The drag race the entire community has been waiting for!!
Originally Posted by bigslim350Z
UTEC isn't good for high boost? I remember hearing Dave talk about something called Autronic? Perhaps that could be an alternative? After seeing your drag racing runs, I couldn't imagine what you would be like at around 22 psi. It would be crazy. Maybe you could try to work with those programs that allow you to apply certain boost to each gear or something like that.
maybe something like 5 psi 1st gear, 9 psi. 2nd gear, full boost 3rd gear and on, or something like that.
Originally Posted by Alberto
These slicks are capable of hooking me up, I was not warming them up enough and launching wayyy to aggressively. I dont like the part throttle the UTEC provides at 13+ psi, it hiccups slightly more than it did when I was tuned @ 9psi. WOT its fine...
definitely looks like you are launching way too hard. when you were launching in your ST days it looked alot less aggressive. but like you said, the slicks should have no problems holding for you. I've seen people use MT ET streets and do 9.60's on 10" wide slicks.
Philthy, I dont know when you started thinking you were good at drag racing-especially to make a comment like that to me...I posted the video so people wouldnt know that I was lying or backing out for no reason. The possibility of losing-like I had with Sharif, Luie, Joe, and Julian only pumps me up more for a run, it doesnt make me back down
If you cant understand that I want the car to be 100% for MY OWN personal standards then that says alot about you. I dont get satisfaction out of running a built car on street tires and running 12's with 500+whp-thats just stupid, who shows up to a gun fight with a knife? I do it one time, I do it right.
Don't start crying Alberto - just having some fun and I could care less if I win or lose, I DO THIS FOR FUN! Either way, I will race you and couldn't care less about ego...
I was more than happy with my times, and based on your vids, they look a bit better than your runs on SLICKS!
could you shift gears while you are doing your burnout (do you have "roll control"?) most of my friends when they heat their tires up are doing burnouts through their top gear. probably your equivalent of 3rd or 4th? (spinning them at over 100 mph)
Originally Posted by dutchboy350Z
What were you trapping on your runs?
I had a total of three runs with the car, 12.9 (first run) 12.6 (second run) & 12.3 (third run), definitely would have been in the 11's with another run or two - my traps were ~120mph. I was on street tires, track wasn't prepped and it was pretty fun spinning them down the track, I had a BLAST! I was at 15psi, 460whp DD...
IIRC you ran low 12's? You def got beat with me off the gas about 4X-but whatever floats your boat
I do it for fun, but there is a big difference between me and you. I race my car HARD, so it is not worth my time or $$$ to run my car unless its for a good time and going 100%. I could spin down the track on street tires and run 12's all day long AND not break but what fun is that? Different strokes for different folks...
If you did this for fun, you wouldn't be sooo UP TIGHT and SCARED of losing!
OK Alberto, you win, stop crying now!
I usually do them in 2nd gear, but have trouble holding the car straight right outside the water box in 2nd. I can do 1st gear all day at redline but its not fast enough to REALLY heat them up. Next time, I'll have a much more conservative approach and work up, instead of going all out off the bat.
(2nd gear means you are spinning around 60 mph or so?) i was doing 2nd gear burnouts in my drag radials, still wasn't enough to smoke them and get them hot enough to hold traction.
Philthy-I know thats what your doing-working on my axles today, hopefully its an easy fix
David-I know of a shop that was gonna do line locks but I havent check in with them, it is an option, but I dont drag race all that much you know...
Good thing you know I'm only playing, I really thought you were getting mad
I have my stock axles if you want them $75...
And why so low power at 15psi? Sharif tuned you or did Julian,.
Couldnt resist taking a shot at me huh? Youll see my tuning skills on the 21st.
LOL-I guess you tuned it? Correct me if Im wrong but didnt Sharif tune it? I know he's from Jersey so then I doubted myself...no ill will here
..Phil hates me.
No sharif tuned it, thats why Phil got beat so bad
..Phil hates me.
..Phil hates me.
Yeah, my cars very weak
- so let's race
