PICS of my turbo install!!
Old Apr 20, 2007 | 01:37 PM
  #141
priscilla ls1's Avatar
priscilla ls1
Its funny I get into 5th somtimes and somtimes I don't. I know I need to. And the times I shift to 5th I am only in that gear for like a second. I was thinking of getting what Alberto got and going with the lower gears. That way I can avoid the 5th gear all together. But next time I go out there I am going to shift at a lower RPM that should put me in 5th for a longer time and give me a higher trap.
Old Apr 20, 2007 | 03:34 PM
  #142
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I f you shift @ 7K you shouldnt need to shift to 5th. If you are shifting at 6600 you will end up shifting to 5th right before the traps. IMO I would hold it to 7K on every gear to prevent shifting to 5th. Bottom line is shifting is time lost. Good luck your only going to get better.
Luie
Old Apr 20, 2007 | 04:04 PM
  #143
priscilla ls1
hhmm.. How high does the 4th gear go? 120? So you are saying shift at 7K every gear and avoid 5th. hhmm Maybe I should raise my rev limiter to 7200. That way I have a little room to play.
Old Apr 20, 2007 | 09:39 PM
  #144
350Z_LEE's Avatar
350Z_LEE
Can you post up your dyno sheet?
Old Apr 20, 2007 | 09:47 PM
  #145
priscilla ls1
I beleive my latest one is on page 4.
Old Apr 23, 2007 | 06:23 PM
  #146
priscilla ls1
Thats it I'm getting an LSD, I'll be going back to SGP for that as well as a high boost tune.
Old Apr 24, 2007 | 10:51 AM
  #147
NoahzBurnt's Avatar
NoahzBurnt
it coming along!!! Hope to have her back in June.....no worries....u save a lot of money when u don't go for TT joy rides!!!
Old Nov 19, 2008 | 02:34 PM
  #148
priscilla ls1
Just wanted to post up a quick update. Fixed my boosting issue and maxed out 505hp and 573tq at 15psi boost. Went to the track about a month ago and did 11.76 @ 127mph 1.7 60ft
