Official STS Rear Mount Turbo Discussion Thread
Old Nov 3, 2009 | 05:13 PM
  #2161
rips350z's Avatar
rips350z
Originally Posted by athenG
If you want your motor to last then you need a tune!! You can just use someone's map and expect it will yield the same result. The turbo size shouldn't matter that much since boost is boost. How your car react on that boost is the difference so you really need a dyno to tune the ignition. Do you have a wideband? What EMS are you using? If you are brave then you can always make adjustment on the fuel but I wouldn't touch the ignition unless you know what you are doing and have access to a dyno.
yes im using innovate lc-1 wideband, with utec EMS, also im having trouble with my lc-1 to my acuatal gauge the db-red... it ****ing stays blinking at 7.4 then jumps all over the place, maxx ive seen it was around 21.8, but i dont believe its right
Old Nov 3, 2009 | 05:28 PM
  #2162
athenG's Avatar
athenG
Do you have any basic knowledge in tuning? Download the Utec manual and read that thing 10x. Do a lot of reading and as long as you get a good base map then you should be able to at least make minor adjustment on the fuel.
Old Nov 3, 2009 | 05:31 PM
  #2163
rips350z's Avatar
rips350z
o ya ive done that and my buddie is good with it
Old Nov 4, 2009 | 07:25 AM
  #2164
1GR8350Z's Avatar
1GR8350Z
The stumbling going into boost on mine turned out to be the MAF. Also found a small boost leak
Old Nov 4, 2009 | 09:02 AM
  #2165
athenG's Avatar
athenG
Do you have Utec and running speed density?
Old Nov 4, 2009 | 10:27 AM
  #2166
1GR8350Z's Avatar
1GR8350Z
Yes.
Old Nov 8, 2009 | 12:59 PM
  #2167
JonnyC's Avatar
JonnyC
Just an FYI, the heat shield bolt that the turbo intake bracket bolts to is very week. I had a real bad rattle for a month or so and finally took some time to look underneath. The bolt which is welded into the floor of the trunk broke off which caused the heat shield to rattle against the floor of the trunk. I ended up just running a stainless bolt from the trunk down through and it's real solid again.
Old Nov 8, 2009 | 04:43 PM
  #2168
GBoger's Avatar
GBoger
I may have suggested that a while back
Old Nov 10, 2009 | 08:12 AM
  #2169
JonnyC's Avatar
JonnyC
Oh, haha. This thread is just too huge to really keep track of all of the suggestions
Old Nov 10, 2009 | 12:56 PM
  #2170
1GR8350Z's Avatar
1GR8350Z
Your not kidding. I know the answers are in here, but it gets frustrating trying to find them
Old Nov 12, 2009 | 01:33 AM
  #2171
rkd350z's Avatar
rkd350z
looks like it will have better F/R weight distribution with this kit!
Old Nov 12, 2009 | 05:29 AM
  #2172
Boozt's Avatar
Boozt
Ok boys...I'm jumping into the Uprev/Osiris pool late Nov......I want to switch to a EBC from my MBC......What is working best with our kit???? The plan is to run different maps at various boost levels and at least one for race fuel. Thanks.
Old Nov 12, 2009 | 05:37 AM
  #2173
goosegoose's Avatar
goosegoose
I use the Blitz SBC i-D Dual Solenoid controller. Others have used the HKS EVC model. All have had good results.
Old Nov 12, 2009 | 06:21 AM
  #2174
athenG's Avatar
athenG
EVC6 has speed/gear dependent boost control.
Old Dec 4, 2009 | 11:58 AM
  #2175
GBoger's Avatar
GBoger
apexi avc-r has rpm dependent boost control which i find works best for this kit since you can set the wastegate to be 99% open in the early rpm range. It made a significant noticeable difference in spool up time and responsiveness
Old Dec 4, 2009 | 01:08 PM
  #2176
athenG's Avatar
athenG
Yes, Daniel had the AVC-R and that helped him hit full boost on 1st gear. How was the install?
Old Dec 4, 2009 | 02:10 PM
  #2177
1GR8350Z's Avatar
1GR8350Z
Are there any negatives that go with the AVC-R install because that sounds great being able to build full boost in first gear.
Old Dec 4, 2009 | 02:34 PM
  #2178
GBoger's Avatar
GBoger
only tricky part of the install was getting the speed signal hooked up right.
Old Dec 7, 2009 | 09:19 AM
  #2179
Boozt's Avatar
Boozt
I ended up with the AEM tru-boost.....its a guage and controller all in one. Very happy with it so far.....Osiris is next.
Old Jan 5, 2010 | 09:16 PM
  #2180
2004Black350z's Avatar
2004Black350z
Exhaust Whore
sold my APS ST a few months ago for personal reasons. However Just came across BNIB STS for very good money. I already know the opinions of Daniel and Bobby at CIN since they back this turbo kit and i def trust Bobbys opinion. So to the OGs that have had STS installed for a while whats ur thoughts? still happy?
