*** JWT BB530's and BB700's side by side ***
Old Nov 16, 2006 | 05:35 AM
  #41
chimmike's Avatar
chimmike
the BB700 looks like a GT28RS turbo....while the 530s look like a GT28R.
Old Nov 16, 2006 | 05:39 AM
  #42
zul8r's Avatar
zul8r
I put down 436 uncorrected on the mustang dyno on 1 pull with the 550 turbos and 3" exhaust w/ TP's untuned...I'm lovin those 700's though
Old Nov 16, 2006 | 06:50 AM
  #43
350Zzzz's Avatar
350Zzzz
Professional
Originally Posted by Sharif@Forged
You beat me to it, MIA. This turbocharger flows a tad less than the APS TT standard turbo kit.
In regards to a previous post, saying that an engine is running 40psi of boost pressure means nothing to me, without knowing the mass airflow generated by this turbo, or at least the size/type of turbocharger installed. 20psi of boost pressure out of one tiny turbo is going to flow a fraction of the air, generated by a larger frame turbocharger at the same 20psi pressure.
You can push a turbocharger further than its theoretically peak efficiency range, but you generate more heat, and diminishing returns in terms of mass airflow. Mass air is the only factor we should be looking at when judging turbos...not shear pressure. My technicians WRX makes 5psi at 1/8th throttle in a the parking lot, but its generatating virtually no airflow...LOL.
PM, it is my understanding, that the PE Drag car that you guys built ran in the 10's. Then you guys switched to a different turbocharger setup and ran 8's. But wasnt the intake manifold, throttle body, and piping upgraded as well? All of the 8 second drag cars I have seen run some pretty wild setups.
It does appear that you guys have gone off on a tangent, or should I say, on your own personal tangents; as I did not state nor imply pushing the JWT BB700 or any turbos over and above the manufacturers specified peak operating parameters.
I would not want to “push a turbocharger further than its theoretically peak efficiency range.”
Why would I want to do that after spending over and above what it would have cost me to buy another Z just to get a powerhouse that I don’t really need (basic need that is), but I feel I need, as it is obviously more a neurotic need – then cut corners with the turbos. If the both of you were right-on with your assumptions then I would have got the 530s instead and pushed it to perform like a 700.
Really, why would I want to do that, let alone suggest it
I would suggest you reread my comments. And, Sharif, you surprise me, of all people to even think that someone like Vinny Ten, with his experience and knowledge would even consider such a cheap short cut.
Let’s stay on track, shall we!?
G
_____________
Old Nov 16, 2006 | 06:56 AM
  #44
1G-350Z's Avatar
1G-350Z
I agree about not pushing a turbo beyond it's intended range... When you come to that stage you need to step up...
Yea the PE Street car ran 10's... When Vinny came aboard in 6 weeks he got the car in the low 8's... My point originally to Mia is that particular motor is not nearly as radical as some might think... That's it...
Another thing what we have applied to the SS Street car is really not that wild in our book...
Old Nov 16, 2006 | 06:59 AM
  #45
Julian@MRC's Avatar
Julian@MRC
Let us know if they fit with the stock manifold..I know the JWT manifolds are incredibly similar to the APS ones, and APS is now using the same manifolds for both their standard kit and extreme kit, so it must fit with the larger turbos, somehow..
Old Nov 16, 2006 | 07:05 AM
  #46
MIAPLAYA's Avatar
MIAPLAYA
G
_____________
I don't think there was much to misread. I stated the turbos were good to ~720 HP efficiently based on the compressor maps. You then told me that I must be way off assuming the mass flow rate draws a direct correlation to WHP because Performance Motorsports made some ungodly amount of power above that. (at least that is what you insuated) Since you are trying to tell me how turbos work and what these turbos are good for I'm trying to show you that even Garrett who makes this turbo doesn't believe they should be pushed past 360 HP worth of flow each. Sharif is basically backing up my point and for you to spin it off as him suggessting a shop is taking shortcuts is pretty low. He's basically confirming what ANYONE who works with turbos would tell you based on the compressor maps and a street motor. Perhaps you should re-analyze your own posts.
Old Nov 16, 2006 | 07:19 AM
  #47
Julian@MRC's Avatar
Julian@MRC
+1, APS claims their standard kit to be good for 800chp. Several members have proven that theory bust...Actually the way they rate them is "airflow", meaning that they theoredically should flow enough airflow to produce 350chp each, on an efficient motor. Some may get more HP out of them, some less.Depends on many factors.
The PE turbos PM were using before Vinny came along and showed Andy and Garry how to actually do things the right way, were rigged so that the wastegates were shut. That car went 10.3 but was light as fukc, had traction,and had some insane water to air intercooler set up. I think they only were making 600hp when they ran that 10.3. They later upgrade to twin TURBONETICS T-60's and a Turbo 400 tranny, which is what made that car a real contender..
Here is a general rule I go by..Look at the HP a manufacturer claims, and cut it by 10-15% and thats what youll most likely get..
So IMHO the new APS exteme claims 1000hp, subtract 150hp, and thats 850chp, puts you about 700whp, thats right on point..
Old Nov 16, 2006 | 07:25 AM
  #48
MIAPLAYA's Avatar
MIAPLAYA
And FYI this
Originally Posted by 350zzzzzzz
The CFM output of the turbos is absolutely not a direct correlation to the HP that will be produced by the motor.
I will leave it to the PM team to comment on the numbers that Vinny generated on his stage-1 VQ35DE with 30 psi of boost; and FYI, it was no where close to 700 whp, 720 hp or even 714 hp.
Is what I am arguing. When you decide to fly in the face of years of accepted and proven data you should expect that people who have been at this for a while are going to say something. Sharif, I, and Julian aren't new to turbos. Oh and neither is Garrett who happens to agree with us.
Old Nov 16, 2006 | 07:28 AM
  #49
1G-350Z's Avatar
1G-350Z
Julian
I wish, they fit the stockers, We had to get new manifolds, they actually come out a touch farther... And right now I think they are made to order, we had to wait a long time for them.
Old Nov 16, 2006 | 07:33 AM
  #50
1G-350Z's Avatar
1G-350Z
+1 +1 +1
Bottom line Let the Dyno represent the truth... Better yet the track!
Old Nov 16, 2006 | 07:39 AM
  #51
1G-350Z's Avatar
1G-350Z
This thread is simply to show the differences of the two turbos that are available through JWT.... I would really like to keep this thread focus on that... As far as what kind of numbers we are expecting out of the BB700's. Time will tell, That's it...
Old Nov 16, 2006 | 07:57 AM
  #52
MIAPLAYA's Avatar
MIAPLAYA
Understandable. And I will happily leave this thread to its original intention. But if someone is going to post info that is baltantly incorrect someone needs to correct it. Otherwise people are swayed into believing things and spending money to not get the results they have been told about.
Old Nov 16, 2006 | 08:10 AM
  #53
350Zzzz's Avatar
350Zzzz
Professional
And FYI this
If your assumption that the BB700(s) are in fact the GT2860R; and considering Garrett's approximations of 250hp/1 L – 360hp/3 L peak then maybe I should suggest to Vinny that we might want to consider Julian’s recommendations of the APS exteme with an average mean of 700rwhp.
G
_____________
Old Nov 16, 2006 | 08:25 AM
  #54
MIAPLAYA's Avatar
MIAPLAYA
G
_____________
Um my "assumptions" of what the BB700 is are not assumptions. How much actual data do I need to provide you. Is the excerpt from the Garrett catalog not enough? Every asepct of the turbocharger is idetnical. Compressor major diameter, trim, A/R, turing diameter, trim, A/R and even the comrpessor map are IDENTICAL. What more do you need on this? and Garrett is not saying 250Hp for a 1L and 360HP for a 3L. They are making a recommedation. That is this turbo should be used for motors of 1.8-3L of dispalcement and can produce between 250-360 HP of air efficiently. Split the displacement in half for the Z and you get 1.75L spinning the turbine side of this unit. This falls in Garretts recommended range. The airflow theres not much more to discuss on. Garrett and everyone who has been reading compressor maps for a while can tell you that 36 lb/min of flow is the max flow on the efficiency island. Since Garrett does not indicate a maximum flow rate I'm not going to say the compressor cannot flow MORE then that but that is the limit of its flow efficiently. APS has never published EXACTLy what turbo they are using or flow rates for them. And since they are making their own compressor housings (supposedly) we don't even know what the A/R is. So I would take the word of someone more experienced in their air flow claims when it comes to choosing which of their turbos you use.
Old Nov 16, 2006 | 08:35 AM
  #55
Julian@MRC's Avatar
Julian@MRC
G
_____________
Im almost betting 100% that the Extreme kit only produces 700-740WHp similar to the Greddy's with the upgraded turbos..
As for the JWT, I cant really say, but I dont believe any of the HP #'s thate came out of Violent Racing Technology.
Old Nov 16, 2006 | 08:38 AM
  #56
NoahzBurnt's Avatar
NoahzBurnt
FYI when I spoke to Jim on the phone (many many many times) ironically his turbos are named for their designated horsepower and composition and were originally named based on their efficiency with 300Z's (these are the upgrade options for a 90-96 300Z).
According to Jim Wolf himself "the BB stands for Ball Bearing while the number represents the crank horsepower based on a pair" So....
BB530 = ball bearing turbo good for ~530chp on the 300ZX
BB700 = ball bearing turbo good for ~700chp on the 300ZX
So yes, turbos can be run slightly higher to make more power but if I had to trust someone's opinion it would be the man who sells and names these parts
Old Nov 16, 2006 | 08:44 AM
  #57
MIAPLAYA's Avatar
MIAPLAYA
I'm willing to bet this is the turbo APS is using on their extreme kit. Although I can't be sure. It would nice if they would just tell everyone what they are using.
If it is max flow appears to be just over 50 lb/min. So sure 1000 CHP is possible..
Attached Thumbnails *** JWT BB530's and BB700's side by side ***-extremeturbo.jpg
Old Nov 16, 2006 | 08:45 AM
  #58
MIAPLAYA's Avatar
MIAPLAYA
Bingo.. It all makes sense if you look at the data...
Old Nov 16, 2006 | 09:09 AM
  #59
350Zzzz's Avatar
350Zzzz
Professional
In the beginning we had no idea what the hp approximations were derived from; am I to understand, now you are basing your assumptions from that of a 300ZX; interesting.
Might I ask at what compression ratio, valves per cylinder, etc., etc that these approximations were based upon?
G
_____________
Old Nov 16, 2006 | 09:51 AM
  #60
WA2GOOD's Avatar
WA2GOOD
Hahaha. Nice. I love the doubters. Good, you keep believing whatever it is you believe, and we will just keep making the numbers that we do, over and over again, on severall cars, on a few different dyno's. Are you trying to say that JWT, "The Dyno Shop", Stillen, etc. are all involved in some kind of conspiracy to make all their dyno's read consistantly higher numbers repeatedly just for our VRT cars??
PM, Thanks for posting the pics, never thought to do it myself. I am sure you guys will find the JWT BB700 kit to be great, I know we have.
