Oil in intake piping (vortech)
Old Mar 18, 2007 | 07:28 PM
ZZZed's Avatar
ZZZed
Default Oil in intake piping (vortech)
I checked my vortech intake piping and noticed that the inside was coated with oil. Is this normal and where is the oil coming from? I've read that it could be a broken seal in the SC? I've also noticed that my car has been bogging down when i go WOT above 3k RPM. Could this oil be causing my car to bog down? Thanks for any help.
Old Mar 18, 2007 | 07:49 PM
Quamen's Avatar
Quamen
Possibly your PCV if you are not running a catch can of some sort.
Old Mar 19, 2007 | 02:02 AM
booger's Avatar
booger
if you got oil in the IC pipes . I would think it almost has to be coming from the SC . I had it happen to me also . I found it when I was playing around with my BOV . I just happen to put my finger in the pipe when the BOV was off . You'll more than likely have it in your plenum also .. You'll need to clean both out .
Old Mar 19, 2007 | 06:16 AM
THE TECH's Avatar
THE TECH
How many miles on the SC? I'd doubt it was the SC though. More likely what Quamen said about the PCV or the intake tube on the air filter.
Old Mar 19, 2007 | 06:21 AM
SungNamZ's Avatar
SungNamZ
+1
Old Mar 19, 2007 | 12:41 PM
booger's Avatar
booger
I forgot about the crank case breather hose being hooked up to the intake filter . I just let the hose hang and vent .
As far as miles on the blower...Mine had very few miles on it when the seal in the blower went bad
Old Mar 19, 2007 | 01:14 PM
ZZZed's Avatar
ZZZed
So if I have oil in my Intecooler piping as well as oil up to my throttle bottle. Most likely my SC seal has broken and I need to send the unit to vortech? I"m not talking about a couple of drops either. Its a good amount of oil coating the inside of the pipes.
Old Mar 19, 2007 | 01:22 PM
booger's Avatar
booger
That would be my guess . I dont think your gonna see that much oil coming from the breather hose . I cleaned all the lower pipes and the IC out , along with taking off the top of the plenum off to clean it out .
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
