Just installed HKS DLI... Need help.
Old Sep 22, 2006 | 11:22 PM
XBS's Avatar
XBS
Veteran
Exclamation Just installed HKS DLI... Need help.
So yesterday I installed the HKS DLI along with a new set of NGK LFR6AIX-11 iridium plugs. Since the plugs come pre-gapped and the DLI will amplifie the ignition I did not gap them.
So I change the plugs and install the DLI, pretty easy straight forward install, cant really do it wrong( i think lol). Wire the ground to a current ground already on the ENGINE.
Drive the car everything seems fine, cant tell a diffrence. Probally a waste of money. but it looks cool (LOL) and it probally does help I just cant feel it.
So today rolls around and now my idle is a little jumpy not much and i have a check engine light.
My idle is definetaly not as smooth as before...
Also im running 100octane so its not the fuel....
Any response is appreciated!
Old Sep 23, 2006 | 12:17 AM
rookie's Avatar
rookie
Maybe a defective unit? What was the code? I know they come pre-gapped but did you make measure and see if they were all the same gap? What's you EM?
Old Sep 23, 2006 | 12:19 AM
XBS's Avatar
XBS
Veteran
Going to read the codes on sunday, I did not measure to make sure, im running the Unichip that came with the APS kit tunned by brainstorm(poorly)
Old Sep 23, 2006 | 12:22 AM
rookie's Avatar
rookie
Hopefully the code can lead you in a direction. There should be plenty of Socal DLI users to test out the unit. Let me know if you don't find anyone, I have one installed.
Old Sep 23, 2006 | 12:41 AM
XBS's Avatar
XBS
Veteran
Did you feel an improvement, if your not busy sunday give me a call maybe we can meet up. Ill PM you my number. Thanks for your help.
Old Sep 23, 2006 | 05:04 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I felt an improvement, and my traps went up 1 mph with no other changes in hotter temps...pull the code and report back.
Old Sep 23, 2006 | 09:01 AM
XBS's Avatar
XBS
Veteran
Might have the codes tonight, will keep you guys updated.
Old Sep 24, 2006 | 04:23 PM
XBS's Avatar
XBS
Veteran
Well Check engine light was Off today when i woke up, car runs better now. DLI makes a small diffrence, nothing to say WOW about.
The code was a P0300 - random cylinder misfire
Old Sep 24, 2006 | 05:10 PM
nissansource's Avatar
nissansource
reset ECM
Old Sep 24, 2006 | 07:11 PM
XBS's Avatar
XBS
Veteran
Why would i do that now, the CEL is off now...?
Old Sep 25, 2006 | 06:55 AM
nissansource
fresh relearn
Old Sep 25, 2006 | 02:17 PM
XBS's Avatar
XBS
Veteran
Well if the CEL comes back Ill do that, for now its running good, DLI is making the engine a little smoother, or it could be all in my head. Who knows im to lazy to take it off.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
