Fuel cell finally :)
Old Nov 2, 2006 | 09:10 PM
meatbag's Avatar
meatbag
Default Fuel cell finally :)
Got a teaser pic of my fuel cell. Ill have more in a couple of days
ATL was awsome to deal with.
Those are the bosch 044 pumps which i believe is on the AAM stage 2 system. Each one flows about 300lph free flow and 200lph at 5 bar, setup should be good for 1300bhp in theory.
Old Nov 3, 2006 | 05:58 AM
THE TECH's Avatar
THE TECH
That center line going into the cell is the return correct?
Old Nov 3, 2006 | 06:30 AM
002-M-P's Avatar
002-M-P
interesting...what kind of hoses are those?
Old Nov 3, 2006 | 09:40 AM
meatbag's Avatar
meatbag
Not sure exactly what the brand name is of the hoses.
The center line is the return line. The pumps are mounted in a surge tank that has 3 trap doors and guiding veins that go across the fuel cell to keep fuel around the pumps.
Old Nov 3, 2006 | 02:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Can anyone explain, or link to, an explanation of what the purpose of a "fuel cell" is? What makes it better than your typical fuel tank?
Everytime I search google I get a lot of web pages talking about the type of "fuel cell" that generates electricity...
Old Nov 3, 2006 | 03:45 PM
phunk's Avatar
phunk
CJ Motorsports
i have used those bladders before in race cars. neat stuff.
whenever i use that style bosch pump, i remove the fitting in the top that it comes with, because banjo fittings do not flow super well. you can put a AN fitting straight into the pump - not that it matters, yo uhave more then enough pump anyway so its fine im sure.
looks good.
Old Nov 3, 2006 | 08:10 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
a fuel cell is basically a lightweight fuel tank, it can be in many different sizes and weighs almost nothing. most of them are sumped in the back so all the fuel goes towards the back bottom and thats where the pick up lines are.
i love my fuel cell, i wouldnt go back to stock setup ever.
nice setup man!!
Old Nov 3, 2006 | 08:43 PM
meatbag's Avatar
meatbag
looks good.
I was trying to figure out what to do about the banjo fitting. some people say toss it and go AN and other says that the flow ratings are done with the banjo fitting and the you need it since it has a 1-way valve in it.
Im going to try it with the banjo connectors first and if there are any problems ill switch it out for AN fittings and see what happens.
Heres what the whole surge tank/collector looks like.
Attached Thumbnails Fuel cell finally :)-untitled.jpg
Old Nov 4, 2006 | 06:04 AM
MoodDude's Avatar
MoodDude
Basicaly the reason you go with a fuel cell are:
- Fuel starvation (this is the main reason)
- Weight
- Safety
Here are some Q and A's on fuel cells:
http://www.fuelsafe.com/faqs.htm
http://www.atlinc.com/US/faqs_racing.html
Old Nov 4, 2006 | 08:26 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Thanks for the constructive help guys. I appreciate it.
Old Nov 4, 2006 | 10:08 AM
sentry65's Avatar
sentry65
the burninator
phunk, how's your intank cell project coming?
Old Nov 4, 2006 | 10:13 AM
kpiskin's Avatar
kpiskin
So it's not a fuel cell in the tradition sense. Basically a performance gas tank that's lighter and safer? I thought one of the reasons the Z tank was so big was to help with overall balance of the car. Doesn't a lightweight fuel tank spoil some of the handling? How much fuel can you put in the car after the conversion?
Old Nov 4, 2006 | 12:54 PM
meatbag's Avatar
meatbag
My fuel cell holds 80L or about 22 gallons. stock tank is 18gallons, or thats all i could ever get in it.
Old Nov 4, 2006 | 01:22 PM
kpiskin's Avatar
kpiskin
Wow, how much weight loss? Any difference in fuel economy?
Old Nov 4, 2006 | 01:25 PM
meatbag's Avatar
meatbag
Im pretty sure fuel economy is going to br crap with my car anyways, ill know the weight difference when the stock tank comes out.
Old Nov 6, 2006 | 06:26 PM
meatbag's Avatar
meatbag
Fuel cell weights 33.6 lbs dry. I'll try to get a weight on the stock tank sooner or later.
Old Nov 6, 2006 | 06:31 PM
phunk's Avatar
phunk
CJ Motorsports
sorry for off topic.
its running around in a viper being tested. the CAD files exist for the Z unit, and the material is in stock to make it... but we have been too busy trying to keep up with the currently available products, and the demand is still too low. We may even wait all the way until spring to release it, just cause. We also are thinking of adding those cheap Siemens 60lb injectors that APS uses in their "extreme" kit to our inventory (since they only RETAIL for 350 a set, and if you crank the fuel pressure like they do, you can call them 800+cc), or maybe putting them in with the twin pump kit or something.... we got Viper products and Rx7 products in final stages of testing and once they are done and on the new website in the making, the twin Z pump project will get final testing on the balance of the venturi siphon then its ready to go.
if someone actually called us and said YES i need it now, rather then in 2 months, we would probably just put it together and adjust the siphon then send it out. the rocket science is done, we just have to cut it out of the billet..... i could probably post a pic of an old prototype, but hmmmm... the bad guys might be looking.
Old Nov 6, 2006 | 07:30 PM
meatbag's Avatar
meatbag
I was waiting for someone to do this but got caught up in making some other changes to the car. Glad to see that its still intended for production as it will be a nice clean setup.
More pics
The empty hole in the top plate is for the fuel level sender which i dont have yet.
Old Nov 6, 2006 | 07:53 PM
symalik's Avatar
symalik
nice, is it all functional now?
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
350z82
Oct 1, 2015 06:25 PM
