P1564 code.
Old Mar 15, 2007 | 10:13 PM
Dubai's Avatar
Dubai
Default P1564 code.
Dropped the car to the dealership to remove the navigation system form the car and guess they f%^&ked up the car. I have P1564 code. did a lil search and found that its the ASCD Steering Switch. what does that mean?
also my vaccum is -10 and fuel pressure is 53-54. what do I have to check?
Old Mar 16, 2007 | 06:33 AM
Dubai's Avatar
Dubai
bump
Old Sep 21, 2007 | 04:09 PM
zxpwr's Avatar
zxpwr
bump
i have the same issue now.. all i know is my cruise control does not work... the obd scanner described the P1564 as "accelerator control"
Old Sep 21, 2007 | 04:54 PM
ZCARBANDIT's Avatar
ZCARBANDIT
its the ASCD Steering Switch.in other words a bad cruise control switch.replace it and reset the ecu ,which u can do w.o the consult.
Old Oct 7, 2007 | 02:42 AM
malized's Avatar
malized
hi guys, i have a problem in the 2003 Z , the cruise control is not working , but when i press the button, the ''cruise'' appear on the gauge , and i try to press down the acceleration button , it will not work ...
p.s from 1 month ago it was working well , but i didn't use it each time !!
can some body help me ???
thx
joe
Old Oct 7, 2007 | 10:36 AM
VIZAGE's Avatar
VIZAGE
So are you throwing this code also? You didn't state. It would help, it would basily tell you the problem at hand. So your saying that CC is working, but the accelaration switch is not?
Old Oct 7, 2007 | 01:02 PM
malized's Avatar
malized
yep exactly ....
hope to give some solution
joe
Old Nov 13, 2007 | 11:35 AM
xav_350z's Avatar
xav_350z
joe just Switch to an STI lool
Old Nov 13, 2007 | 11:38 AM
malized's Avatar
malized
lol
Old Jan 1, 2008 | 10:00 AM
kramykram's Avatar
kramykram
Ok I went to autozone and had the codes pulled, i just replaced my o2 sensor i broke pulling my tranny, but guess i need to leave the battery unhooked longer. now this other code P1564 code ascd i have read is for the cruise control switch going bad, well i put in an aftermarket steering wheel, so i imagine this is the cause of the code, but is there a way to get rid of it is what i need to know? Thanks in advance.
had my own post but no replies. maybe i can get something here
Old Sep 1, 2009 | 12:12 PM
zerosec's Avatar
zerosec
^ this thread is like 1 year old but how do i get rid of this P 1564 CODE ?
i had this problem just after i installed the momo steering wheel.
its the cruise control button, but how do i fix this thing ? :/
Old Dec 30, 2009 | 12:40 PM
midz350's Avatar
midz350
the same thing here I got the P 1564 code and the cruise control and stereo buttons are not working, even there lights, and slip and VDC are on.
Old Dec 31, 2009 | 07:12 AM
midz350's Avatar
midz350
Bump
Old Jan 3, 2010 | 12:32 PM
midz350's Avatar
midz350
C'mon people! I don't want to start a new thread. I just need to know where is the fu**ing harness for the steering switch. I couldn't find it in the service manual!! I think I may disconnect it by accident.
Old Jan 5, 2010 | 04:58 PM
zerosec's Avatar
zerosec
^ bump !
aarrgghh
May 1, 2022 11:04 AM
dutchboy350Z
Feb 15, 2022 11:07 PM
footballmania32
Wheels Tires
Oct 20, 2015 09:08 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
disturbed2483
Aug 5, 2009 05:54 PM
