Creating an FI Budget.........
Old Aug 16, 2007 | 04:35 PM
Jes-Z's Avatar
Jes-Z
Default Creating an FI Budget.........
So I'm going to set up a budget for FI. Before I get started, I'm going to tell you I looked at the Stickies at the top of the FI section.
My goals are:
A very reliable setup of close up to or no more than 400HP @ maximum boost on a stock block.
I occasionally go to open track days @ Homestead Motor Speed Way and want to be able to get the most out of my car. I believe a good single setup will give me the edge I'm looking for.
As for my brakes, I have a stoptech Stage 2 upgrade for now. I'm planning on a BBK, that's why I'm trying to budget for FI like this. I want good brakes and a reliable Turbo setup that is cost effective.
I'm going to step up the car gradually. Eventually, in the distant future, I'd like to build up the internals. But, my car is not a daily driver and my budget is somewhat limited. I'm not broke, but I'm also not ready to spend 15-20K on my engine alone.
My idea:
A used single turbo setup (APS or TN). 3K-3500K
Engine Management (Utec)- 900
Injectors- 300-400
Fuel Return- 1K
Walbro-300 ( I think)
Oil Spacer - 100
BOV- 250 ( i would like the HKS Sequential)
Install- 1500-2000K
Gauges- 500-750 (With pillar
This puts me @ Close to 8500-9K.
Are my estimates correct and is my parts list accurate?
What are some recommendations from current FI owners?
Thanks guys.
Old Aug 16, 2007 | 05:08 PM
rcdash's Avatar
rcdash
oil spacers or a deeper oil pan usually come with a kit. add a few hundred for the return fuel system install. walbro is only 100. high impedance injectors (for use w/ UTEC) will be around 600 for new ones. utec + tuner (wideband) will run closer to 1100-1200. I'd check out the Greddy "staged" packages that Sharif@Forged offers for a better package deal that'll come very close I think to your used kit total.
https://my350z.com/forum/engine/270261-greddy-tt-stage-packages-you-asked-here-it-is.html
Old Aug 16, 2007 | 05:11 PM
Jay'Z's Avatar
Jay'Z
Dont forget a boost controller.... Whats up wit yo clutch?? Staying stock??
Old Aug 16, 2007 | 05:12 PM
rcdash's Avatar
rcdash
you can use utec to control boost with the dtec boost controller $100
Old Aug 16, 2007 | 05:15 PM
Ten to Four Z's Avatar
Ten to Four Z
Thumbs up
Hey, looks good so far.
You’re going to need a Clutch. I recommend the JWT Clutch and not to get a Lighted Flywheel.
And if you need injectors, I have a set of 440cc, never installed and for a lot less than $300-$400 (their at Factory Performance. I'm picking them up when I get my car this Sunday.)
Since you live in Florida, try giving Performance Factory a call. They can get you EVERYTHING on your List (maybe not the used Turbo Kit) and GREAT PRICES!!!
Here Take a Look At This Craziness= https://my350z.com/forum/showthread.php?t=294120
Old Aug 16, 2007 | 05:17 PM
doug's Avatar
doug
My goals are:
My idea:
Injectors- 300-400
Fuel Return- 1K
Oil Spacer - 100
Install- 1500-2000K
Thanks guys.
got any pics of you?
Old Aug 16, 2007 | 05:19 PM
Jes-Z's Avatar
Jes-Z
Why?
Old Aug 16, 2007 | 05:21 PM
doug's Avatar
doug
Why?
wanted to see if them Tig O Bittys are really for the win
Old Aug 16, 2007 | 05:22 PM
Jes-Z's Avatar
Jes-Z
If you wana see Man *******................. Jesse is my nickname. It's alot easier to deal with than my real name "jesus".
Old Aug 16, 2007 | 05:23 PM
doug's Avatar
doug
no i'll pass... damn i got caught on that one i am going in the shower to wash myself with disinfectant
Old Aug 16, 2007 | 05:24 PM
Jes-Z's Avatar
Jes-Z
Clutch and Flywheel Definetly going with JWT. But why not Lightweight?
PF will be doing the install of course Jeremy is awesome. Plus he's the closest to me.
Old Aug 16, 2007 | 05:34 PM
Ten to Four Z
On an N/A car a lightened flywheel would be great or if you are going to track the car.
A heavier or stock flywheel would not only be easier to drive daily but in-between shift the RPMs don't drop as fast. Keeps the boost and RPMs higher during shifts, Very popular with the supra crowd.
Old Aug 16, 2007 | 05:39 PM
phunk's Avatar
phunk
CJ Motorsports
for 400 hp on a budget, i would consider maybe a supercharger?
Old Aug 16, 2007 | 05:41 PM
Jay'Z's Avatar
Jay'Z
U no like ST??
Old Aug 16, 2007 | 05:49 PM
Jes-Z's Avatar
Jes-Z
I'm sort of biased. Not to mention you almost need a stage 3 or 4 kit to reach 400HP. At least from what I've seen. Don't quote me. I'm probably wrong.
Old Aug 16, 2007 | 05:56 PM
Jay'Z's Avatar
Jay'Z
Your only talking Stillen when you say stage 4.. Vortech and ATI put out some decent numbers 400+ with only upgraded pulleys and some other fuel additions..
Old Aug 16, 2007 | 06:11 PM
Cube's Avatar
Cube
Of all those things you listed, why not start off with a BRAND NEW STS rear mount for $5500, which includes most of the crap you're talking about and is an easier install
Old Aug 16, 2007 | 06:14 PM
Jes-Z's Avatar
Jes-Z
i never thought of that. my only worry is that the roads in miami suck. speed bumps everywhere and ditches. i'd be afraid of hitting something.
Old Aug 16, 2007 | 06:15 PM
Jay'Z's Avatar
Jay'Z
Old Aug 16, 2007 | 06:17 PM
Amiricanmade's Avatar
Amiricanmade
becuase it would come out cheaper? or becuase 400hp is not worth turbo?
Also Jes-Z do you mean 400whp?
