vortech FAQ: read this before asking vortech questions
Old Mar 4, 2008 | 09:36 AM
  #161
JonnyC's Avatar
JonnyC
Alright I searched this thread and couldn't find anything. I just got a used kit, but it didn't come with any of the parts to tap the upper pan. It looks as though a new kit comes with a center punch and 9/16" cutter. Can I just use normal drill bits to work my way up to 9/16" and then use a 3/8" NPT tap? I assume the 3/8" fitting is 3/8" ID, with the outside diamter close to the size of 9/16"?
UPDATE: I purchased the return line kit from Vortech in order to get the cutting bit along with the arbor, because it was pretty much the same price if i bought those separately. Drilling out the hole was really easy actually, using a basic Dewalt drill (didn't need a right-angle drill). I just had to bend the coolant hard line out of the way and remove the sway bar and bracket from the frame...
Old Mar 4, 2008 | 10:24 AM
  #162
JonnyC's Avatar
JonnyC
Also, I was planning on using one of the 1/8" NPT ports of a sandwich plate i purchased for the feed line, instead of using the T fitting from the Vortech kit (didn't get it with my used kit anyways). Since this would move the connection further out, is the supplied braided hose long enough to reach out a few more inches?
I have to call Vortech soon to order a few parts, so I need to know if I should get a longer feed line, or just order the T fitting with adapter for 1/8" BSPT.
Thanks!
UPDATE: Using a sandwich plate will work fine, and using the supplied 90 degree fitting the line easily made it over the to supercharger. I was a bit worried that I would be sending unfiltered oil when the normal installation would be sending filtered oil through the pressure port, but it was determined that both the sandwich plate and pressure port would be supplying unfiltered oil.
Old Mar 12, 2008 | 09:56 AM
  #163
JonnyC's Avatar
JonnyC
FYI for anyone looking for a 3/8" NPT Tap for the return line (if you don't want to go driving around to your local stores to find one)...
I just placed an order for this one http://www.galesburgelectric.com/sto...productid=9349
It was the cheapest I could find (including shipping). I'll let you know how it works out.
EDIT: umm yeah, they shipped it out within 3 hours of ordering it and the UPS tracking number already works - awesome!
EDIT again: My local Harbor Freight has a 4 piece tap kit that includes a 3/8" NPT and it's only like $14 - so much for this "hard to find" tap.
Old Apr 9, 2008 | 05:01 AM
  #164
naturalstateZ's Avatar
naturalstateZ
sweet. Awsome info. Now I need to check the prices on all the parts recommended. hopefully under 10K. again thanks for the info
Old Apr 24, 2008 | 10:46 AM
  #165
supernadc2's Avatar
supernadc2
This was one of the most helpful threads ive read through... thanks guys now i can sleep at night knowing i know what im doing finally haha.. just waiting on a kit for the HR!!
Old Apr 24, 2008 | 12:31 PM
  #166
sentry65's Avatar
sentry65
the burninator
glad it helped
Old Apr 25, 2008 | 06:28 AM
  #167
Highway Riding's Avatar
Highway Riding
Excellent thread that actually answered a ton of questions i was thinking about asking.. I seriosuly considereing this kit as opposed to a turbo for reliability issues and on top of that i plan on using everything i have already installed.. great thread...
Old Apr 29, 2008 | 12:11 AM
  #168
c3 rolling's Avatar
c3 rolling
hey sentry, i saw that you posted the blower doesnt get that hot and your able to touch it. Ive noticed my blower get REALLY hot and could almost burn my hand.....
Old May 9, 2008 | 07:10 AM
  #169
ekelly36's Avatar
ekelly36
so after reading 9 pages I just have 1 question... people have compared SC to TT but I am between the STS rear mount and the Vortech.... I didnt ever want to mess with turbo manifolds and red hot turboes under my hood... The STS is a single system and I dont really know the differences between the single turbo and dual.... If I will get the same power with the rear mount that I will with the Vortech then I will probably go vortech......which would be the best route to go?
Old May 9, 2008 | 09:46 AM
  #170
JonnyC's Avatar
JonnyC
The Vortech won't give you the torque that the single turbo will. And as I understand it, you won't feel the vortech as much as the turbo because it provides a linear power curve (feels like a much stronger n/a car). The Vortech should be safer for two reasons - not a ton of torque down low like the turbo, so less stress, and no chance of over boosting. However, if you get it installed and tuned properly, that won't be a big deal.
If I lived by an good tuner, I my have went the STS route.
Old May 9, 2008 | 10:18 AM
  #171
ekelly36's Avatar
ekelly36
Yea I think im kinda leaning toward the STS but I wont know for a couple more months when I get money saved I have changed my mind so many times my wife is starting to go crazy lol
Old May 12, 2008 | 01:58 PM
  #172
chaparro78's Avatar
chaparro78
Been reading this for 2 hours now looking for a belt size and it has me all confused now. Just need a simple answer. I have an 03 non rev Z with a 3.12 pulley and switching to a 2.87 pulley. Keeping original design of system.
From what I have read I need to get the 93" belt.
NAPA part# 25-060930.
http://www.napaonline.com/NOLPPSE/(S...Dn=0&Dk=1&Dp=3
or NAPA part # 060926
Old May 12, 2008 | 03:48 PM
  #173
350Z400rwhp's Avatar
350Z400rwhp
Mine is the same way, can only put my hand on it for a second or so, is this normal?
Old May 12, 2008 | 04:58 PM
  #174
sentry65's Avatar
sentry65
the burninator
that's normal. You can put your hand on it briefly
Contrast that with putting your hand on a red hot 850 degree turbo...
Old May 12, 2008 | 07:56 PM
  #175
350Z400rwhp
Ok so its relatively cool lol. Makes sense as the oil that runs through the supercharger has to be at least 200+ degrees. Thanks Sentry.
Old May 12, 2008 | 09:30 PM
  #176
JonnyC's Avatar
JonnyC
Hmm...my Si trim was still really hot even after the car was off for 30 mins or so. I couldn't keep my hand on there for longer than 1/2 a second.
I'm planning on getting an oil cooler soon, because things seem to be running pretty hot.
Old May 13, 2008 | 03:17 AM
  #177
350Z400rwhp
[QUOTE=JonnyC]Hmm... I couldn't keep my hand on there for longer than 1/2 a second.
Forget the oil cooler, you just need to man up and hold your velvet soft hand on there Johnny
Old May 13, 2008 | 06:24 AM
  #178
JonnyC's Avatar
JonnyC
Haha...that is so true
Old May 28, 2008 | 12:34 PM
  #179
JasonZ-YA's Avatar
JasonZ-YA
Do they make a Vortech SC that doesnt require oil lines and use of the engines oil to cool the Vortech........ive searched like crazy and cant find info on this, but i swear i read that somewhere....a vortech with a sealed oil unit built onto it?
- J
Old May 28, 2008 | 03:56 PM
  #180
05Z33's Avatar
05Z33
They make a V3 blower. It just came out and no one here has tried it yet.
