Low compression motor with No turbo, can it run????
Old Feb 28, 2007 | 05:08 AM
lemansz20's Avatar
lemansz20
Default Low compression motor with No turbo, can it run????
I am thinking of selling my t/n turbo kit b/c I am probs going to get a twin turbo but i am not sure yet. I know the car will be slower, alot slower but will I hurt the car if I run it with no turbo kit with my low compression built motor?????? I remember seeing a thread on this but I couldnt find it, it was a pretty long time ago/????
Old Feb 28, 2007 | 05:11 AM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
It will run, you will loose some power due to the lower compression and no boost. Be careful, a tune is always a good idea or drive a beater until you switch out your setup completely.
Old Feb 28, 2007 | 05:17 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Assuming everything else is in check, the fact that it is low compression is not going to hurt it driving around. Most of the time driving with a turbo is not spent boosting anyways (interstate cruising, etc).
Old Feb 28, 2007 | 05:39 AM
rocks's Avatar
rocks
I have 9.1 with no turbo. Its fine. But i also have cams and stuff. Back in the day people used to drive around in 7.5:1 compression v8s.
Old Feb 28, 2007 | 06:09 AM
TENGAI's Avatar
TENGAI
It'll run. Slower, but it'll still run fine. Recommend a tune to make sure you're not running pig rich and to check timing.
Old Feb 28, 2007 | 08:18 AM
QuadCam's Avatar
QuadCam
you'll probably only be 15-20hp down from stock.
it will be fine.
Old Feb 28, 2007 | 01:20 PM
lemansz20's Avatar
lemansz20
Ok cool, im gonna take most of the tn kit off, probs sell it for 2400 b/c I want it gone, no injectors or reflash but everything else with a bigger intercooler. Thanx guys always good to hear from the more experienced.
Old Feb 28, 2007 | 01:28 PM
priscilla ls1's Avatar
priscilla ls1
It will run for sure, Also how low compresion are we talking about?
Old Feb 28, 2007 | 01:30 PM
Sean's Avatar
Sean
I think you can use lower octane fuel as a bonus side effect.
Old Feb 28, 2007 | 04:08 PM
atlsupdawg#2's Avatar
atlsupdawg#2
For every point you raise compression you gain 3%. For every point you go down it's about a 2% loss. I think you're cool bro. You're looking at about a 6-6.5 HP loss..
You sure can...
Old Feb 28, 2007 | 08:52 PM
widebody350's Avatar
widebody350
2400 bucks and I'll pay shipping and you got a deal.
Old Dec 7, 2019 | 07:36 PM
Willy So's Avatar
Willy So
hey guys i got the same question i just sold my supercharger i had a V3 and my engine is built i have 9.1 compression and a built block can i drive my car normal i also have a haltech pro plug in...
Old Dec 7, 2019 | 08:06 PM
813_350Z's Avatar
813_350Z
Read above
apex locator
Jul 23, 2021 02:27 AM
