2 turbonetics install questions.....
Old May 26, 2007 | 07:59 AM
freezeg35's Avatar
freezeg35
Default 2 turbonetics install questions.....
There is one pipe underneath that is heat wrapped, but quite close proximity to the lower rad hose......normal?
The rubber intake on the front of the turbo rubs against the side of the rad itself......normal?
Thanks.
Old May 26, 2007 | 08:09 AM
carfi179's Avatar
carfi179
Yes it's normal based on my experience and some of people I know that have TN kit. Nissan just didn't leave enough room for FI application.
Old May 26, 2007 | 09:45 AM
taurran's Avatar
taurran
How close are we talking?
You may need to realign the turbocharger and/or tweak the whole setup to get it not to rub. I took quite a bit of time actually removing the turbine and compressor housings and aligning them to get mine to sit perfectly without rubbing.
Old May 26, 2007 | 09:50 AM
QuadCam's Avatar
QuadCam
I even heat wrapped my lower radiator hose, too. If you have any doubt, heta wrap it.....and then, wrap it again.
It is kinda like having sex with a Thai hooker,....don't take any chances, and double wrap it!!!
Old May 26, 2007 | 12:18 PM
freezeg35's Avatar
freezeg35
Its actually touching the side of the rad. My installer mentioned something about tweaking motor mounts to me...........
Old May 26, 2007 | 10:53 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
haha, what about korean hookers, have you seen TN model??? jk guys!!
Old May 27, 2007 | 03:41 PM
freezeg35's Avatar
freezeg35
The intakes are different on the g vs the z, maybe its normal on the g35?
Old May 27, 2007 | 05:40 PM
2slo2bfurious's Avatar
2slo2bfurious
Thanks.
It shouldn't rub, you talking about the rad. or the rad. pipes/hardlines? I'm saying because you have to bend the pipes away for the thing to fit right....
Old May 27, 2007 | 05:44 PM
Eazzy's Avatar
Eazzy
Both are tight fits --keep piping loose till you get everything as best u can then tighten everything down ------ There is ALWAYS little mods that have to me done with any install
Old May 27, 2007 | 07:24 PM
freezeg35's Avatar
freezeg35
The rubber intake that goes on the inlet of the turbo rubs against the side of the rad.
Thanks all.
Old May 27, 2007 | 07:57 PM
Eazzy's Avatar
Eazzy
I have ground away ( neatly, so I dont get flamed ) the core support. then I keep an eye on it an rotate it during filter cleans
Old May 27, 2007 | 10:13 PM
ZXORCST's Avatar
ZXORCST
My lower rad hose was about 2 secondes from blowing when I found out. I installed the silicone hoses heat wrapped the exhause and zip ties the hose out of the way.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
