UTEC map switch
Old Dec 15, 2006 | 11:38 AM
clemlover15's Avatar
clemlover15
Default UTEC map switch
I was just wondering how this worked?
This is was I am assuming, the psi I use below are examples...
so you get tuned @ 8psi store the map1, then tune @ 10psi map2, and then @13psi map3.
So after tuning is all done and the 3 maps are stored, do you just chose the map you want then match the boost with a controller?
Sorry if this sounds dumb but I have the UTEC and would like this feature if it works this easily.
Thanks for any info
Also I already have bought a EBC $$$ can it be used this way or is it easier to get XS EBS??
Old Dec 15, 2006 | 01:59 PM
doug's Avatar
doug
you use a map selecter switch.. i believe it has 4 maps
Old Dec 15, 2006 | 02:11 PM
wtf no turbo's Avatar
wtf no turbo
Now with 2.8 you dont even need to mess with BC. The utec will control the boost so you just switch and go. It is nice not to have to run around at 17 psi all the time.
Old Dec 15, 2006 | 05:31 PM
clemlover15
no BC? well how does will you change the boost?
Old Dec 15, 2006 | 05:58 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
until 2.8 version came out, you had it wrong, but now you can control boost through the combo of the utec and the turboxs boost solenoid.
the utec is boost sensitive so it doesnt matter what map you are on, it will change to different load sites for different boost levels. now you can set up map 1 for 93 octane, map 2 for race gas and so forth...
until now!!
now you can do like you said with V 2.8..
Old Dec 15, 2006 | 06:10 PM
clemlover15
until now!!
I have already bought a EBC before MRC figured it out with the $90 XS controler, can just get a tune for different PSI say the range of low mid high, then use the controler to match the boost with the corresponding map when activated?
Old Dec 15, 2006 | 06:53 PM
Julian@MRC's Avatar
Julian@MRC
The tune will never be as accurate that way..
Old Dec 15, 2006 | 07:02 PM
clemlover15
check your PM box, thanks for the info
Old Dec 15, 2006 | 11:31 PM
KempieZ's Avatar
KempieZ
Can anyone tell me where I can find this Utec boost controller for 79$. It's better and cheaper than an apexi BC. Nice! I would like to buy it asap, because my installation is within 2 weeks.
Old Dec 16, 2006 | 02:04 AM
thawk408's Avatar
thawk408
Its $115 shipped.
Old Dec 16, 2006 | 06:24 AM
Julian@MRC's Avatar
Julian@MRC
$129 retail
give me a shout, Ill tell you where to get it.
Old Dec 17, 2006 | 11:22 AM
sandy@forged's Avatar
sandy@forged
Forged Performance
With an EBC set to two different boost levels, it would be just as accurate as using the TXS boost controller. The TXS setup just make it a one switch affair, rather than a two step operation.
Old Dec 17, 2006 | 12:59 PM
captj3's Avatar
captj3
This is true but the txs boost controller is a lot cheaper than a EBC even if you have to buy the map switch.
Old Dec 17, 2006 | 02:01 PM
Julian@MRC's Avatar
Julian@MRC
Which would be more accurate, like I said..Also the UTEC could be set up in closed loop boost control where it gets feedback from the UTEC MAP sensor, to control a target boost. Much more of an accurate, and simple as well as cost effective way of tunning your car.
1 Map sensor, 1 EBC , 1 ECU, all working together like one happy family..Less BS to go wrong.
Old Dec 17, 2006 | 07:26 PM
QuadCam's Avatar
QuadCam
$129 retail
Julian, TXS stated at PRI that thay just dropped the retail price on the solenoid to $89.
Old Dec 18, 2006 | 06:52 AM
clemlover15
So I could still could use my EBC but it would be better to use the XS EBS?
Old Dec 18, 2006 | 06:56 AM
Julian@MRC's Avatar
Julian@MRC
IMHO Yes.
Old Dec 18, 2006 | 02:12 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Yes, since you already have an EBC, just use it. If you were starting from scratch, then the TXS would be a better idea.
Workshop12
Mar 23, 2020 01:45 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
