differential question
Old Jun 12, 2007 | 12:05 PM
g.terron's Avatar
g.terron
Default differential question
hi, i have a g35 with greedytwin 6-speed manual, and i was thinking to change the diferential for the automatic diferential,i think my dif,is 3.67 and the auto in 3.33. the question is what are the benefits, the car will make more speed? for drag will be good? thanks for any help that you can give.
Old Jun 12, 2007 | 09:03 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I am planning to go with a 3.3 once the engine is built.
Old Jun 12, 2007 | 09:11 PM
Fluid1's Avatar
Fluid1
This topic has been discussed quite a few times on this forum.
The 3.3 is longer gearing. It helps because you don't 'run out' of rpms in each gear. Like if your stock MPH in 1st gear is 30, then it will be like 32-33 with the longer gears. You will have a higher top speed potential, but the lower gears do not rev up as fast.
Old Jun 13, 2007 | 04:30 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Do a search for threads started by me in this forum, I went into great detail regarding my 3.5 to 3.3 FD swap....
Old Jun 13, 2007 | 07:03 PM
g.terron's Avatar
g.terron
thanks for the info. alberto i read it and i think that i will make the change
Old Jun 14, 2007 | 04:12 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Sounds good, how much power are you running?
Old Jun 14, 2007 | 06:22 AM
g.terron's Avatar
g.terron
alberto, right know i have on 50/50 mix of 93/116, 620 whp and 708 with a shot of nos.
Old Jun 14, 2007 | 08:00 AM
Alberto's Avatar
Alberto
Cranky FI Owner
You are def a candidate for this FD. Other than running slicks or wide DR's Id imagine you couldnt hook up until 3rd, maybe 4th.
Old Jun 14, 2007 | 12:55 PM
g.terron's Avatar
g.terron
thats right iam doing drifting instead of drag jaja!
Old Jun 14, 2007 | 02:09 PM
TENGAI's Avatar
TENGAI
3.3 FD for the manual tranny is almost mandatory for anyone running FI IMO... Definitely consider getting this done at those power levels.
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
Alexreyes
Sep 30, 2015 11:30 PM
