Ballistic Built Motor, Greddy TT, 5AT Dyno Numbers
Old Aug 9, 2007 | 06:37 AM
rcdash's Avatar
rcdash
Would love to see pics of where they inserted the new injectors... upper plenum or lower plenum? Very cool idea!
Old Aug 9, 2007 | 06:41 AM
doug's Avatar
doug
https://my350z.com/forum/forced-induction/289453-secondary-injection-w-eu-greddy-tt.html
Old Aug 9, 2007 | 06:42 AM
617G's Avatar
617G
we did indeed check each bank for differences, however, if the air flow to the cylinders is unequal (unlikely as they are well designed) then the fuel flow will be equally unequal producing a balanced air fuel ratio for the cylinder. FI engines use secondary injection and actually mount the injector before the throttle bodies so the air has more time to mix.
The injectors were mounted at the top of the manifold against the air flow allowing the fuel to atomize before reaching the cylinders.
Attached Thumbnails Ballistic Built Motor, Greddy TT, 5AT Dyno Numbers-second1.jpg   Ballistic Built Motor, Greddy TT, 5AT Dyno Numbers-second2.jpg
Old Aug 9, 2007 | 06:43 AM
rcdash's Avatar
rcdash
Very cool indeed - thanks. The rear cylinders in an unmodified plenum setup do run a bit hotter (leaner) I believe due to the plenum shape. Probably not significant and like you said accounted for based on where the fuel is injected.
Old Aug 9, 2007 | 07:22 AM
roncfpz's Avatar
roncfpz
Congrats and good luck with the 5AT.
Old Aug 9, 2007 | 07:23 AM
617G's Avatar
617G
I'm waiting on the results of your tranny build
Old Aug 9, 2007 | 07:28 AM
doug's Avatar
doug
you mean long term results? because his tranny is already in
roncfpz's Avatar
roncfpz
Here you go.
https://my350z.com/forum/forced-induction/290809-forged-performance-sgp-built-5at-greddy-tt-f-con-vpro-504whp-16psi.html
So far so good.
Old Aug 9, 2007 | 07:42 AM
617G's Avatar
617G
thanks
sales@czp
Sep 23, 2019 03:30 PM
