vortech FAQ: read this before asking vortech questions
Old Aug 5, 2015 | 08:52 AM
  #2241
350Z_Al's Avatar
350Z_Al
Originally Posted by OldManZ350
Take the belt off and crub it with hot soap and water. If you feel the belt is done, get a new one.
Also do the same to your motor and pulleys.
Pulleys and belt always need to be clean. Any little bit of dirt, grease or coolant will just cause problems with a blower.
When tightening the belt, first take it up snug, then 1/2 turn each in till no slip or squeal.
If the Belt and pulleys are clean and you get squeal, then take the belt up 1/2 turn, if you still get squeal, then another 1/2 turn and so on.
Will do, thanks! Belts only got like 100 miles on it, so maybe it's still saveable.
How sung do you run your belt? On mine, on the long straight section between the power steering and the grooved idler I can twist the belt just over 90 degrees by hand. Is that about right or too loose?
I'm running this layout but with the GTM style pulley mod with two pullies.:
Edit.. I'll probably end up ordering one of your braces from you in the near future too.
Old Aug 5, 2015 | 09:19 AM
  #2242
OldManZ350's Avatar
OldManZ350
Yes about 90* is right. But if you have ANY Coolent on the belt or pulleys it needs to come off. Coolent is very slippery like oil.
Old Aug 5, 2015 | 10:27 AM
  #2243
350Z_Al's Avatar
350Z_Al
Thanks again! Car stayed home today, I'm going to take it off and soap it tonight.
Old Aug 13, 2015 | 02:05 PM
  #2244
350Z_Al's Avatar
350Z_Al
Woo!! Dyno day tomorrow!
Old Aug 14, 2015 | 06:06 PM
  #2245
350Z_Al's Avatar
350Z_Al
Well, good news and bad news.. Ran out of MAF (5.19v) on the dyno at ~5000rpm, ~10psi.
Made 407/348 on a rough tune, and a dynojet that has a tendency to read low apparently. Couldn't do too much after running out of MAF.
It's the older blower the first Z kits came with, 2.87 jackshaft pulley, 34/28 cog pulleys, added 'GTM' mod, Treadstone TR1045 Intercooler, and a 3" MAF pipe.
I was under the impression I would be good with the stock MAF in the 3" pipe because the 3" pipe increases the range ~20%, I guess not.
Based on my setup, anybody knowledgeable care to comment if running out of MAF at that point seems about right? I was a bit surprised, I thought I'd be good with the 3" MAF pipe.
Old Aug 17, 2015 | 07:55 AM
  #2246
the3kgt2's Avatar
the3kgt2
Yes, it's normal. Time to upgrade to the UpRev MAF GT
Old Sep 17, 2015 | 01:38 PM
  #2247
415FX35's Avatar
415FX35
Do you think 1000cc injectors are overkill for my setup? I tried to bring my fx35 to get tuned at zcgarage recently and they recommended that I go with 1000cc injectors(which they sell/install) to replace my gtr 570cc injectors. I did a lot of research on here beforehand and from what I've seen, a lot of people on here run the dw 600cc or the gtr injectors that is good for up to 400whp which is what I am aiming for. Below is my setup. What do you guys think? Thanks -Dom
-Vortech V3 Tuner Kit with 2.87 pulley
-GTR R35 570cc OEM Injectors
-Uprev GT Maf
-Walbro 255 Fuel Pump (no RFS since I need to pass smog in Cali)
-NGK Iridium Sparkplugs - 1 Step colder
-MotorDyne 5/16" ISO Thermal Space
-Fujitsubo Legalis R 3inch Exhaust
-M2 Performance Y-pipe
-Berk Technology High Flow Cats
Old Sep 17, 2015 | 06:04 PM
  #2248
OldManZ350's Avatar
OldManZ350
You're existing GTR Injector is Fine. No need to go bigger with you're setup.
-Uprev GT Maf
Old Sep 17, 2015 | 06:50 PM
  #2249
415FX35's Avatar
415FX35
You're existing GTR Injecot is Fine. No need to go bigger with you're setup.
Thanks! I'll stick with the GTR injectors.
Old Oct 10, 2015 | 07:35 AM
  #2250
350Z_Al's Avatar
350Z_Al
Modified the stock MAF, rescaled the MAF table in UpRev. Getting to about 4.5v at redline.
I still have a bit of belt slip to deal with, then back to the dyno.
Old Jan 28, 2016 | 02:56 PM
  #2251
Rev_Night's Avatar
Rev_Night
SO, i just read the past 6 pages, which goes back 2 years or so. I have a 2007 350z with about 46K mileage, K&N drop filters, Z1 hi flow cats, and MD Shockwave exhaust. As this is my daily driver and only car, I value stability and longevity first, and performance second. My goals are to have this car running for the next 50-75K mileage, and any HP north of 400 rwhp i'll be happy with.
I want to get forced induction and a supercharger fits my purposes more then a ST/TT. So a V3 Vortech/Stillen it is. Their official V3 page was a bit sparse in specs so I emailed them and I got the following response:
Our complete kit includes:
-Vortech V-3 supercharger unit preinstalled on our solid billet bracket
-Aluminum cast intake manifold that houses an intercooler
-Heat exchanger
-Dual intake filter system
-Mandrel bent aluminum intake pipes
-Fuel pump
-600cc injectors
-2.87' Pulley
-UpRev tuning solution (already have),
-Plug and play wiring harness and all necessary mounting hardware, hoses, etc.
I'm also planning on buying an upgraded oil cooler, Stillen recommended their SETRAB cooler for $488. Thoughts?
Based on above goals and parts, is there anything else I need? A local stillen dealer (PTUNNING, Manassass, VA) is doing the install.
Old Jan 4, 2018 | 12:01 PM
  #2252
JaE35z's Avatar
JaE35z
Old Aug 17, 2018 | 06:24 PM
  #2253
Golden_Armz's Avatar
Golden_Armz
Default Cog belt moving
Does anyone know how I can tighten the cog belt tensioner? My cog belt keeps moving away from the blower and is getting chewed up. I dont think my dog belt is tight enough. I tried pushing the pulley down to tighten it, but still can move the belt with my fingers. Any help would be appreciated.
Old Jul 23, 2019 | 03:00 PM
  #2254
lonewolf99's Avatar
lonewolf99
Hi,
after finally having read through all 113 pages..
1) can anyone help confirm the exact kit# from Vortech for a 2003 G35 5AT coupe?
I need a complete kit (CARB approved) since this is for a California car...
I called Vortech and their sales associate is saying it should be 4NZ218-010L but their install manual seems to indicate
kit# 4NZ218-010L as being "2003-2004 Standard Engine 350Z, V-3 SC" and doesn't mention G35.
vs
Kit# 4NZ218-030L for 2003 Infiniti G35, 6-Speed
the only difference in part#s between the two kits seemed to be 5A001-351 vs 5A001-354 - timing control box...?
I'm a little paranoid, I just want to get this ordered correctly and then worry about install and tuning without missing anything critical.
on relevant mods at this point are transgo valve body upgrade and HKS cat-back exhaust. oil cooler has been ordered, and will go in ahead of the SC,
along with upgraded radiator.
2) if I decide on getting CJM stage1 RFS along with Walbro lph 255 fuel-pump and DW600CC injectors,
would I still be able to use the Vortech SS box? if not what would be the next step?
goal is 400WHP, reliable daily driver that will pass standard smog check =)
any help would be greatly appreciated, looking to finally make this happen within next few weeks!
Old Mar 9, 2020 | 01:11 AM
  #2255
OldManZ350's Avatar
OldManZ350
Just saw your Post..... Kinda Late.
If you need any help with you setup or modifications, please feel free to PM me!
TimRod
Originally Posted by lonewolf99
Hi,
vs
Old May 20, 2020 | 07:49 AM
  #2256
acelow13's Avatar
acelow13
Is the vortech complete kit, not upgradeable? i wanna get the full kit so i have the CARB # but i notice everybody prefers to get the tuner kit, why? The complete kit comes with everything you need so if you want more power just change the injectors, pulley, intercooler etc. people make it seem like you cant do that with the full kit
Old May 20, 2020 | 07:50 AM
  #2257
acelow13's Avatar
acelow13
Default complete kit vs tuner kit
Old May 20, 2020 | 08:54 AM
  #2258
acelow13's Avatar
acelow13
Old May 20, 2020 | 10:01 AM
  #2259
THIRZTY's Avatar
THIRZTY
Yes it's upgradeable. The 'tuner kit' just isn't using Vortech's fuel/tuning management. Most prefer to use an upgraded return style fuel system, bigger injectors and their choice of tuning. The Carb # is actually on the blower. Once you switch to a return style fuel system, that pretty much a dead give away it's not CARB compliant anymore. If I had to smog my car... I'd rather just remove everything, make my car 'stock' and avoid the hassles.
Old May 21, 2020 | 01:50 PM
  #2260
acelow13's Avatar
acelow13
So even if i got the tuner kit it would still have the carb # on the blower?
