasiJ
Default Another MRC MasterPiece!
Hi everyone......Well I got my baby back from MRC on Thursday night after having the APS ST installed. What can I say, Julian and the guys over at MRC have beat my expectations and then some. The car is so smooth at idle and running. The power just keeps comming! The car's drivability has improved on all levels. I have a few pic's BUT no dyno yet. We are waiting for the APS ST Exhaust to come in befor the final tweaking and Dyno. Right now the car is at 7PSI and (just a guess) about 350ISH to the wheels. Hopefully the exhaust will be here in the next 2 weeks and I can get some final numbers......
Old Aug 26, 2006 | 09:19 AM
Julian@MRC's Avatar
Julian@MRC
Nice to see another satisfied customer!!
Old Aug 26, 2006 | 09:20 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Nice work guys...congrats on the newfound power.
Old Aug 26, 2006 | 09:29 AM
JasiJ's Avatar
JasiJ
Very Satisfied!! Can't wait for the exhaust now to finish her up!
Old Aug 26, 2006 | 11:12 AM
Oleg's Avatar
Oleg
Congratulations...
Old Aug 26, 2006 | 11:29 AM
vantage350z's Avatar
vantage350z
Nice, Glad everything went smooth...
Old Aug 26, 2006 | 11:31 AM
zz350zz's Avatar
zz350zz
You better get those scratches on your front bumper fixed
Old Aug 26, 2006 | 11:38 AM
JasiJ's Avatar
JasiJ
Don't remind me
Old Aug 26, 2006 | 12:16 PM
Osix350Z's Avatar
Osix350Z
Congrats man, enjoy the BOOST!
Old Aug 27, 2006 | 08:45 AM
tig488's Avatar
tig488
great, enjoy it and be careful with that new power.
and please, if by any chance you can log boost somehow, either on the dyno, or by datalogging, please show what your boost is doing. i wanna see if the folks at MRC can solve the mysterious boost drop, since nobody else on "this" continent can.
Old Aug 27, 2006 | 08:59 AM
JasiJ's Avatar
JasiJ
boost drop??
Old Aug 27, 2006 | 09:15 AM
Julian@MRC's Avatar
Julian@MRC
If your running stock exhaust, that is the reason..The actuator spring needs to be tightened or replaced.
Old Aug 27, 2006 | 09:30 AM
tig488's Avatar
tig488
haha, MRC surely you have seen or heard about my saga with my aps st kit, along with numerous others.
straight thru JIC single 3" exhaust with resonator cut out, Forge Motorsports actuator, Blitz dual solenoid ebc, custom made crossover pipe to eliminate the flex joint, connectors checked and double checked, hell, even ran the car with no exhaust, still get a drop in boost. ive practically rebuilt the entire kit.
ill be waiting on a boost graph.
Old Aug 27, 2006 | 09:42 AM
zman1910's Avatar
zman1910
Tig, I don't know what exactly you did to your car but plenty of others that used the APS exhaust are barely getting boost drop. I even had a fabbed reverse y-pipe to my Greddy and I had about 0.5 psi of boost drop...I'm sure this won't be an issue for this customer
Julian@MRC's Avatar
Julian@MRC
What kind of boost is it making and dropping to?
Old Aug 27, 2006 | 09:57 AM
tig488's Avatar
tig488
its strange because it does it worst on a dyno than on the street. on the street with my ebc set to 9psi and the gain set low it goes up to 9 and tapers down to around 7.5 or 8. with the ebc set to 12psi, it goes to about 11.5 and drops down to around 7.5 or 8. no matter what i do i cant make it hold past 8 on the street.
yesterday on sharifs dyno, and on other dynos, it would peak around 11.8 and by redline it was 6!!
sharif and i talked because he had another aps st that did the same, regardless of what he did. even with no exhaust, just had the turbo and dp, the boost still dropped. i did the same experiment with similar results.
i know some people have better luck, bullitproof has
my exact setup, same exhaust but makes 60 more hp, but he has cams.
im pretty much to the point of dealing with it, i was just curious to see what results you guys had.
Old Aug 27, 2006 | 02:29 PM
Zivman's Avatar
Zivman
Why is the power steering cooler mounted in front of the IC? Are you mounting it there for more flow? The location (per the APS directions) does not have it mounted there.
Old Aug 27, 2006 | 02:31 PM
Zivman's Avatar
Zivman
I would think the boost is dropping more on the dyno because of the load (or lack of load at the upper RPMS) he is putting on the car.
Old Aug 27, 2006 | 02:34 PM
Zivman's Avatar
Zivman
I would not run any exhaust other than the APS single on this setup. out of box, I saw no boost drop on the install I did. that said, Pulling the exhaust factor out the exhaust so I don't know what to say about your situation. I would try a MBC for ***** and giggles and see what happens
Old Aug 27, 2006 | 02:40 PM
tig488's Avatar
tig488
done it, tried a hallman pro and it didnt help. ive got some more tricks up my sleeve im gonna try soon. im just to the point where it feels strong and i dont want to do much more to it. it feels strong on the street, its just a psychological thing.
back to MRCs good thread. dont want to take away from them.
