Merry Xmas from Forged - Built Motor Greddy TT 5AT FCON +
Old Jan 27, 2007 | 08:13 PM
  #101
roncfpz's Avatar
roncfpz
Originally Posted by JuanFunction2ND
add to the list
pedal assembly with 6 spd shifter
drive shaft are the same.(if im not mistaken)
and ur rear pumpkin will be fine. longer gears(keep ur 3.3)
talk to Gurgen he converted to 6spd from an auto. he said it wasnt a cheap conversion. he could give u a ball park figure
Thanks, I appreciate it! Yep, I got the list from Gurgen.
Old Jan 27, 2007 | 08:26 PM
  #102
rcdash's Avatar
rcdash
the tc is supposed to lock at 2900 rpms (the stall rating for the stock tc). i don't understand how it could be "locking" past 4k rpms. Further, in 4th and 5th gear, past some certain speed, there is supposed to be electronic locking (so even if you're cruising below 2900 rpms, the tc will be locked).
Maybe the TC is "slipping"? That would make more sense to me. But the fluid coupling should still be there - unless something is broken inside (fins), I wouldn't think it would be possible for it to cause that dyno chart...
Anyway Andre takes the stock TC apart for the upgrade - be interested to know what he finds...
Old Jan 28, 2007 | 10:47 AM
  #103
roncfpz's Avatar
roncfpz
Locking, slipping....I'm not sure but I described the condition/problem to Andre @ Edge and he said it was the torque converter causing the problem. My guess is that there may be something broken. I may never find out since I'll be doing a swap.
Old Jan 28, 2007 | 11:47 AM
  #104
rookie's Avatar
rookie
Wish you weren't doing the swap, the more high power motor setups on 5ATs the more pressure can be applied for this tranny to get some more support.
You guys will probably understand the stuff pictured here more than I do.
This is what Level 10 sells as an internals upgrade for the RE5R05A. Again I don't know what is what in these pictures.
Just before Christmas I had my transmission taken out and this kit put in. The shop that VRT uses did the work. I got it back and after about 1k miles I took it to the drag strip. Made it thru a day at Cal Speedway and than made a trip to Irwindale Speedway for 1/8 mile racing.
Snapped an axle at Irwindale and had the tranny pulled out and sent in for inspection. The tranny shop said everything was still good. In auto mode the tranny with this kit feels much more solid, before this I would never ever accelerate very fast in auto because I don't trust the downshifts the tranny does during boost which is where I think most of the damage will happen.
I haven't dyno'd since getting this stuff done but we do plan on turning up the boost and seeing what it can hold. I have a second tranny we'll probably be experimenting with. Getitng a pan spacer made is one item, the tranny shop took measurements and is planning on getting a kevlar band made, they also said the seals in this tranny looked like a weak point after the band.
Old Jan 28, 2007 | 06:12 PM
  #105
JuanFunction2ND's Avatar
JuanFunction2ND
Function:Tuned
<--- in the same boat with a 5AT ^ good to know keep us posted.How about drivability issues, is it smooth
Old Jan 28, 2007 | 06:46 PM
  #106
roncfpz's Avatar
roncfpz
Thanks Rookie. After doing extensive research and having conversations with IPT, Level 10, Edge Racing, Alto, Raybestos, HPP, etc. I grew increasely frustrated with the lack of significant development in upgrades that will hold upwards of 600+ whp. Even though I may not hit those levels with a high boost tune I want my tranny to hold that much power for any margin of error. I do plan to continue research and hopefully we all make some head way on advancing the 5AT. I believe HPP Racing right now is doing the most extensive testing and will probably isolate key weaknesses that may lead to advances.
Old Jan 28, 2007 | 07:38 PM
  #107
rookie's Avatar
rookie
From your posts it does seem like you've done a lot of the foot work, which is a loss for us. Dealing with the 5AT is so dam frustrating at times.
Sorry this turned into a 5AT thread, you having Sharif there and having made a lot of contacts it turned out that way. Your Z is beautiful, having beastly power to the ground will make it that much better.
Old Jan 28, 2007 | 07:47 PM
  #108
roncfpz's Avatar
roncfpz
Thank you very much. I'll keep harassing them over at Alto about getting that powerpack available soon. The 5AT is quite complicated.
Old Jan 28, 2007 | 08:04 PM
  #109
acg's Avatar
acg
I am actually looking at picking up Gurgens built tranny with the TC and VB upgraded but it is currently waiting on Alto to come out with the better clutch packs but Gurgen called me and said that this may not happen anytime soon (lack of demand I think) so I am deciding on what I should do, on the other hand I don't think mine was slipping as once it starts to slip then it is not long after that the tranny goes out, mine has been doing this hesistation for about 5 months now.
Not trying to make this into a clutch thread either but for us 5AT guys this is the last hurdle I think.
Old Jan 28, 2007 | 09:07 PM
  #110
Cannysage's Avatar
Cannysage
Originally Posted by roncfpz
Rookie, according to Sharif, there is like a "pause" at around 4500rpms. It's not tranny slipping, but the rpms drop momentarily and then power comes back on and falls. We could not get a good dynojet run at all. When Sharif posts the graph you'll be able to see and I'm sure he could explain better.
I have the same prob. let me know if you find out anything. I thought it was my unichip.
Old Jan 29, 2007 | 10:22 AM
  #111
TENGAI's Avatar
TENGAI
Originally Posted by Audible Mayhem
yeah man, wait a week or two and look at my turbo 400 set up, i will be recessing the shifter down into the stock position with the stock plastic back on top of it, it will look stock, then, well, it will hold anything you will throw at it.
1500 -1700 for tranny with warranty good to 1500 hp/tq, 400 flexplate, 300 adapter, and 1 000 000 for the install (what a *****) hehe jk
definitely a winning combo for still less than an upgraded tranny, plus you could sell your stock auto, plus all the upgrades you have so far and have one of the sickests cars around because you will be able to put that power down and it WILL shift...
i mean, the third gear is just like your 4th gear in your auto, so its not too bad, plus the newer trannies have overdrive, i am looking into stuff right now
+1 on the above... If you're going to stick with an auto tranny on a boosted VQ, this just seems to be the safest and most stout approach. Especially considering that if you can recess the shifter and give it a stock look...
Old Jan 31, 2007 | 03:56 PM
  #112
1G''s Avatar
1G'
Yeah i think this is the way i'm going to go to. 3300 or so and your DONE!!! i hope
Old Jan 31, 2007 | 08:38 PM
  #113
rcdash's Avatar
rcdash
But the MT trannys break too... maybe those are mostly stock ones giving trouble that I read about
Old Jan 31, 2007 | 08:48 PM
  #114
maximumsportZ's Avatar
maximumsportZ
Ron, you did the right thing.
Old Feb 1, 2007 | 05:48 AM
  #115
roncfpz's Avatar
roncfpz
Thanks. Doing a TH400 or TH350 swap is certainly economical and they are very stout trannys but my objective is not to end up with a drag car. That makes sense for some but not in my case for my objectives.
Old Feb 1, 2007 | 05:50 AM
  #116
roncfpz's Avatar
roncfpz
The 009 version with an ATS Triple or Double Carbon clutch should hold my power range of 500-600hp.
Old Feb 1, 2007 | 06:05 AM
  #117
BrianLG35C's Avatar
BrianLG35C
Hey Ron, could you post some pics of your rear? I'd like to see how the EVO TT looks on your Z. Also, how did you like the Tein CS coilovers? I see you switched but I'm only looking for a slight upgrade in handling and lower stance.
TIA
Old Feb 1, 2007 | 06:22 AM
  #118
roncfpz's Avatar
roncfpz
TIA
Hey Brian, I liked the TEIN CS coilovers but they were too soft for any sort of road and track events as well as keeping my front splitter from scraping with dips in the road. The Flex are pretty stiff but I like them for this car since it's not my daily and works with my EFDC. I've heard good stuff about the HKS and KW coilovers. Here's a couple different pics for ya.
BTW, Sharif fixed the off center tips in that last pic......they line up perfect now.
Old Feb 1, 2007 | 06:26 AM
  #119
BrianLG35C's Avatar
BrianLG35C
Just amazing pics! Your Z looks fantastic! Have you heard anything on Greddy coilovers? Who did you use for your Z transportation?
Old Feb 1, 2007 | 06:29 AM
  #120
roncfpz's Avatar
roncfpz
Thanks! I appreciate it. I have not heard anything about the Greddys. I used Gary Almond of Almond Exotic Transports........great guy, great service and great price. www.almondexotictransports.com He does alot of Vipers for Heffner Performance.
