vortech FAQ: read this before asking vortech questions
Old Oct 7, 2008 | 06:17 PM
  #241
03zcarfl's Avatar
03zcarfl
so what can i expect with 5/8" plenum spacer, greddy evo 2 exhaust, 440cc, and a utec and a 2.87 ..... 400ish? 320 ish trq?
Old Oct 7, 2008 | 11:28 PM
  #242
sentry65's Avatar
sentry65
the burninator
probably pretty close to that, but I personally wouldn't do it without opening up flow more with changing cats, or headers, or cams. Otherwise you'll probably be over 12 psi which is up to you if you're comfortable with that psi level on a stock block.
440cc might not be enough injector for the 2.87. I always tell people to go with 550cc just to be sure, but if you already have 440's installed, give it a try and see where you end up first. It might work if the tune is conservative and depending if your state puts ethanol in the gas or not or how high the elevation is where you live
Old Oct 8, 2008 | 04:57 AM
  #243
ekelly36's Avatar
ekelly36
you think as long as I stay below 12 psi I should be ok? I will have a brand new motor, I know I need to break it in before installing the supercharger. if it was indeed 11.5 psi then maybe headers and cams will take me down to about 10?
Old Oct 8, 2008 | 06:00 AM
  #244
Asian Invasian's Avatar
Asian Invasian
how loud is the BPV when shifting? I know since its constantly open its pretty loud when cruising, but I can't find any clips of the BPV "blowing off". I am asking of course in comparisong to a BOV.
Old Oct 8, 2008 | 06:05 AM
  #245
ekelly36's Avatar
ekelly36
it sounds pretty decent. almost like a bov but not as defined. Bov is short burst sound.. the vortech (mine atleast) makes the sound a little longer and it fades into the normal jet engine sound.... I like it... I wondered if mine was louder than everyone elses but I got use to it.... mine goes pretty much silent when I am wot. I cant hear it over my exhaust, but any other time I can hear it. If I am just parking lot speed it is really loud....
Old Oct 8, 2008 | 06:45 AM
  #246
03zcarfl's Avatar
03zcarfl
we got 93 octane and etahnol added... im in florida so my elevation is less than 300ft at all times...lol... i was also looking into meth/h2o injection
Old Oct 8, 2008 | 06:46 AM
  #247
03zcarfl's Avatar
03zcarfl
btw hi flo cats are coming asap... want kinetix again
Old Oct 9, 2008 | 09:06 AM
  #248
Asian Invasian
Is the short burst sound usually as loud as a BOV?
Old Oct 9, 2008 | 09:07 AM
  #249
Asian Invasian
If you are in a higher elevation then will it be a lower PSI?
Old Oct 9, 2008 | 01:49 PM
  #250
sentry65's Avatar
sentry65
the burninator
strictly speaking about elevation, the short and simple answer is yes...but it's more complicated than that.
It still depends on where you are. It's sorta the same thing like temperature vs wind chill temperature.
A rough rule of thumb is air density will decrease about 3% for each 1000 ft of elevation above sea level which you can also ball park figure for your fuel requirement.
But the reality is there's still a bunch of other crap involved like temperature, pressure density, and how quickly lower density air compresses vs higher density air, and how that might slightly change the shape of your boost chart, etc.
Old Oct 9, 2008 | 02:03 PM
  #251
Asian Invasian
Just wondering because I am a mile high.
Any comments on the sound of the BPV? I can't ever hear them on any youtube videos.
Old Oct 9, 2008 | 02:08 PM
  #252
JonnyC's Avatar
JonnyC
No, it's quite a bit different. It sounds more like a gradual release that continues on (since the blower keeps pushing out air). My friend was driving next to me and said it sounds like a blow dryer while cruising...then someone turns it off when I go into boost. Then "pssshhh" and the blow dryer gets turned back on again
That's the thing - when you go into boost, it just sounds like a normal Z (with a little louder exhaust). So you don't get that "ramp-up" sound of a turbo - it's kind of the opposite.
However, just cruising around town it sounds pretty mean...especially rolling in somewhere allowing the engine to slow you down.
Old Oct 9, 2008 | 02:11 PM
  #253
Asian Invasian
lol a blow dryer?
Old Oct 9, 2008 | 02:49 PM
  #254
sentry65's Avatar
sentry65
the burninator
to me the blower sounds like a jet engine
the bypass valve sounds like a big rig truck's hydraulic brakes releasing air pressure
Old Oct 9, 2008 | 05:09 PM
  #255
Asian Invasian
That seems like a good comparison, I can get a general idea.. its as loud as a BOV then?
Old Oct 9, 2008 | 06:10 PM
  #256
Barzten1's Avatar
Barzten1
Believe me its plenty loud and I miss it. Very distinct sound.
Old Oct 9, 2008 | 06:18 PM
  #257
Quamen's Avatar
Quamen
You can kinda hear my BPV in these videos:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/ApDXfWZihWw&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/ApDXfWZihWw&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/NmjRr51m0GU&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/NmjRr51m0GU&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Crappy video by my friend but just after the 1:00 minute mark is a good outside sound of it:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/xX2uj2IPNFk&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/xX2uj2IPNFk&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
This is the standard Vortech bypass valve in all of the videos. In the first video it is hard to hear and almost sounds like it doesn't go off but it is because I have an exhaust in that video which I don't in the other two.
The second video you can faintly here it from inside the car and in the last video from outside it is clearly audible at the end.
Old Oct 9, 2008 | 10:16 PM
  #258
Asian Invasian
That last video is what the BPV sounds like? I think it sounds sick.. not like a swoosh like everyone is saying though..
Old Oct 10, 2008 | 07:32 AM
  #259
350z006's Avatar
350z006
Here's some videos from a member on the 350**tech forum; you can definitely hear the BPV:
http://s306.photobucket.com/albums/n...t=MVI_3386.flv
http://s306.photobucket.com/albums/n...t=MVI_3387.flv
Old Oct 10, 2008 | 08:16 AM
  #260
vortechg35's Avatar
vortechg35
Where do I get the 2.87 and will belt slippage be a problem?
