vortech FAQ: read this before asking vortech questions
Old Jun 11, 2010 | 07:14 AM
  #1281
binder's Avatar
binder
well, if it's a pressure build thing then i would look at your crank venting situation. I would vent your breathers to atomosphere (catch can) so to release some pressure. If pressure is blowing the dipstick out then the lower crankcase is getting pressurized. It shouldn't have THAT much pressure in it.
Old Jun 11, 2010 | 07:33 AM
  #1282
4SHIZZIL's Avatar
4SHIZZIL
Yes I did notice PCV giving out around 6psi....so I ran that vent to a catch can. capped off the line.
Just wanted to make sure there wasnt something else that I could do.
after the comp and leak down before putting this block in, I was (AM) very dissappointed. I dont drive the car daily and now I have been dropping more time and money in it than ever before. I do take her to the store once or twice a week but man.....
The more HP the more Problems.
Old Jun 11, 2010 | 08:16 AM
  #1283
iStan's Avatar
iStan
ZR
I wonder if seafoam would be good for you now. It's something I've been meaning to do, but I keep forgetting.
Old Jun 11, 2010 | 01:31 PM
  #1284
4SHIZZIL's Avatar
4SHIZZIL
I actually am all for cleaners and mixers from time to time, just not as an oil additive...my only issue is with my blower. I have V1 so my oil goes through my blower not self contained....
I guess I could disconnect then run it for a bit to clean, then reconnect after oil change, but I am always thinking about the blower more than the motor.
I just had my S rebuilt to a T trim and that two weeks killed me running NA...lol.
Id rather the car sit at my house for a month without cranking it up (but the ability too) than for 3 days at any shop regardless of how good they are.
If I drop something in there that harms my blower...im going to be double upset at my self inflicted wound! LMAO
Old Jun 11, 2010 | 01:34 PM
  #1285
4SHIZZIL's Avatar
4SHIZZIL
FYI I have not ran the car on the dyno or at all since eliminatating the PCV system.
I will update as always when that time comes. Maybe that TTrim w the 2.87 on the RevUp is too much? lol
Old Jun 16, 2010 | 09:00 AM
  #1286
Erdem's Avatar
Erdem
Juuuubiiiiii!!!!.... now I have misfire on my car..
at this moment I drive with stock injectors (without the vortech, waiting to get her tuned), Walbro fuel pump, TD Exhaust..
to begin with.. cel came on.. but I though, it was the new 2 x 2,5" exhaust that caused it..
few days later the car would stop, sometimes when on idle..
and today it began to smoke like steam-train..
is there anything I should be aware of?
EDIT: the codes i got was p0300 and p0430
Old Jun 16, 2010 | 09:51 AM
  #1287
binder's Avatar
binder
0300 is random misfire. i don't know the other.
smoke could be from misfires and unburned fuel
Old Jun 16, 2010 | 11:03 AM
  #1288
Erdem's Avatar
Erdem
yep it is running on 5 cylinders at this moment... my tuner just looked at it.
Old Jun 16, 2010 | 12:05 PM
  #1289
Erdem's Avatar
Erdem
anyways... did you solve your issues with your car Jeff?
Old Jun 18, 2010 | 04:23 PM
  #1290
Synjn's Avatar
Synjn
Quick Question: What does your boost gauge indicate when you are at an idle? I'm at -15 psi aprox. Sometimes -17 psi depending on the weather. What does that say about my crankcase venting. Is that normal for us with Vortechs?
Only reason I ask is because my oil gets dirty relatively quick after an oil change.
my setup:
Passenger side valve cover vent runs directly to catchcan then to intake plenum. Driver side valve cover vent runs directly to my supercharger inlet. Which now is blowing by oil out my bypass valve and into my intercooler.
Old Jun 18, 2010 | 09:27 PM
  #1291
GT-ER's Avatar
GT-ER
P0430 = Catalyst System Efficiency Below Threshold
It just means you catalytic converter is damaged ( or gone ) or your secondary 02 sensor is bad ( which really doesn't matter unless you care about emissions and stuff..lol ).
Old Jun 19, 2010 | 11:14 AM
  #1292
binder's Avatar
binder
depends on which issue you're talking about. the lean issue, i'm not sure cause the car is still in pieces. i'm sure the spacer was hte issue though.
  #1293
binder's Avatar
binder
unless the cat failed and is blocking the pipe, which is a very common problem on forced induction on cars with cats.
Old Jun 19, 2010 | 11:50 AM
  #1294
Synjn's Avatar
Synjn
I could really use an answer to my previous question fellas. Thankx in advance.
Old Jun 19, 2010 | 06:35 PM
  #1295
GT-ER's Avatar
GT-ER
True, didn't think about that.
Old Jun 20, 2010 | 02:17 AM
  #1296
Erdem's Avatar
Erdem
I don't have my Vortech connected yet... so I can't answer to that unfortunately..
Old Jun 20, 2010 | 05:59 AM
  #1297
GT-ER's Avatar
GT-ER
my setup:
Mine is usually at about -18 to -20 at idle. Don't know how normal it is though.
Old Jun 20, 2010 | 08:40 AM
  #1298
maXmood's Avatar
maXmood
Under Boost!
mine is about the same too..
however, when on Drive and my foot on the brake, it goes to -16.
Old Jun 20, 2010 | 08:53 AM
  #1299
akks350z's Avatar
akks350z
-22 at idle on mine
Old Jun 20, 2010 | 03:35 PM
  #1300
GT-ER's Avatar
GT-ER
Today I checked with my AC on and in Drive and it went to -16. With AC off and in park it's at -20.
