vortech FAQ: read this before asking vortech questions
Old May 17, 2010 | 11:22 AM
  #1201
Erdem's Avatar
Erdem
so today we got a new belt on.. about 3/4" shorter I think...
and got up to almost .55 bar I think it's almost 8psi.. with the 3.12 pulley, is this normal?
my mods are: Stillen TD exhaust and everything else is stock it's a manual also...
what do u guys think I should expect of hp numbers?
the dyno read 248hp with everything stock before the installations began..
thanks in advance jeff.. lol
Old May 17, 2010 | 12:44 PM
  #1202
binder's Avatar
binder
3.12 is like 8psi give or take. I think some people might get it up to 9psi but it varies from car to car and conditions.
see if you can log the boost so we can see if it's slipping up top. remember a new belt will stretch quickly so you'll hvae to adjust it after about 100 miles then again at 500 miles. i would say a few dyno runs and it might loosen up and need to have another 1/2 turn of the tensioner to stay tight.
glad to hear it's working...lots of times it's a simple problem.
probably gonna be mid 300's give or take. 325-375. depending dyno, car, conditions, etc.
Old May 17, 2010 | 01:46 PM
  #1203
Erdem's Avatar
Erdem
how many whp will a stock 03 make?
Old May 17, 2010 | 02:34 PM
  #1204
Erdem's Avatar
Erdem
and thanks again Jeff.. if it wasn't for you and this forum, my SC would be on it's way to Vortech for an "inspection"... and I would wait months for it to come back...
so thank you again for the help. I appriciate it..
Old May 17, 2010 | 02:46 PM
  #1205
binder's Avatar
binder
glad i could help. many forum members have helped me so it's nice to give back. Plus a lot of us have been in the same place you were so you came to the right area to ask.
Old May 18, 2010 | 11:09 PM
  #1206
Synjn's Avatar
Synjn
Binder can I get a location and a part # for that 80 1/8" gates belt for the revised belt layout. Thankx
Old May 19, 2010 | 10:07 AM
  #1207
binder's Avatar
binder
http://www.amazon.com/Gates-K060795-...4292349&sr=1-1
gates k060795
napa will carry them but i think they use a different part number. that amazon one is cheaper than napa if you can wait for shipping.
Old May 19, 2010 | 01:10 PM
  #1208
maXmood's Avatar
maXmood
Under Boost!
gates k060795
that's the same belt i'm running, which isn't tight at all (can be twisted more than 90 degree) while the tensioner is at it's max..
i need a shorter one. has anyone gone to a shorter belt than this?
Old May 19, 2010 | 01:19 PM
  #1209
Erdem's Avatar
Erdem
^I also have the same belt.. and also got the tensioner pulley to the max, and it was still slipping..
Old May 19, 2010 | 03:25 PM
  #1210
Chef-J's Avatar
Chef-J
Booooosstt!!
Maxmood, that's way too long imo.
What pulley and with GTM pulley mod?
Try 1/2 short or 1" short belt and see if that makes diff. No worry tho, belt numbers are just giving an idea where to start. Some people may need little shorter or little longer than other members. ( Somehow )
Old May 19, 2010 | 03:30 PM
  #1211
Chef-J's Avatar
Chef-J
Booooosstt!!
gates k060795
Humm maybe napa price went up? I used to get my belts from napa for around 25 bucks.
Old May 19, 2010 | 03:48 PM
  #1212
iStan's Avatar
iStan
ZR
Chef!! Long time........YOU SOLD YOUR Z???
Old May 19, 2010 | 04:56 PM
  #1213
Z_ology's Avatar
Z_ology
I have gotten tons of useful info from this thread over the last year
Here is a link to my short build thread in the regional forum:
https://my350z.com/forum/north-centr...ts-review.html
Old May 19, 2010 | 04:58 PM
  #1214
Chef-J's Avatar
Chef-J
Booooosstt!!
Yep Yep. Your vortech still running strong in vegas weather?
Edit: i'm not around here much as before, so shoot me pm whenever you have nothing to do. I do still check here tho...maybe once in coupe day lolz...
Old May 19, 2010 | 05:37 PM
  #1215
binder's Avatar
binder
ya, do you guys have the pulley mod?
I literally couldn't pry the 79" belt on there with a pry bar. i have tons left to tighten on my 80 1/8" belt.
pulley mod took extra belt to fit.
Old May 19, 2010 | 11:32 PM
  #1216
- bigc -'s Avatar
- bigc -
i just swapped from a 2.87" pulley to a 3.12" pulley and had to play around with belts. some more data points:
new 79.5" belt works for 2.87 with GTM pulley
used (ie. stretched) 79.5" belt works for 3.12 with GTM pulley (just barely though)
new 80-1/8" to 80-3/8" belts work for 3.12 with GTM pulley
Old May 20, 2010 | 02:16 AM
  #1217
nurrishd's Avatar
nurrishd
Some advice needed
Currently running a 2.87 pulley which makes me 420whp @n 12psi on orisis. The tuner is holding the power back too as my car just wants to keep making power. I am running Str8dum1's old kit which is an SI trim impeller and 600cc injectors with a return to tank fuel system
So having lived with the car for about 1 month in its current state i am looking to get a bigger pulley and reduce the boost to get better fuel consumption and less power to achieve a more reliable car.
Do i keep my belt and get a 3.12 pulley or do i get a new belt and a 3.33 pulley?
I am pretty sure if i dropped to a 3.33 pulley my tuner could still get me 380whp which would be perfect. But if you guys think that's not achievable then maybe i should go for a 3.12 pulley
Old May 20, 2010 | 02:21 AM
  #1218
maXmood's Avatar
maXmood
Under Boost!
that's what i thought...
i'm running 2.87 pulley with no GTM pulley.
i don't see dust on the pulley, but the belt can really twist over 90 degrees (probs 100 degrees). and i think that's probably the cause of having a low boost.
i'm gonna try to find something shorter than that (k060790, like binder suggested) or even shorter.
Old May 20, 2010 | 04:03 AM
  #1219
maXmood's Avatar
maXmood
Under Boost!
i'm wondering tho, why i wasn't supplied with the correct belt when i ordered my kit?
i mean, is it usually an 80 1/8" belt for the 2.87 pulley, and with that you'll have enough threads to tighten it more in if required??
Old May 20, 2010 | 04:13 AM
  #1220
maXmood's Avatar
maXmood
Under Boost!
^with that being said, then 79.5" without the GTM pulley isn't the best belt.
should i consider 79" belt?
