strange noise...sounds like a pigeon.
Old Sep 28, 2006 | 12:50 PM
QuadCam's Avatar
QuadCam
Thanks Ed for the great customer service. I'll do some more research on the "pigeon" and report back.
Old Sep 28, 2006 | 01:52 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
No problem at all Andrew if by any chance I can't help you I'm sure Steve can help you when needed. We both have 350z and are more than willing to help regardless of what car you drive.
Old Sep 29, 2006 | 11:13 PM
accordfreak's Avatar
accordfreak
dude i get the same sound from my g35 and i'm NA! WTF?
Old Sep 30, 2006 | 05:06 AM
QuadCam's Avatar
QuadCam
Interesting!!!
I am starting to think it's not the BlowOffValve. It just doesn't seem like the sound is coming from all the way up front.
Old Sep 30, 2006 | 11:23 AM
MIAPLAYA's Avatar
MIAPLAYA
Interesting!!!
Could it be gear whine? I know some people have had gear whine from the trans in certain gears and the same from the diff if the backlash wasn't set right when new final drives were installed.
Old Sep 30, 2006 | 11:33 AM
QuadCam's Avatar
QuadCam
no. It doesn't sound like gear whine at all.
Old Sep 30, 2006 | 11:36 AM
MIAPLAYA's Avatar
MIAPLAYA
OK this is going to sound retarded but heres something you can do to check if its the bov. Put a piece of hose (garden would work) in the BOV horn. Run it into the car and listen to the end of it. Drive around to reproduce the noise and listen to see if you can hear it in the hose. I used that to check mine.
Old Sep 30, 2006 | 12:06 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
I'm working on a solution for you Andrew and we will discuss this today at Extreme Autofest and as you know you can always call back and talk to us.
Old Sep 30, 2006 | 12:12 PM
QuadCam's Avatar
QuadCam
that's an idea. I'm trying to imagine how that looks.
Old Sep 30, 2006 | 12:14 PM
QuadCam's Avatar
QuadCam
what confunses me is that it only happens when I am only into light boost. Doesn't happen if the manifold pressure is medium to high. Doesn't happen if you are still in vacuum or 0 pressure.
Old Sep 30, 2006 | 12:25 PM
MIAPLAYA's Avatar
MIAPLAYA
I still think its the BOV. Normally when boost comes on it holds the BOV closed with the aid of the preload spring. If the preload spring is not set right or is failing or if the diaphram is bad the BOV will not fully seal causing some air to vent out during light boost. When higher boost pressure is reached the BOV finally seals closed and the noise is gone.
Old Sep 30, 2006 | 12:50 PM
QuadCam's Avatar
QuadCam
it is not leaking out under light boost.
The "pigeon cooing" happens when I let off the throttle at light boost. I don't get the noise under acceleration.
Old Sep 30, 2006 | 02:50 PM
MIAPLAYA's Avatar
MIAPLAYA
OK thats different then mine then. Hmm I'll talk with Ed about it tomorow.
lapham3
Oct 7, 2022 03:15 PM
AbyteZero
Sep 22, 2015 09:17 AM
Bigsyke
Sep 11, 2015 06:19 PM
3rdpower
May 24, 2005 12:51 PM
jozero
Dec 11, 2002 11:31 PM
