emange install in process, have question
Old Dec 4, 2006 | 04:47 PM
350Z_LEE's Avatar
350Z_LEE
Default emange install in process, have question
Installing the greddy e manage blue, anyone know what the small black box with wiring coming from it is for? Doesn't say anything about it in the manual. The instructions that came w it are in japanese but I have a copy of the TT install and nowhere in their either. Anyone know what this black box is? thx
Old Dec 4, 2006 | 04:49 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Um, got a pic?
Old Dec 4, 2006 | 05:01 PM
350Z_LEE's Avatar
350Z_LEE
yeah i can pop one real quick hold up
Old Dec 4, 2006 | 05:05 PM
350Z_LEE's Avatar
350Z_LEE
here are a couple pics. It's the black box
Old Dec 4, 2006 | 05:13 PM
phunk's Avatar
phunk
CJ Motorsports
that is the RPM signal adapter.
if you go to greddy.com you can download the instructions for the turbo kit. in the back of the instructions is where the wiring information is, and it covers that device there. IIRC each yellow goes to each coil wire, the black is ground, and the brown is the RPM signal output (which you run to the Emanage RPM input). but definatly double check that.
Old Dec 4, 2006 | 05:18 PM
350Z_LEE's Avatar
350Z_LEE
thanks, appreciate that :]
Old Dec 4, 2006 | 06:33 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Good memory...that is correct. Probably been a while since any of us have wired up one of these bad boys!
Old Dec 4, 2006 | 07:36 PM
supra crazy's Avatar
supra crazy
I had a question to add to that. Is an RPM adapter required whie using emanage ultimate? because im not pickin up rpm with just the signal wire from EU connected
Old Dec 4, 2006 | 08:03 PM
phunk's Avatar
phunk
CJ Motorsports
I am pretty sure that you dont need the RPM adapter for either application if you get the RPM signal somewhere else. Where does the manual for the Apexi SAFC say to get RPM signal in our cars? I am sure whatever pin that says to use will work?
Old Dec 4, 2006 | 08:06 PM
MarkG35's Avatar
MarkG35
you may want to ditch that whole thing altogether
Old Dec 5, 2006 | 09:07 AM
supra crazy
O really?
Thanks
Old Dec 5, 2006 | 09:33 AM
Sharif@Forged
Forged Performance
You dont need the RPM adaptor for the EU. It should pick it up via ignition wire, or via crank angle sensor input. YOu have to select the pickup in parameters.
Old Dec 5, 2006 | 09:35 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I'm using a similar "black box" for my EU to correct the injector pulse width outputs... I think it's called injector adapter #2
without it, the thing runs richer than a beverly hills b1tch
Old Dec 5, 2006 | 12:43 PM
350Z_LEE's Avatar
350Z_LEE
I just want to wire it up and get it going. I have an appointment to get a tune on the 11th. It's all Greek to me. My cousin will be the one wiring it up for me. I am going to upgrade to the UTEC in the near future.
Workshop12
Mar 23, 2020 01:45 PM
