water/meth and FCon
Old May 13, 2007 | 01:47 PM
MADScientist's Avatar
MADScientist
Default water/meth and FCon
I am ready to take the plunge on an injection kit, but wondering about a few things...
For you FCon tuners out there... Most of the name brand kits (I am looking at the Snow Performance) have the ability to trip a 12 volt switched source if something is not working right on the injection kit (out of fluid, short, pump failure, etc). Can the FCon switch maps based on this trigger?
For example... I have a few buddies with Supras running this setup with an AEM. The injection kit trips a 12 volt source when it is activated and that tells the ECU to run that map. If the injection kit does not activate the relay then the AEM runs the defualt map which is a safe mode map.
I am looking to do something similar to this with the FCon and not have to buy the Navigator to do it. Otherwise Snow Performance has a boost limiter sel. tha can be used to avoid engine damage.
Any other thoughts on this would be great! I plan to run the greddy kit to 22psi with this setup on pump gas and injection. I am running 16psi now and starting to see some knock on just 93 octane.
Old May 13, 2007 | 04:01 PM
westpak's Avatar
westpak
SFZCC
I am a newbie at this but have been reading the manuals over and over as I setup my car and the answer should be yes but I think with a 5 volt signal.
Old May 13, 2007 | 05:46 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The FCON can trigger a water meth system, and shift to a submap when this occurs. It needs to be programmed, but it is definately doable.
Old May 13, 2007 | 06:53 PM
MADScientist
Well then Sharif... we will talk at ZDayz!
Old May 13, 2007 | 07:29 PM
Sharif@Forged
Forged Performance
hehe....and remember..the high boost setting is borderline race fuel mix territory.
Old May 14, 2007 | 03:51 AM
MADScientist
If that means we can stop "teasing" the Cosworth heads and make some stupid and useless horse power I am all in!
Old May 14, 2007 | 06:55 AM
Sharif@Forged
Forged Performance
hehe....the guy who made 492whp on our dyno did 540whp on the dynojet. I have no doubt you are very close to 600whp on the DJ. Doesnt anyone need more than that for a street car??
Old May 14, 2007 | 10:21 AM
BamBam's Avatar
BamBam
I need more....
Old May 14, 2007 | 10:43 AM
MADScientist
I run low boost on the street! But on a serious note, I have plans on putting this car into the 10's and with the limited tire choices I have using a BBK I think the only other way to do it is with lots of extra HP...
I have been talking to the local Supra guys here in Indy and they swear by methanol injection over race gas for a street car. There is a guy here that is running 800whp daily driven with pump gas and injection. I don't see any reason why we cant to this on a Z as well. Its not like I am going to run it at these power levels any place other than the track...
Old May 14, 2007 | 12:18 PM
k3silk's Avatar
k3silk
Go for it you can be the test guy then if it works we all will copy!
Old May 25, 2007 | 04:31 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Hey Joe (jkenefic) did you ever get an answer from the guys a Alky about our kits? Give a ring when you get the details.
bcoffee20
Nov 19, 2015 06:39 PM
phunk
Sep 17, 2006 05:49 PM
MIAPLAYA
Jun 19, 2006 06:15 AM
35ounces
Dec 13, 2005 07:49 AM
phunk
Aug 17, 2004 10:05 AM
