Vortech plus other mods...
Old Sep 15, 2006 | 04:54 PM
IlirG's Avatar
IlirG
Default Vortech plus other mods...
Hey guys, My car is in the shop right now getting a Vortech installed. Pre installation my mods are Stillen TD exhaust, Test Pipes, Alphawerks headers, 1/2" plenum spacer. Got two questions for y'all since there seems to be a ton of FI knowledge floating around here.
1) With the mods I have listed above is it necessary to replace the stock injectors with larger injectors?
2) Would taking off the test pipes and going back to stock cats be a good decision in terms of better performance out of my Vortech SC? I say no, but just want to make sure...
I appreciate your help
Old Sep 15, 2006 | 05:26 PM
NismoBlck350z's Avatar
NismoBlck350z
keeep the test pipes for better flow throught the exhaust, also upgraded the injectors wouldnt hurt but if the kit safely runs on them no need, unless your looking for more power which u would need bigger injectors
Old Sep 15, 2006 | 05:28 PM
freezeg35's Avatar
freezeg35
Have fun with the rasp. I had the vortech with stillen dual and crawford cats and still had minor rasp at wot at certain rpms.
I would h***ard to guess that you will have quite a bit more than me. I would consider h/f cats over test pipes, but thats just me.
Old Sep 15, 2006 | 05:39 PM
IlirG's Avatar
IlirG
I have had rasp for 5k miles now, my exhaust sounds to nice to let some rasp between 3k-3.5k make me change it. I am more concerned about the performance aspect, not the sound...
Old Sep 15, 2006 | 06:35 PM
booger's Avatar
booger
Rasp with the open exhauat is a given . You have to restrict it to get rid of it completely . As far as injectors and the kit . Vortech made it safe to run on the stockers . You can go to the smaller pulley and have it tuned and be ok .
Old Sep 15, 2006 | 06:45 PM
IlirG's Avatar
IlirG
Thumbs up
Thanks booger
Old Sep 15, 2006 | 07:35 PM
freezeg35's Avatar
freezeg35
I got 1lb. less boost with the cats on, seemed to lose a bit on the bottom end, but made more mid and up top.
Old Sep 15, 2006 | 09:38 PM
RA11325's Avatar
RA11325
Vortech claims 8psi out of the box, I have headers, test pipes and a 3 inch exhaust and my car makes around 7psi at redline on the stock pulley.
Old Sep 15, 2006 | 10:37 PM
Triji's Avatar
Triji
Mods are below.... No rasp, and pulling 9lbs with 3.12 pulley on stock injectors. I love this frickn' kit she starts to pull HARD at 3.4K all the way to redline... I have only tightened my belt 1x after the 1st 500 miles and it is still as tight as a virgin on her wedding day using the NAPA belt (over 4K miles on the kit now)... That is one thing I WOULD STRONGLY SUGGEST..... Get the NAPA belt instead of the belt that comes with the kit... it is that much BETTER...
GL...
Old Sep 16, 2006 | 04:49 AM
booger's Avatar
booger
An open exhaust will also reduce boost in most cases , but increase hp up top
Old Sep 16, 2006 | 05:28 AM
IlirG's Avatar
IlirG
Yup, I bought the Gates belt even before my my SC came in lol!
Old Sep 16, 2006 | 09:58 AM
IlirG's Avatar
IlirG
Its installed, and I love it! Absolutely a blast to drive, wish that boost kicks in a little quicker but man when it does And surprisinlgy rasp has gone down to near nothing????
350Z_Al
Oct 29, 2020 07:44 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
