6mt 3rd gear not worky- here's why!
Old Jun 15, 2007 | 04:12 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Originally Posted by 350zDCalb
just got off the phone with nissan
3rd gear $160
UPDATE:
I studied the diagrams and compared them to what is sitting on my workbench... the part that broke is the "3rd counter gear"
Now that is a great illustration!
maybe rebuilding with a new counter gear that has been cryoed and prayed over by monks???
Wow! Thats some "Power point" material there.
Old Jun 15, 2007 | 04:21 PM
rythex's Avatar
rythex
(dumb question.. please don't kill me), why is it 2 seperate pieces? Would it be possible to get a solid one made if that's a weak spot?
Old Jun 15, 2007 | 06:51 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
weld that **** yo!!!
Old Jun 15, 2007 | 07:50 PM
QuadCam's Avatar
QuadCam
shouldn't you be on the dyno trying to blow up AJ's car???
Old Jun 15, 2007 | 07:51 PM
Audible Mayhem
My350z
in the morning man, in the morning, blow up or hit 500 stock block. then take it and prove it on the track....
Old Jun 15, 2007 | 07:55 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
well, i will be looking into having this third counter gear reproduced in this fashion. I will fully pull this gear off tomorrow, but it does appear that nissan mates two machined pieces together and has some sort of copper seam between them... would be much stronger if it was one piece from the beginning
Old Jun 15, 2007 | 08:24 PM
Audible Mayhem
My350z
that is actually magic copper seal that is imported from east india.
Old Jun 15, 2007 | 09:13 PM
rcdash's Avatar
rcdash
no after-market/stronger gears are available?
Old Jun 15, 2007 | 09:37 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
We have made them already ,we are in the testing phase right now .
sam
GT MOTORSPORTS
Attached Thumbnails 6mt 3rd gear not worky- here's why!-mvc-674x.jpg   6mt 3rd gear not worky- here's why!-mvc-675x.jpg
Old Jun 15, 2007 | 09:58 PM
Nealoc187's Avatar
Nealoc187
The engagement tooth ring/gear is brazed to the main body of the gear with copper (in this case, sometimes they use bronze, brass, etc). Many OEMs do this as a"fuse" - breaking the gear in this fashion is better than shredding the teeth off the gear which will take out both the 3rd input gear and 3rd counter gear and likely take out other gears as well as ruin bearings, etc. This way, if it breaks, it just breaks itself and there is no other carnage.
Old Jun 15, 2007 | 10:11 PM
rocks's Avatar
rocks
Hah at least my 6th gear is going out first. 25k miles on the tranny and 6th gear grind wtf. Those gears are probably made of hardend steel. You can weld it with an arc welder and get it really really really hot.
Old Jun 15, 2007 | 11:20 PM
Nealoc187's Avatar
Nealoc187
the synchronizer wearing out has absolutely nothing to do with the strength of the gear nor the gear breaking. they are two separate and unrelated problems. All gears are made out of hardened steel, otherwise they'd wear out. getting gear steel really really hot isn't the best idea...
Old Jun 16, 2007 | 05:32 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
sam
GT MOTORSPORTS
there he is! I have called, emailed... I was hoping to here from you buddy... I assumed you must have been out of the country, you are a difficult guy to get ahold of...Can I use JUST your 3rd counter gear with the other OEM gears?
Old Jun 16, 2007 | 08:22 AM
Netko350Z's Avatar
Netko350Z
Old Jun 16, 2007 | 09:14 AM
Alberto's Avatar
Alberto
Cranky FI Owner
sam
GT MOTORSPORTS
No offense, but you've been testing since before I picked my car up in September Im losing the faith, at the same time Im not losing $$$....
Old Jun 16, 2007 | 12:12 PM
IIQuickSilverII's Avatar
IIQuickSilverII
sounds like the stroker kit took priority all that time perhaps
Old Jun 16, 2007 | 12:46 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Sorry TODD busy as usual ,I will call you shortly ,and to answer your question our gear sets was designed to accomplish two things. stronger gear and different gear ratio not to mention straight cut verses helical .
Sam
GT motorsport
Old Jun 16, 2007 | 01:04 PM
  #38
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
No offence taking.if we had seen more demand on the gear sets, we could have them available long time ago ,the gear set are on the shelf and are assembled in couple test transmissions ,they are not on the top priority list ,this does not mean that we are never going to finish up not at all, it is all based on the market demands.(steel in the testing phase sorry bert )
Sam
GT MOTORSPORTS
Old Jun 16, 2007 | 06:16 PM
  #39
350zDCalb's Avatar
350zDCalb
builtZmotors
Sam
GT motorsport
thx for the call Sam, good talking to you... when your gears are tested and released, they will definately be the best option...
Old Sep 17, 2007 | 12:52 PM
  #40
thommy's Avatar
thommy
Same s_hit with the 3rd gear here in germany.
Attached Thumbnails 6mt 3rd gear not worky- here's why!-img_0565_klein.jpg   6mt 3rd gear not worky- here's why!-img_0566_klein.jpg   6mt 3rd gear not worky- here's why!-img_0567_klein.jpg
