Finally, Jonb ATI Procharger dyno sheet @ 14psi
Old Aug 5, 2007 | 02:44 PM
  #41
stormcrow's Avatar
stormcrow
Originally Posted by booger
Im not sure . But from watching the R4 software live as the car on the dyno and the logs afterwards . The psi level would jump up and down so fast that I dont think it made a diff .
Cog belts and cog pulleys are supposed to be matched and Im sure his are . I dont see someone filing off each tooth on a cog belt .
or were you talking about the cog pulleys teeth being filed ?
the cog pulleys... i thought it very odd that this was done... and actually, it seems to have had the opposite effect of what they were trying to do... no more sharp peak, but the horizontal sides are as sharp as razors...
Old Aug 5, 2007 | 02:54 PM
  #42
booger's Avatar
booger
Is this the ATI kit that was on Trefling's car ? That Sharif had tried to tune at one time ? Im wondering how you have come to know so much about a guys car thats in Texas .
Old Aug 5, 2007 | 03:10 PM
  #43
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I dont know if its the same kit. But the OP had some military training in GA, and spent a couple or three Sat's at our shop over the course of 3 months, for various work on his car. Stormcrow has a limited social life, so he hangs out at our shop on Sat.
I havent seen a dyno plotted pressure chart from either Vortech or ATI showing a clean linear buildup to 14psi. Do you have one? Seems like the straightline linear build-up ends at about 10-12psi tops, from what I have seen.
Old Aug 5, 2007 | 03:27 PM
  #44
stormcrow's Avatar
stormcrow
shush! it's the place my car feels most at home... oh, and you're one to talk...you're as "married" as i am! neither of us can chase the hot dirties...
Old Aug 5, 2007 | 03:57 PM
  #45
booger's Avatar
booger
If I had my older laptop working I could send a dyno chart to you . I had one going to 22psi when I first put on the all cog system . I also had a bunch of Zeitronix logs and a few R4 logs .
The old laptop took a chit a couple weeks ago and Im not going to try to start it up again with out having some one here to help retrieve some stuff on it .
The only one that showed large up and down swings in psi was the r4 logs . The Zeitronix wasnt fast enough to log it , it would go up and down [ psi ] but not as large or as fast as the r4 software .
Old Aug 5, 2007 | 04:10 PM
  #46
booger's Avatar
booger
An example of what Im saying .
I was going over a r4 log when tuning the old set up [ serp pulley..slip from 5900rpm ] Every time I tried to make a change to an area of the A/F map . Nothing would happen . So I logged a run on the R4 and looked at it . Thats when I saw how much the Split Second MAP sensor was seeing different psi levels . It would jump from 13psi range up into the 14psi range . I made changes in that area and sure enough . The A/F went in the direction I wanted it to . This happened in several areas between 5900 to 7200rpm's
Old Aug 6, 2007 | 06:40 PM
  #47
Jay'Z's Avatar
Jay'Z
Talked to the dyno shop and they didnt have any boost or a/f charts.... Im thinking about going on a road trip to forged....... Damn its far......... I might just say fruck it and live with what i got.. for now......
Old Aug 6, 2007 | 07:01 PM
  #48
stormcrow's Avatar
stormcrow
uhhhh...hells naw! c'mon back... i'll let you crash at my place... then, once the problem is figured out and resolved, we'll go on a mountain run...
Old Aug 6, 2007 | 07:03 PM
  #49
Jay'Z's Avatar
Jay'Z
I know man....... I feel ****ty because I know its still not done with that ziggy *** chart past 5k.....
Old Aug 6, 2007 | 07:12 PM
  #50
stormcrow's Avatar
stormcrow
then, come on back when you get some time off... trust me, it'll be worth it...
Old Aug 6, 2007 | 07:19 PM
  #51
Jay'Z's Avatar
Jay'Z
Yea, it should be in a few weeks to a month.. Ill let you know.. Hey the thing is my belts are holding up now.. So Im sure hell get a better tune up top.. I kinda know there is more to be had on this damn setup.. I may even upgrade the intercooler.. How do you feel about that?? What else could it be??
Old Aug 6, 2007 | 07:37 PM
  #52
booger's Avatar
booger
My biggest problem of making more HP is the AT5 . But it seems to me that the more boost you try to stuff in the engine with a SC . The more gets waisted spinning the blower . The higher the boost the harder it is to spin the blower and the whp extracted from each psi gets less and less . Parasitic loss !
Old Aug 6, 2007 | 07:43 PM
  #53
sentry65's Avatar
sentry65
the burninator
I don't know how well the UR or the X02 flows, but a higher flowing setup might possibly help some
more flow would drop the psi some, make more hp and make it easier to spin the blower with less stress on the belts
or could it be possible that the blower itself is a bottleneck?
Compared to the vortech, the ATI design is smaller, even though it spins almost twice as fast
Old Aug 7, 2007 | 02:47 AM
  #54
Jay'Z's Avatar
Jay'Z
SHARIF,
I worked out a deal to come up to GA.. So if i came friday to your shop would you be able to fit me in for a tune?? Its a 14hr drive now FTL..
your PM box is full BTW sharif..
Old Aug 7, 2007 | 02:52 AM
  #55
Jay'Z's Avatar
Jay'Z
Its not the exhaust.. I just freed up a **** load of flow with this exhaust..
It could be the blower itself.. Not completely sure but I know stangs get alot more boost out of the ATI corrrrect?
Old Aug 7, 2007 | 05:27 AM
  #56
stormcrow's Avatar
stormcrow
SHARIF,
give him a ring at the shop... he should be there... also, are you talking about this friday? if so, do you need a place to crash?
Old Aug 7, 2007 | 06:10 AM
  #57
Sharif@Forged
Forged Performance
SHARIF,
sure...common down...i will squeeze you in. i just cleared my box.
Just PRAY that boost curve holds up.
Old Aug 7, 2007 | 07:26 AM
  #58
sentry65's Avatar
sentry65
the burninator
trefling got 500whp out of his ATI I think. I don't remember the psi, but surely it's possible. Could it just be really conservative timing?
Old Aug 7, 2007 | 08:55 AM
  #59
Jay'Z's Avatar
Jay'Z
I can guarantee he never got 500whp.. I have talked to him before.. He may have gotten that after he did Spray w/ SC.. Not SC alone.. Trust me..
  #60
Jay'Z's Avatar
Jay'Z
Road Trip!! Im off!!!
Side note: Stormcrow meet me at the crossroads on friday.. Early.. I know you dont wake up till after 1pm but ill be there before that.. lol..
