Update on the Brian Crower Stroker kit.
Old Jan 14, 2011 | 08:52 AM
  #201
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it is, but like any other stroker, it needs machining...comes with the territory
Old Jan 14, 2011 | 08:56 AM
  #202
e30cabrio's Avatar
e30cabrio
4 digits worth?
Old Jan 14, 2011 | 09:04 AM
  #203
Z1 Performance
Former Sponsor
again, you need to ask your machinist what all is involved and what he will charge
Old Jan 14, 2011 | 09:10 AM
  #204
e30cabrio's Avatar
e30cabrio
Thanks
Old Jan 14, 2011 | 04:25 PM
  #205
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Block needs to be cleared in several places, and you will also need a billet girdle which will also need some modification. It really comes with the territory, when putting a stroker in a VQ35.
Old Jan 14, 2011 | 04:55 PM
  #206
Kwame's Avatar
Kwame
Sharif, for a FI build I agree with you 100%. However, for a naturally aspirated stroker build notching the stock girdle will be adequate.
Old Jan 14, 2011 | 04:57 PM
  #207
Sharif@Forged
Forged Performance
The OEM girdle is fairly thin in places, and it worries me to carve away too much of it. You are correct it can be done with OEM.
Edit: What worries me more, and is kinda creepy...is we are posting in Julians thread from 2007.
Old Jan 14, 2011 | 05:03 PM
  #208
Sharif@Forged
Forged Performance
Originally Posted by Z1 Performance
Yes they still offer it actually - it's not part of their official catalog anymore, but if it's what you want, they will do it for you - but there is no advantage to it according to our direct discussions with BC. The net difference with the largest piston is 4.07 liters vs 4.15 liters - you tell me how much of a difference that will yield. That is why they introduced the slightly smaller stroke one - because it needs alot less machining (retains squirters), and will yield virutally identical power for all intents and purposes.
There never were issues with it...the issue is on the part of an installer who may be ill experienced for this type of build in the first place. A stroker is shoving 10 lbs of dung into a 5 lbs bag. Some guys know how to do this, others don't. You gotta find the machinist who knows how. The larger stroke crank will simply require alot more machine work and eliminates the factory oil squirters - which again can be compensated for in any number of ways by someone who knows what they are doing in the first place.
The 86.4 crank still does not retain the squirters....just for clarification.
On Rich's engine we were able to modify the pistons and couple other changes to retain the squirters but it was not easy.
Old Jan 14, 2011 | 05:29 PM
  #209
Kwame's Avatar
Kwame
Good times when he was around. Oh well...
Old Jan 14, 2011 | 05:40 PM
  #210
e30cabrio's Avatar
e30cabrio
Thanks for the insights, Sorry if this is a bad thread to dredge up, I searched for BC 88mm crank and this seemed the best place to ask.
Old Jan 14, 2011 | 06:26 PM
  #211
e30cabrio's Avatar
e30cabrio
How much would you guess preparing the oem gordle? Would I be better off getting this?
https://my350z.com/forum/engine/4010...dle-249-a.html
Where is the part number hidden on the crank/box? I have nothing but this:
The label just has the specs.
Old Jan 14, 2011 | 08:20 PM
  #212
str8dum1's Avatar
str8dum1
^ thats the girdle that Sharif was talkin about that we used on my motor. 250$ is a small price to pay. I wouldnt mess with notching the stock piece.
Old Jan 14, 2011 | 10:14 PM
  #213
abushong504's Avatar
abushong504
This is the girdle I used for my BC stroker kit/engine.
http://www.350zmod.com/Injected-Perf...r%20vqgrdl.htm
Old Jan 15, 2011 | 05:55 AM
  #214
e30cabrio's Avatar
e30cabrio
Anyone know how to decipher this?
It says 026 A88 0702005.
Old Jan 15, 2011 | 08:37 AM
  #215
go-fast's Avatar
go-fast
guess: 026A88=26th 88mm crank and 0702005 (7th month of 2005)=crank design date (not manufacture date)
call and ask
Old Jan 15, 2011 | 08:48 AM
  #216
e30cabrio's Avatar
e30cabrio
I sent them an email with the picture.
Figured it could not hurt to ask. I am sure someone knows.
The date was my guess as well as the 88mm, but there are balanced and unbalanced versions of all part numbers and there has to be a way to tell based on something on the crank.
Thanks
Old Jan 15, 2011 | 11:56 AM
  #217
str8dum1's Avatar
str8dum1
thats the balance one.
The unbalanced has a U stamped at the end of the crank
Regardless, your machine shop should always check it anyhow
Old Jan 15, 2011 | 11:58 AM
  #218
e30cabrio's Avatar
e30cabrio
My luck improves!
Uh oh!
I intend to have the entire rotating assembly balanced.
Thanks
Old Jan 15, 2011 | 01:20 PM
  #219
Z1 Performance
Former Sponsor
You have no choice but to balance the whole thing
How well its balanced and to what rpm I have no idea you have to ask them.
I hope you realize what you stepped into and that it comes to fruition - it ain't going to be cheap or any adjective remotely close to cheap. As everyone has suggested you need to find a good machinist to do this who is used to doing builds of this level and guide you through your next steps and purchases.
Old Jan 15, 2011 | 01:23 PM
  #220
e30cabrio's Avatar
e30cabrio
I guess it works out I intended to.
:P
But that makes me wonder why buy the balanced unit when it has to be balanced as a rotating assy?
Is there "less" balancing with a balanced crank?
