*** JWT BB530's and BB700's side by side ***
Old Nov 22, 2006 | 07:44 AM
  #101
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by mraturbo
What up Rob?
Yes, The APS are larger for sure than the 530s which are GT25s.
APS stock set-up should easily make more power than the JWT 530 set-up straight out of the box simply based upon airflow.
Happy Holidays.
M
Thats what I thought. Thanks Mike. The BB730s appear to be 2860Rs too so that makes sense. If thats the case and the APS units are 2871Rs for the standard kit it only makes sense the Extreme kit must be even larger...
Old Nov 22, 2006 | 09:31 AM
  #102
1G-350Z's Avatar
1G-350Z
Originally Posted by 350Zzzz
PS: I brought the Z home yesterday evening, what a rush driving home from LI. My utmost appreciation goes to Vinny, Damian, Mike, Rodney & Alex.
Uhhhhhh Ummmmmm Forgeting someone are we???????
Old Nov 22, 2006 | 09:40 AM
  #103
1G-350Z's Avatar
1G-350Z
Originally Posted by MIAPLAYA
i don't know about GT25s...I think the JWT BB530s might be a form of GT25 but if you put the APS regular kit and JWT BB530 next to each other (some already have) the APS units are larger for sure... turbine and compressor.
I would like someone to put a APS regular TT kit turbo side by side with a BB530... The BB530 is essentially a GT25R...
Old Nov 22, 2006 | 10:04 AM
  #104
MIAPLAYA's Avatar
MIAPLAYA
Yeah I kinda figured it was. Sharif mentioned that he had side by side compared them. Anyone have an APS kit and JWT kit in stock?
Old Nov 22, 2006 | 03:13 PM
  #105
350Zzzz's Avatar
350Zzzz
Professional
Okeydoke.....Rob....thanks buddy......still waiting for you to deliver, though
It is truly amazing, just with the stock injectors & 9 psi to generate 430 rwhp without UTECH or METECH. Waiting for the Hydra, larger injectors, return fuel line, 3"-4" and 15/20 psi
And most of the experts preached that it would never happen with our stock injectors, as it's already maxed out at 90% duty cycle. Next, we will find more & more engine failures on 18 month old unsleeved blocks, even with forged internals.
G
_______
Old Nov 22, 2006 | 06:42 PM
  #106
Julian@MRC's Avatar
Julian@MRC
G
_______
G,
Look at the huge success ATI procharger had with their kits using stock injectors If you knew anything about the automotive field, you would know that the method of forcing more fuel pressure through a smaller injector, is a half asssed way of delivering fuel to the motor. It is unstable and unpredictable to say the least.The right way to do it is more fuel pressure and bigger injectors running within the accepted industry 80% duty cycle. I assure you next comment will be "well its good enough for JWT so it MUST be the right way to do it"... Wrong.. JWT does it for 2 reasons.
1) Primarily to pass CARB exemption, by using the smaller injectors reducing the pollutants at idle and part throttle.
2)to undoubtedly cut production costs of their kits, which are by the way the Most expensive on the ,market right now (besides the APS extreme)And lack Injectors,an adequate fuel system and a worthy engine management..
This being said, Ask Vinny if he runs stock injectors with a Rising rate fuel pressure regulator on any of his race cars??I assure you he will look at you as if your crazy.
And as far as the 18 month old unsleeved blocks failing comment, Where in gods green earth do you come up with your information? Just cause one does not have the time or finances to sleeve a block and build a $25,000 motor, does not mean they will not reap the benefits of enjoying a boosted 350Z with a built motor safely for many many years, with a proper tune and sensible level of boost. After all, your mighty JWT kit claims to achieve this very task on a stock motor.
As a matter of fact, can you point to one single built motor failure, in which the sleeve integrity became an issue as of yet? No, you can not..Therefore for you to make such comments openly on a public forum and cause mass hysteria, is at the least, RECKLESS. People might actually think you know what your talking about, and follow your advice.
Making 430 whp with a stock injector is IMHO playing Russian Roulette with your motor. Shoot, I could take a bone stock motor and boost it and run a Kenny Bell booster pump and make 500whp, this does not mean the motor will last and be reliable..
Old Nov 22, 2006 | 06:51 PM
  #107
mraturbo's Avatar
mraturbo
No Problem Rob.
Take care.
M
Old Nov 23, 2006 | 06:08 AM
  #108
Devil Z's Avatar
Devil Z
What up Rob?
Happy Holidays.
M
Thanks alot man, that has cleared up many questions for me.
Old Nov 23, 2006 | 06:21 AM
  #109
Devil Z's Avatar
Devil Z
So does that mean the APS isn't a 25/35 Hybrid? Eh I was told that the 25/35 Hybrid and 2871 are the same thing, and that the APS has the same (or was it similar?) Turbine as the BB530, but with a larger housing so they don't crap out.
Peace
Old Nov 23, 2006 | 08:13 AM
  #110
MIAPLAYA's Avatar
MIAPLAYA
Peace
I'm fairly certain 25/35 was the old Garrett naming convetion. They switched a while back. Theres no way JWT and APS have the same turbine section from what I can see. If the 530s are GT2554Rs they have a 53mm 62 trim turbine. The GT2871R has a 53.6 mm turbine 76 trim..
Old Nov 23, 2006 | 08:36 AM
  #111
Devil Z's Avatar
Devil Z
0.6 mm difference, but quite a bit with the Housing.
Thank you!!!
Old Nov 23, 2006 | 08:39 AM
  #112
MIAPLAYA's Avatar
MIAPLAYA
Thank you!!!
And the trim dude. The trim is quite a change. From a 62 to a 76 trim is a large difference in airflow. Thats like comparing a 40 trim to a 60...
Old Nov 23, 2006 | 09:00 AM
  #113
Devil Z's Avatar
Devil Z
I'm a noob with Turbos so could you explain a little bit what trim means? Thanks.
Old Nov 23, 2006 | 09:05 AM
  #114
MIAPLAYA's Avatar
MIAPLAYA
Well that discussion could take days if we covered everything. Best bet is to pick up a book on turbo design and go through it a few times. Heres some decent info from another forum that should help explain it a little:
Originally Posted by Turbo Trim discussion
Your inducer is a good place to start to determine a turbo's general power potential for moving air since this is were the air is "introduced' to the turbo system. Larger the inducer the larger amount of air can be swallowed. (again, there’s many other factors like blade design, angle of attack, number of blades, etc.). The larger the inducer the more power it takes to spin it up also (lag) because with each rotation its swallowing up more air so the harder the turbine would have to work. The exducer is were the air that has entered the compressor axially from the inducer gets slung out radially by the exducer blades and gets compressed as it enters the snail or scroll of the compressor housing. The larger the exducer the higher the tips speed for a given turbine shaft speed, so the faster and more compressed the air gets slung out. Generally, the smaller the trim number (smaller trim = bigger difference between the inducer and exducer, larger trim number = closer in size between the inducer and exducer) the more effient the turbo will be at higher pressure ratios. The larger the trim the more air the turbo can move, but will not be as effient at higher pressure ratios. It’s always a trade off. This is why it’s really important to be able to read compressor maps and match the turbo to your engine needs and performance goals. Fortunately for many, most of this leg work and math have been done and all you have to do is ask knowledgeable people on the forum to get the answers.
As I stated above, the larger the inducer the more lag or longer spool-up time will be realized. BUT, with a larger exducer (with same size inducer) an interesting thing happens. In certain circumstances your spool-up time can DECREASE. This is due impart to the tip speed of the larger exducer is faster for the same shaft speed as the smaller exducer comp wheel. The higher tip speed flings the air out with more force. This only works in moderation and in the smaller to mid sized framed turbo compressors (t3 – T4 sized). There is diminishing returns in this phenomenon. So don’t expect to place a 3 inch inducer monster turbo on your ride with an 8 inch exducer and expect it to spool like a stocker. This is practiced quit frequently in hybrid or (HiFlo) stock/upgraded turbos. The turbo shop will “up-grade” the comp wheel by adding a larger inducer for overall more flow potential, then up-size the exducer as well to gain back some responsiveness and decrease spool time that the larger inducer took away from. Think of it this way: it takes X amount of exhaust energy (flow and pressure) to spin up your stock turbo in Y time, but your producing X1 exhaust. So you have great spool-up. Then you stick a larger comp wheel on there, it has the same exducer (major) wheel diameter but it has a larger trim and larger inducer for added kick. It now takes X2 energy to spool it up like your stocker did but your only making X1 exhaust flow before your wastegate opens. You now have more power, but at the expense of less responsiveness, otherwise known as turbo lag. Now if you take and replace that “up-graded” comp wheel with another one with the same inducer dia. But have a larger exducer on it lower your trim (but overall still a larger comp wheel physically then the stocker). Now because the tip speed will be greater for the same shaft speed as the first upgrade, you’ll make boost sooner. Its now only taking X1 exhaust energy to spool it. This is how in moderation you can upgrade and have similar responsiveness to a stocker but with more flow. Some of this same responsiveness will be also do to a most likely up-graded exhaust system also. Again, this doesn’t work well with larger framed turbo’s do to mach differentials (blade speed from the base of the shaft to the tip gets a greater and greater differential the larger the turbo gets. Back sweep in the blade design helps a little. Many other factors such as overall mass {more inertia} and aero factors as well). Turbonetics makes exclusive wheels just to take advantage of this. They have a t3 H trim wheel with a 60 trim configuration. They come out with a “Super 60” wheel (its actually a lower trimed number when you do the math, but its basically the same exact wheel {same inducer size} with a larger exducer) to spool like the smaller 50 trim, but flow like the 60 trim. And because it has the same exact blade design and contours, it fits within a 60 trim housing with no mods.
Old Nov 23, 2006 | 09:12 AM
  #115
MIAPLAYA's Avatar
MIAPLAYA
More about trims from Garretts site:
Originally Posted by Garrett
1. Wheel trim topic coverage
Trim is a common term used when talking about or describing turbochargers. For example, you may hear someone say "I have a GT2871R ' 56 Trim ' turbocharger. What is 'Trim?' Trim is a term to express the relationship between the inducer* and exducer* of both turbine and compressor wheels. More accurately, it is an area ratio.
* The inducer diameter is defined as the diameter where the air enters the wheel, whereas the exducer diameter is defined as the diameter where the air exits the wheel.
Based on aerodynamics and air entry paths, the inducer for a compressor wheel is the smaller diameter. For turbine wheels, the inducer it is the larger diameter (see Figure 1.)
inducer and exducer diameter of compressor and turbine wheels
Figure 1. Illustration of the inducer and exducer diameter of compressor and turbine wheels
Back To Top
Example #1: GT2871R turbocharger (Garrett part number 743347-2) has a compressor wheel with the below dimensions. What is the trim of the compressor wheel?
Inducer diameter = 53.1mm
Exducer diameter = 71.0mm
Example #2: GT2871R turbocharger (part # 743347-1) has a compressor wheel with an exducer diameter of 71.0mm and a trim of 48. What is the inducer diameter of the compressor wheel?
Trim = 48
The trim of a wheel, whether compressor or turbine, affects performance by shifting the airflow capacity. All other factors held constant, a higher trim wheel will flow more than a smaller trim wheel.
However, it is important to note that very often all other factors are not held constant. So just because a wheel is a larger trim does not necessarily mean that it will flow more.
  #116
westpak's Avatar
westpak
SFZCC
Originally Posted by MRC Motorsports
G,
Well the ATI procharger was more due to lack of timing retardation no so much due to fuel that was blowing up engines, the Vortech SC also uses stock injectors but uses the SS box to retard timing and they seem to be OK.
And to compare it to what a race team would use is just reaching and not a reasonable comparison.
Old Nov 24, 2006 | 09:17 AM
  #117
Julian@MRC's Avatar
Julian@MRC
So your saying that forcing the stock injectors of about 270cc's to flow more fuel to support 400+whp by increasing fuel pressure is a RELIABLE and safe method of adding fuel?
Old Nov 24, 2006 | 11:01 AM
  #118
westpak's Avatar
westpak
SFZCC
What I am saying is that your are using bad examples to support your argument, they really do not apply.
Is it safer to run with bigger injectors? of course it is but does that mean the current setup is not safe? my only points of reference are that the couple we have done are running fine.
Old Nov 24, 2006 | 12:34 PM
  #119
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Running high fuel pressure for brief periods of time (typical street driving) will probably do no harm. There are countless JWT and Vortech cars doing this, and I havent seen any failures attributed to a malfunctioning injector.
However, extended periods of high fuel pressure can overheat and potentially cause your injectors to stick. The solenoid is designed to pulse with a certain pressure behind it. That said, I think injector manufacturers are being overly cautious, in certifying their injectors to operate at or below 50psi of fuel pressure.
At low boost (6-8psi), I dont see an issue with the JWT fuel system, when used as it was intended. But at higher boost, I would definately be looking at a return fuel system, larger injectors, and a different tuning platform.
Old Nov 24, 2006 | 12:36 PM
  #120
Julian@MRC's Avatar
Julian@MRC
So what happened to your old opinion that cars running over 400whp need a complete return fuel system?? I Personally dont trust this method at all. I know what people do when they get a TT kit installed in their car, and the abuse most people subject their cars to.Such as extended highway driving at 120-140 mph. Therefore I would never trust a car making 350+whp with a stock injector, perfoming way past its intended design.All you need is one little hiccup or drop in fuel pressure at that power levels and BOOM. You know the first thing that the person will do is blame the shop that installed the kit, when the car blows up.
