TN kit easiest way to pressure test for bl
Old Nov 9, 2006 | 02:25 PM
LODOSS's Avatar
LODOSS
Default TN kit easiest way to pressure test for bl
What is the easiest way to test the TN kit for boos leaks.. i know what i need to do it.. but i need more info in terms of where to test it from. it looks like to test it from the intake pipe or where the filter is at.. i would need to take the bumper off.. which from my undertanding is a pain because you need to take the wheels off and fender wells off etc too. is there another way to do this? it seems that there are not many places to access the intake piping.
also do bike pumps really work? i tried with that my 3000 vr4 and i was not able to pressurize the intake pipe..
something like this work better?
http://www.wagan.com/htmls/autoapp-compressor.html
Old Nov 9, 2006 | 02:32 PM
MIAPLAYA's Avatar
MIAPLAYA
Reason for needing a test?
Old Nov 9, 2006 | 03:00 PM
LODOSS's Avatar
LODOSS
Make sure I don't have a boost leak .. =o
Old Nov 9, 2006 | 03:17 PM
MIAPLAYA's Avatar
MIAPLAYA
Are you making a full 8 PSI? What is your AFR? What is your vacuum at idle?
Old Nov 9, 2006 | 03:37 PM
taurran's Avatar
taurran
Yup. Idle vac a good way. Maybe try spraying carb cleaner around the plenum/pipes/etc while its idling and look for sucking bubbles.
Old Nov 9, 2006 | 03:39 PM
MIAPLAYA's Avatar
MIAPLAYA
Carb Cleaner in small amounts around the plenum in pipes will result in the motor to increase engine speeds slightly if there is a leak there as you are essentially adding fuel...
Old Nov 9, 2006 | 03:41 PM
taurran's Avatar
taurran
Uhh yeah, I meant soapy water, not carb cleaner.
Old Nov 9, 2006 | 03:43 PM
MIAPLAYA's Avatar
MIAPLAYA
LOL either one will work...
Old Nov 10, 2006 | 07:56 PM
LODOSS's Avatar
LODOSS
sigh.. no boost guage.. i had an AVCR i sold along with my other car.. have not decided to get one yet.. i think i am going to wait till next year and then get one of those color screen boost gauge with wideband readings etc. i went with TN so my car looks stock.. which it does -p
Old Nov 10, 2006 | 08:42 PM
rocks's Avatar
rocks
boost gauge before and after intercooler helps you measure pressure drops... what do i know.
Old Nov 16, 2006 | 11:14 AM
LODOSS's Avatar
LODOSS
hm.. i don't think that will work. unless you mean capping it off each section.. if you are losing pressure then its going to be the same pressure on the whole intake system.
Old Nov 16, 2006 | 11:15 AM
MIAPLAYA's Avatar
MIAPLAYA
you might want to invest in a boost gauge then...it would be a good start...
apex locator
Jul 23, 2021 02:27 AM
issyz
Jul 2, 2017 03:04 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
