Boost Guage Q's
Old Sep 24, 2006 | 03:51 PM
jj350z's Avatar
jj350z
Default Boost Guage Q's
I just installed an Auto-Meter boost gauge for a Vortech SC. It reads aroun d 25 vacuum at idle, and when I punch it I can only get the guage up to 0? Whats goin on?
Old Sep 24, 2006 | 03:53 PM
jj350z's Avatar
jj350z
I didnt really floor it b/c Im breaking in my new tranny, but I gave it a good push.
Old Sep 24, 2006 | 05:08 PM
jdm3fiddyZ's Avatar
jdm3fiddyZ
your prolly still in vacuum if your just partial throttling it. I remember when i had my vortech it wouldnt boost hard until you had it floored, all the way up to 12 psi
Old Sep 24, 2006 | 05:11 PM
Zivman's Avatar
Zivman
SC is Rpm based so all you need to do is rev it out; even in partial throttle. What have you reved it to?
Old Sep 24, 2006 | 07:55 PM
jj350z's Avatar
jj350z
I was at 4,500-5,000 id say. I just put in a brand new tranny so I didnt want to beat on it until i break it in for about 1000 miles.
Old Sep 24, 2006 | 07:56 PM
jj350z's Avatar
jj350z
but I also tried reving it out in (n) and got nothing
Old Sep 24, 2006 | 08:06 PM
jj350z's Avatar
jj350z
will it just fly up to 8psi which I believe im at instantly? In other words hold hold hold boost. Like so fast that you would miss it ina split second? Or does it gradually build up like you could watch it 1,2,3......8psi?
Old Sep 24, 2006 | 09:13 PM
ss350's Avatar
ss350
Under partial throttle the bypass valve will vent the boost no matter what Rpm you are at. You need to put load on the engine while accelerating and you will see the boost increase pretty quickly around 3500 rpms to redline. Its difficult to keep your eyes on the rpms, road, and boost gauge at the same time though.
Old Sep 25, 2006 | 04:47 AM
gringott's Avatar
gringott
If this is the electronic version, not mechanical, to operate properly the Autometer boost gauge must have the red + power hooked to a switched power source that maintains power during engine cranking. If you have it hooked to an accessory power source that breaks during cranking, it cannot do the auto zero calibration. I had that problem when my gauge was installed, switching the power source to one that maintained power during cranking fixed it. Hope this helps.
Old Sep 25, 2006 | 04:54 AM
QuadCam's Avatar
QuadCam
you need to be in gear and driving. The engine needs a load against it to "make boost."
Old Sep 25, 2006 | 05:57 AM
chimmike's Avatar
chimmike
nothing is going on, because you're expecting the s/c to act like a turbo!
Old Sep 25, 2006 | 05:44 PM
jj350z's Avatar
jj350z
the guage was broken bought a new one problem solved
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
