Im dying to build my motor...
Old Oct 16, 2006 | 07:40 PM
tig488's Avatar
tig488
Default Im dying to build my motor...
but I dont plan on getting a new kit. since im running the aps single, i dont want to go down to 8.5 CR just to gain only 50-75hp. im curious what some of you guys think a safe CR would be, to maximize hp and not force my turbo out of its eff range, also i dont want to have to upgrade the aps fuel system, maybe injectors but nothing else. i know thats the problem with the stock aps fuel system. id probably ditch the unichip and go with a UTEC as well. i only run 93 octane. if you cant tell, im trying to be a cheap ***.
im thinking 9.5-10.0 CR, UTEC, bigger injectors, and sharif to build and tune, and 500whp is safe and easy. maybe even some meth inj.
any thoughts?
Old Oct 16, 2006 | 07:47 PM
350Zteve's Avatar
350Zteve
No rods?
Old Oct 16, 2006 | 07:48 PM
QuadCam's Avatar
QuadCam
there is nothing wrong with 9:0 CR.
Old Oct 16, 2006 | 07:50 PM
tig488's Avatar
tig488
Originally Posted by 350Zteve
No rods?
of course rods, id get a basic short block buildup, but there isnt much to think about when it comes to rods. my main concern is the CR.
Old Oct 16, 2006 | 07:51 PM
JETPILOT's Avatar
JETPILOT
I agree with /\ and Sharif will tell you the same..... 9.0:1
Hey Quadcam.... Tomorrow is the big day. Tuning Day!!!
JET
Old Oct 16, 2006 | 07:52 PM
z33boi's Avatar
z33boi
i think 9.5 would be perfect but of course thats my opinion and you would need rods also...i think the mods you listed would be just fine and i'm sure the clutch you have now would is fine. i have a set of 9.5 pistons f/s if interested
Old Oct 16, 2006 | 07:55 PM
tig488's Avatar
tig488
z33, if only they were .20 over, my motor has 46000 miles, stock bore is out for me.
Old Oct 16, 2006 | 07:59 PM
z33boi's Avatar
z33boi
well dang that sux..they are stock bore but of course if you ever change your mind just shoot my a PM
Old Oct 16, 2006 | 08:01 PM
zman1910's Avatar
zman1910
I think 9.5 should be fine...I mean it's still less than stock and we've all been running that since the beginning. Thats probably what I'll end up going with eventually
Old Oct 16, 2006 | 08:07 PM
tig488's Avatar
tig488
yeah, what is stock 11.3? thats almost 2 points lower. that should be more than enough with 93 oct and meth. hell 10 might be ok.
Old Oct 16, 2006 | 08:09 PM
baptist's Avatar
baptist
Standard is 10.5 I think.
Old Oct 16, 2006 | 08:19 PM
Mr_pharmD's Avatar
Mr_pharmD
10.2 or 10.3.
U can get wiseco pistons 8.8:1 ratio.
Old Oct 16, 2006 | 08:40 PM
tig488's Avatar
tig488
ah youre right, its 10.3 not 11.3, 10 is probably a bit too high. 9.5 it will be.
Old Oct 16, 2006 | 11:30 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Right on Tig! You always seem to be on the same page as me... I'm also thinking about the build up, but I'm a cheap @$$ as well... Actually exterior mod is getting too expensive.. I can't afford fully built engine.. I want the BARE MINIMUM BUILD UP. SGP's $2750 short block would be it... But then I want Arias piston with eagle rod. My WHP goal would be high 400WHPs. I don't know if I really need the Arias ED pistons either. I'm also leaning towards the UTEC as well.
Old Oct 17, 2006 | 03:43 AM
ImportPartsPro's Avatar
ImportPartsPro
Vendor - Former Vendor
Correct and I would also recommend 9.5:1
Tig488...let me know if I can be of any help with your build
liqalu04
Jan 2, 2022 12:58 PM
350Z_Al
Oct 29, 2020 07:44 PM
