APS TT Smoke under WOT
Old Jun 10, 2008 | 09:07 AM
  #61
BrianLG35C's Avatar
BrianLG35C
Originally Posted by al_v
The "L" mark on the dipstick or lower is the correct oil amount.I always use a little lower the "L" mark.
If you have forged pistons, the crankcase ventilation during boost is very afected , I needed and oil catch can to solve my problem after built the engine.
I do have a built motor with the APS TT kit, so it's recommended to get an oil catch can?
Old Jun 10, 2008 | 09:16 AM
  #62
wannabuy350z's Avatar
wannabuy350z
^of course, there will always be some oil in the piping, its recommened because your FMIC wont get oil in there, and it wont enter your combusion and cause pinging
Old Jun 10, 2008 | 11:34 AM
  #63
al_v's Avatar
al_v
I had smoke problems after my built.
You need to reduce the crankcase pressure installing a catch can , the right side of the engine doesn´t have any vent , so you need to vent that side , otherwise you will have smoke.
Old Jun 14, 2008 | 06:02 PM
  #64
IslandZavage's Avatar
IslandZavage
UPDATE:
I followed the DIY oil catch can, and it works. The car is no longer smoking and its back to normal. I tested it with some spirited driving and popped the hood and there was oil in the catch can that would of made it too my plenum. I wish i did this at first. car is running normal. Thanks everyone for the advice, i really appreciate it.
Old May 8, 2010 | 10:21 AM
  #65
djtimodj's Avatar
djtimodj
Sorry to bump an old thread but my built APS TT is smoking a little under boost. Blue ish smoke so oil i hope. Can some one explain why people are only filling the oil to the L mark on the dip stick with the APS TT's?? I have custom oil returns into the upper oil pan and put 6.1L in the car last oil change a week ago. The cars running around 3/4 on the OEM dip stick.
Thanks.
Old May 10, 2010 | 05:08 AM
  #66
rcdash's Avatar
rcdash
Thanks.
They run to "L" to minimize smoking due to increased restriction in the return lines from running a high oil level (supposedly). In any case, since you have custom return lines, that should be a non-issue. You could be smoking because your return lines are not continually sloping downwards or because you are not venting crankcase pressure well enough or because your intake is sucking up oil while venting the crankcase because there is no catch can in between.
Old May 10, 2010 | 05:19 AM
  #67
captj3's Avatar
captj3
You should only have 5.5 to 5.75 qts of oil with the aps oil pan. 6.1L is to much oil that converts to 6.45 quarts of oil. You don't have enough room for the oil to return and it is backing up through the seals of the turbos.
bcoffee20
Nov 19, 2015 06:39 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
foxsmp26
Sep 25, 2015 09:48 AM
Bigsyke
Sep 11, 2015 06:19 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
