vortech FAQ: read this before asking vortech questions
Old Apr 15, 2009 | 06:25 PM
  #421
Quamen's Avatar
Quamen
Originally Posted by Car vs. Driver
From your sig, it appears you have a different impeller ... that will make a world of difference. The 928 impeller is a different design and builds more boost at lower RPM's. I'm making 10.9 PSI of boost at 6700 or so. I would guess at 425 on a dynojet, but I'll find that out on the 25th actually when I go to the Verocious Motorsports meet here in Delaware and spin the rollers on their dyno.
Oh, and I'm certain my calculator is correct. I used the formula that vortech gives to calculate it.
Just looked up the 928 impeller details ....
That would explain the 10K RPM difference. Again, this is why my next mod will be this impeller and a 2.70 pulley - I'm certain the stock bottom end will not like that for very long
I made 394 with the stock impeller though.
Old Apr 15, 2009 | 06:36 PM
  #422
Car vs. Driver's Avatar
Car vs. Driver
Which pulley? Either way, those are great numbers and also a good reason why comparing dynos is a waste of time . I think track times are the best yard stick.
Gotta love the heart breaker!
Old Apr 15, 2009 | 06:57 PM
  #423
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
do you guys have a link or website to where I can order the 2.87 with gates belt? is there a combo for such deal?
Gtm sells the 2.87 with belt combo but they use bondo belts.
Thanks fellass
Old Apr 15, 2009 | 06:59 PM
  #424
Quamen's Avatar
Quamen
I hear you on track times being the best indicator.
I am running a 3.25" pulley but I also have a larger diameter crank pulley than anyone else (6.22") and I am now switching to a 6.88" crank pulley.
Old Apr 16, 2009 | 03:38 AM
  #425
Car vs. Driver
What made you go with the larger crank pulley?
VAS@Extended .... I use the bando belt with my setup, no GTM pulley and haven't experienced any slipping.
Old Apr 16, 2009 | 03:48 AM
  #426
Quamen's Avatar
Quamen
So I can hit the same impeller speeds as everyone else using a larger supercharger pulley to help fight belt slip. I also run an 8-rib indpendent drive belt for the supercharger.
Old Apr 16, 2009 | 04:11 AM
  #427
Vas@Extended
hm, I guess Ill just order the 2.87 from them then. I already have the gtm pulley upgrade so i guess slipping shouldnt be an issue then.
one more questions:
George asked me to specify the belt setup. New style or old style. Which one do you recommend? which one do you use?
Thanks man!
Old Apr 16, 2009 | 04:48 AM
  #428
Car vs. Driver
Quamen, can you send me pics of your setup? It sounds pretty slick and I'd love to see it.
Vas, I have the out of the box belt setup. I figured I'd start with that and if I get any slip I'd change things around. So far so good.
Old Apr 16, 2009 | 06:08 AM
  #429
Quamen's Avatar
Quamen
This is changing though as stated above. I would like to do a twin supercharger setup with my built motor but the more I look into it everything works out fine until I try getting the charger pipe to the intake manifold. the only way I could really do it would be with the Corvetter style intake manifold Phunk made.
However, the opportunity for a Vortech V7 YSI blower just kinda just presented itself so who knows. In the next to months I am going to push the SC-Trim with the 928M impeller to it limits at around 60,000rpm's and see what happens. If by then I haven't hashed out the couple issues with the twin charger I am just going to stuff the V7 in there and let 'er eat.
Old Apr 16, 2009 | 06:16 AM
  #430
Car vs. Driver
Nice setup you have there.
Old Apr 16, 2009 | 06:29 AM
  #431
Chef-J's Avatar
Chef-J
Booooosstt!!
one more questions:
Thanks man!
This is what i'm running, i don't know if it's new or old.
https://my350z.com/forum/attachments..._non_revup.gif
But if i go with 2.87 pulley, i want to try this setup.
https://my350z.com/forum/attachments...erp_pulley.gif
Make sure you let the George know, what belt size. I ended up buy new belt
chefj
Old Apr 16, 2009 | 06:56 AM
  #432
Vas@Extended
chefj
Chef,
thanks! for the links.
I like the 2nd setup, minus the lower pulley which i dont have ( that shouldnt matter im guessing? ) I only have the gtm pulley.
This whole belt size thing is making thing so complicated I dont get it lol. What size ( inches ) is the belt that I would need with the 2.87?
car vs driver- Thanks man. if your not having any slipping with the old setup and gtm pulley maybe I will go that route? ughh this stuff is confusing lol. what size belt do you have? if you dont mind me asking.
thanks
Old Apr 16, 2009 | 07:07 AM
  #433
Car vs. Driver
I honestly don't know what size it is, I just went into the garage and checked and couldn't see the part number to verify.
Old Apr 16, 2009 | 07:11 AM
  #434
Vas@Extended
darnn
Old Apr 16, 2009 | 07:18 AM
  #435
Car vs. Driver
I have a bunch of crap to do on the car Saturday, I'll get the part number then and PM you.
Old Apr 16, 2009 | 08:01 AM
  #436
Vas@Extended
sweet thanks
Old Apr 16, 2009 | 08:09 AM
  #437
Vas@Extended
OT- How much do the 3.12 pulleys are selling for? with belt. I have a set that I want to sell, but I dont know how much to ask for.
Old Apr 16, 2009 | 08:25 AM
  #438
Car vs. Driver
With the belt, maybe $100 tops.
Old Apr 16, 2009 | 08:29 AM
  #439
Chef-J's Avatar
Chef-J
Booooosstt!!
Just a belt is 50 bucks ( gates ) so i'm assumming around 100 bucks like Car vs driver.
Vas- My belt size is around 80" so i'm pretty sure you will need shorter than that. I would say start with couple of inch shorter. I think belt size might can be change depends on how your belt setup. Well good luck!
Edit: Dave, sorry about delay on shipping, but sent you track number it's thru UPS. And i just checked and scheduled on this friday
chefj
Old Apr 16, 2009 | 08:37 AM
  #440
Car vs. Driver
No problem dude.
Man, I'm on this thread today like a fly on chit. I really do have better things to do, I swear.
