Official STS Rear Mount Turbo Discussion Thread
Old Jul 6, 2010 | 06:44 AM
  #2421
athenG's Avatar
athenG
Originally Posted by rawley_12003
yeah i was told they didn't need a turbo timer well the z comes with oil pressure and volt gauges so i will get a a/f gauge and boost gauge. can the z run on stock fuel pump and injectors just asking cuz i haven't ordered the it yet but will be on the way very soon
Yes if you dont plan on hitting boost.. More air = more fuel. You need a minimum of 440cc and a fuel pump.
Old Jul 12, 2010 | 06:34 PM
  #2422
pinoyz33's Avatar
pinoyz33
Just wanted to drop in and say whats up. I've owned my sts for about a month now that i purchased from JonnyC and Im enjoying it.
Old Jul 12, 2010 | 07:15 PM
  #2423
athenG's Avatar
athenG
How much boost are you running? If you eat Balot it will feel much faster.. lol just hit me up if you have any question Pare ko
Old Jul 13, 2010 | 09:41 PM
  #2424
rawley_12003's Avatar
rawley_12003
yeah i will soon be a sts kit owner as well in a couple of days buying mine from goosegoose really great guy on the phone and awesome upgraded turbo and intercooler. oh would i need a return fuel system with this application just asking and what other things would you guys recommend athensg or anybody can chime in other than gauges and alot of exhaust wraps lol.
Old Jul 14, 2010 | 06:09 AM
  #2425
athenG's Avatar
athenG
You dont need a return fuel system if you are on stock block. Depend on the power level... just get the kit for now and upgrade down the road.
Old Jul 14, 2010 | 05:48 PM
  #2426
rawley_12003
cool man thanks i will do that
Old Jul 15, 2010 | 07:45 PM
  #2427
pinoyz33's Avatar
pinoyz33
Lol! Im running it 5psi. Mabuhy
Old Jul 16, 2010 | 05:45 AM
  #2428
athenG's Avatar
athenG
/\ go bring it up to 7-8psi and the car will be alive.
Old Jul 23, 2010 | 11:08 AM
  #2429
goosegoose's Avatar
goosegoose
I wanted to give you guys a heads-up on a sale I just posted. Brand new Motordyne Engineering ART pipes. These should work really well in any STS kit. Click here if your'e interested.
Old Aug 1, 2010 | 06:35 PM
  #2430
rawley_12003
wow man that turbo is huge what psi do you suggest for the engine goosegoose?
Old Aug 2, 2010 | 04:24 AM
  #2431
goosegoose's Avatar
goosegoose
Rawley,
Please start at the typical levels STS recommends for their stock kit. After all, you currently have a stock engine, and too much PSI won't be good. I think STS recommends 5 PSI to start with. Call them up and double check to be sure. Also, please don't forget to change out the wastegate spring to the original one I included in the separate box. If you forget to change the spring, the wastegate won't allow you to boost any lower than 10psi. I hope this helps!
Old Aug 3, 2010 | 02:01 AM
  #2432
rawley_12003
ok goosegoose i talke to sts and they said they would recommend that i run at like 4 psi cuz the size of the turbo, they said that should easily get me around 400hp.
Old Aug 3, 2010 | 05:49 AM
  #2433
athenG's Avatar
athenG
That is bull!! Look at the Mid-mount kit because I think they are using the same turbo as Goosegoose and they are not hitting 400whp at 4psi. I think they hit around 400 at 8 psi. You can get a .3 bar spring and that will give you around 4.3psi as your lowest boost but if you are planning to use the turbo as your WG reference then get the .4 spring because there are about 2-3psi drop from the piping.
Old Aug 3, 2010 | 03:04 PM
  #2434
GBoger's Avatar
GBoger
run 7 psi on that turbo and call it a day
Old Aug 5, 2010 | 05:56 AM
  #2435
rawley_12003
i was thinking around 5 to 7 psi huh i still have to get my strup headers coated and all my piping wrapped i hope my jwt clutch and flywheel will hold the horsepower
Old Aug 5, 2010 | 06:22 AM
  #2436
str8dum1's Avatar
str8dum1
the stock clutch will hold that power
Old Aug 5, 2010 | 06:36 AM
  #2437
rawley_12003
i still have the stock clutch but had changed it out to a jwt and aluminum flywheel 6 months ago and haven't regret it since lol... i still need to buy gauges but not sure which to buy any suggestions guys on brand type, i need a/f, boost and fuel press. same brand if possible or would look good.
Old Aug 5, 2010 | 06:56 PM
  #2438
TegraRacer134's Avatar
TegraRacer134
I havent been on here in a really long time good to see people still buying this kit. I really miss my Z. Once I get some more money ill buy another and put a STS kit on it. Its reliable and sounds incredible. Rawley if you can afford defi they are badass. I had fuel pressure boost and EGT in my car you can use EGT as a wideband if you know how to read it correctly
Old Aug 16, 2010 | 06:23 AM
  #2439
dbrown's Avatar
dbrown
Now they want 5900 for the kit!!!
Old Aug 16, 2010 | 07:46 PM
  #2440
rawley_12003
wow i'm glad i got mine when i did thanks goosegoose for the great deal.
