Getting Ready To Modify
Old Feb 18, 2007 | 08:39 PM
J0n051's Avatar
J0n051
Default Getting Ready To Modify
Hey everyone on my350z.com well to begin with i have a 2006 350Z, and im a complete newb about cars but im very interested in getting my car to be a very fast daily driver car and also learning about my car, and im interested in the APS Extreme Twin Turbo, and i wanted everyone's input on the Twin Turbo for the Zs, and what i should be getting/learn before i actually buy the Kit for example should i go ahead and first get the stillen exhaust and headers i would like or do i just need the exhaust and not the headers. Sorry if im not clear but if i am thank you everyone who gives me their input and help.
Old Feb 18, 2007 | 08:42 PM
J0n051's Avatar
J0n051
This is my current list of what i was getting
Stillen Exhaust & Headers
MREV2 & 5/16 PLENUM SPACER
ACT Clutch
Nismo R-Type Intake
StopTech 4 Wheel Brake Kit 355mm
B&M Short Shifter
ECU Reflash
Stillen Grounding Wire Kit
Old Feb 18, 2007 | 08:47 PM
Escobar's Avatar
Escobar
sounds like your off to a good start, minus the short throw and grounding kit
Old Feb 18, 2007 | 08:48 PM
Willie's Avatar
Willie
ACT Clutch
Nismo R-Type Intake
B&M Short Shifter
ECU Reflash
No headers, if you are actually getting an aps extreme go with the aps exhauset 2.5" or 3.0" And spend a some time in the FI section to learn your stuff it is rather complex.
Old Feb 18, 2007 | 09:02 PM
Excellent plan.
Old Feb 19, 2007 | 03:50 AM
J0n051's Avatar
J0n051
ACT Clutch
Nismo R-Type Intake
B&M Short Shifter
ECU Reflash
Old Feb 19, 2007 | 04:11 AM
Jay'Z's Avatar
Jay'Z
Stillen Exhaust & Headers EXHAUST YES/ HEADERS NONote: Dont need header if your going turbo later= waste of $$ and labor cost..
MREV2 & 5/16 PLENUM SPACER YES
ACT Clutch YES
Nismo R-Type Intake YES
StopTech 4 Wheel Brake Kit 355mm YES
B&M Short Shifter HELL NO Note: read reviews.. just change shift ****!
ECU Reflash NOT WORTH IT SO NO... Note: with that same cash you could easily buy UTEC!!
Stillen Grounding Wire Kit YES
Ok, My recommendation by each mod...... There ya go.. Hope that helps a newb...
Old Feb 19, 2007 | 04:32 AM
Fluid1's Avatar
Fluid1
I agree with jonb7007, except for the ECU part. I say go for a reflash, they work well and can help you in other areas than just power.
Old Feb 19, 2007 | 04:47 AM
Jay'Z's Avatar
Jay'Z
Well, there ya go OP someone agrees with me.. But Id have to disagree with you Fluid1 on the reflash because that cash could easily buy him a UTEC now since they are so cheap.. UTEC would benefit him at any power level.. just about.. I have had exp with "reflash" and it didnt tickle me at all.......
Old Feb 19, 2007 | 05:20 AM
doug's Avatar
doug
read read read...
look at all the dyno threads in the first couple of pages and look at their mods.. and work with that..
read read read...
Old Feb 19, 2007 | 05:27 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
I agree with the others, don't bother with headers because you will be replacing those with turbo manifolds if you put twins on the car. The APS extreme is a great kit - nothing bad to say there.
Also, I would not bother with the Intake or ECU Reflash if you are going turbo in the future. The intake would be replaced with the turbo intakes, and you will be better off with engine management that allows more adjustability than a reflash.
ACT Clutch
Nismo R-Type Intake
B&M Short Shifter
ECU Reflash
Old Feb 19, 2007 | 06:34 AM
THE TECH's Avatar
THE TECH
Being a noob, maybe some more research is necessary before you jump into the FI arena.
THE TECH's Avatar
THE TECH
Double post, please delete.
Old Feb 19, 2007 | 06:43 AM
stein's Avatar
stein
Don't forget with that many mods the dealership/Nissan will most likely not cover your engine when/if it dies like this guy: https://my350z.com/forum/showpost.ph...2&postcount=60
Being a noob you may just want to research it for a while, let others who have the experience teach us what works and what don't.
Old Feb 19, 2007 | 11:08 AM
J0n051's Avatar
J0n051
i'm sorry please help i dont know how to delete this
Old Feb 19, 2007 | 11:16 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Go to edit button, found on bottom right of your post. Then click inside the "delete" thread box and proceed.
Old Feb 19, 2007 | 12:08 PM
MUZZY's Avatar
MUZZY
dont waste money on the intake if your going to buy a TT
Workshop12
Mar 23, 2020 01:45 PM
2ndchanceZ
Oct 26, 2015 08:03 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
