Vortech with Utec
Old Jan 8, 2007 | 06:17 PM
Sisith's Avatar
Sisith
Default Vortech with Utec
Hey guys Im going to install a vortech kit I bought used and have a couple questions about where certain things get hooked up. I was looking through the instructions and it says that I need to hook the FMU up to the SS box. I am not going to be using the SS box and instead am tuning with a Utec. Where do I connect the wires coming off the FMU? Am I supposed to use the included FMU if Im not using the SS box? And if I dont use it, what controls my fuel pressure?
Also, I will be installing the MAP sensor and a boost guage...should I connect them to the same vacuum line that the FMU and SS box used? Trying to get this all straight before I start. Thanks for the help in advance!
Old Jan 8, 2007 | 06:23 PM
booger's Avatar
booger
Im sure the Utec has some sort of switch to turn on a aux fuel pump at a set rpm and or a psi level . The FMU is inline and controls the fuel preasure
Old Jan 8, 2007 | 06:54 PM
Sisith's Avatar
Sisith
Forgot to mention I will be using 440cc injectors. And im not sure the Utec can turn on aux fuel pumps. I have read the instruction manual and it doesnt mention anything like this
Old Jan 8, 2007 | 07:25 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
the FMU is a BOOST dependant fuel regulator, it will work with the utec, it really will have nothing to do with it, as long as it is consistent, it shouldnt be a problem using it.
Old Jan 8, 2007 | 07:43 PM
Sisith's Avatar
Sisith
So where does that red/black wire run to? Do I take it to my batt positive terminal?
Old Jan 8, 2007 | 08:10 PM
Nealoc187's Avatar
Nealoc187
Vortech with Utec, a G-tech and VTEC
Old Jan 8, 2007 | 08:53 PM
Sisith's Avatar
Sisith
thanks for the constructive post! what would we do without your help??
Old Jan 8, 2007 | 09:03 PM
Nealoc187's Avatar
Nealoc187
Not sure.
Old Jan 10, 2007 | 05:41 PM
Sisith's Avatar
Sisith
Hey guys im still trying to figure out where I should connect the red/black wire for the vortech FMU if Im not using the SS box. Or should I forgo using the vortech fuel equipment and instead get a walbro and use the 440 injectors? What would my fuel pressures look like with a walbro and just the larger injectors?
Old Jan 10, 2007 | 07:33 PM
Julian@MRC's Avatar
Julian@MRC
get a walbro 255lph and throw out that pos DFMU.
Old Jan 10, 2007 | 08:06 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
The fmu is utilized with system that use factory stock injectors,since you are installing the 440 cc injectors ,I would not recommend the fmu ,I wood install a walbro 255 fuel pump instead ,the injectors you have with the 255 pump would be enough fuel for your current set up.the is a simple way to do it .
Old Jan 10, 2007 | 08:25 PM
Sisith's Avatar
Sisith
will the fuel pressures be safe using the walbro? Im assuming so since it pumps out more than 2x the fuel
Old Jan 11, 2007 | 07:21 AM
jpc350z's Avatar
jpc350z
I have the walbro and 440's.. Also did not remove the FMU/Aux fuel pump yet.. However my fuel press (idle/normal driving) is 80psi...You will have to make the walbro mod that turbonetics recommends in there install manual to bring the press down to around 52 psi.. The walbro overwhelms the OEM fuel regulator...
Old Jan 11, 2007 | 02:26 PM
DaveFunction2ND's Avatar
DaveFunction2ND
Your fuel pressure will be higher but you can use the UTEC to remove the excess fuel.
Old Jan 11, 2007 | 04:31 PM
Sisith's Avatar
Sisith
I know the Utec in open loop fueling can specify injector pulse widths, but is there any neg side effect to having that high of a fuel pressure with the stock lines? This is a daily driven car and will see some track time.
Old Jan 11, 2007 | 05:33 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
If you are still planning to run stock injectors, then wire up the pump to a switched power source. Make sure its a good 15-20 amp circuit...something with some beef behind it. Run the pump continously, and pull fuel out with the UTEC.
Old Jan 12, 2007 | 04:58 AM
Sisith's Avatar
Sisith
Thanks Sharif, I may be ordering some things from you tonight
350Z_Al
Oct 29, 2020 07:44 PM
NissanZcrazy
Nov 2, 2015 06:03 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
Calinismo350z
Sep 14, 2015 04:04 PM
