It's done! ~~MoTeC M800~~ running on my car *pics*videos*
Old Sep 27, 2007 | 05:13 PM
  #41
Resolute's Avatar
Resolute
I'm impressed. Nice job, Gurgen. I'm sure your dyno tuning will be as spot-on as your seemingly meticulous nature demands. I'm jealous, LOL.
Will
Old Sep 28, 2007 | 05:49 AM
  #42
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Originally Posted by kuah@splparts.com
I just use it for tuning, it is not wired to the Motec. AFAIK the HKS knock amp has no outputs that can be used for the Motec that way, but I have not seen the new unit in person.
HKS knock amp puts out a 0-5v, actually it can be a good tool for that. If the knosense MS doesn't work out too well, I will get the new knockamp and mess with it. We'll see.
Old Sep 28, 2007 | 05:53 AM
  #43
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Originally Posted by rcdash
Gurgen,
In regards to the knock detection - I am unclear on the external device you pictured. Is that a standalone DSP unit that receives input from the stock knock sensor, deciphers what is noise and what is true knock and then sends the signal for true knock to the MoTeC?
I didn't see a "knock amp" that you listed as your purchases or in Sam's list of available products. What is that little box?
Also if I missed it you got a version of the 800 - not the 880, right? Looks like all the "upgrades" are for the 880 (telemetry, more memory, more injector drivers, etc)...
Very interested in this for the future for a complete carPC integration project...
This is the KnockSense MS unit, ms=megasquirt... i.e. the unit has a 5v out logic when knock occurs. It's only $65, and is essentially a filter,, like the knockamp, wihtout the fancy circuitry. But, we do not indeed kow how well it works. THis is not the only unit I am counting on, as there will be some other tools for listening ot knock (this is curtesy of Tony of Motordyne and Clint (thx723).
We'll see how well it works, but I have to run now, and will hit you guys back up soon.
Old Sep 28, 2007 | 07:55 AM
  #44
GlenRoseFireFighter's Avatar
GlenRoseFireFighter
Clint! What's up man? It's like old times...Clint, Randy and Gurg all in the same thread. I might be getting back into the scene again. We'll see.
Old Sep 28, 2007 | 06:05 PM
  #45
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Will
Thanks Will
Much appreciated. Should be a huge education experience, and I hope my hours of preparation will help in smoothing thigns over. There is always that X factor though, so you never know.
Old Sep 28, 2007 | 06:07 PM
  #46
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Randy
Holy smokes buddy, long time no talk/see. Hope things are well. Clint and I thought of you just hte other day when we were at lunch.... Good times, it was bad for us that you left Cali for greener pastures...
Stay in touch...
Old Sep 28, 2007 | 06:25 PM
  #47
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Nice work! But regarding this knock unit, I have tried interfacing that unit with my Motec M600 with limited success. It is sensitive to high rpm noise, and to calibrate it you need to adjust the **** till it triggers on actual knock. And the trigger is just on/off, I had asked for a voltage output that scales with knock severity but was told it was not possible. So at best you can use it to trigger a fixed ignition retard on knock, which might be good for a failsafe device, but I have not found it useful for actual tuning (personally I use a older gen HKS knock amp w/ headphones).
Thanks...
On the knock unit, there is more to the story.
The KnockSenseMS puts out a square 5V tall signal, so yes, on first glance, it's an on-off signal with no knock intensity information.
But...... if oyu talk to the inventor (Boris), he will tell you that hte knock intensity is conveyed by the duration of the 5v signal, which last a minimum of 20ms for a single knock event, to 200ms for high knock levels. Guess what, Motec can be configured (and IS on my unit) to read the pulsewidth of a given signal (not duty cycle but actual low or high pulse)...on dig 1-4 channels. So, this on my ecu is configred for 0-100% knock intensity on one of the custom user channels, which is then later used as the x-axis for knock correction (in the appopriate custom table)... Voila.... The only thign that remains is proper configuration of the bypass.... and not sure if you knew, but you can change the capacitors on the board to further narrow the signal... This is just for failsafe purposes, we are going to be using something far more trick for tuning... stay tuned.
Old Sep 29, 2007 | 08:48 PM
  #48
THX723's Avatar
THX723
RANDY!!! Good hearing from ya ... hope all is well.
Old Sep 30, 2007 | 10:31 AM
  #49
AlcatrazT2's Avatar
AlcatrazT2
Congrats Gurgen!
Now, give me a lift in that beast...
Old Sep 30, 2007 | 11:03 AM
  #50
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Originally Posted by AlcatrazT2
Congrats Gurgen!
Thanks....you got it, call me up.
Old Oct 3, 2007 | 02:50 PM
  #51
Apex Speed Tech's Avatar
Apex Speed Tech
Default Props to Gurgen
We really have enjoyed working with Gurgen on this project. He's a quick learner and has taught us a few things! Gurgen's attention to detail and analytical approach has made his the ideal kind of customer to work with and we're stoked that this is all going so well. We're glad to be his MOTEC dealer.
Old Oct 3, 2007 | 05:03 PM
  #52
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Neel,
Thanks very much for the very kind words. It's priceless to have the support of someone with your level of sophistication and experience in engine management (and engine mechanicals in general). Just want you to know that I truly appreciate it. I can't wait to tune the car in the next few days, and finally get to play with the real toys to realize my goal of having the best-tuned car that is humanly possible. Thanks again, and have fun in Montreal, will see you when you get back (don't work too hard).
Old Oct 3, 2007 | 05:10 PM
  #53
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I will post some more pictures/videos/technical information very soon guys, stay tuned.
Old Oct 3, 2007 | 05:35 PM
  #54
Shabib67's Avatar
Shabib67
Any tweaking with the traction control?
Old Oct 3, 2007 | 05:42 PM
  #55
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Not yet, but that's certainly planned for after the car is tuned.
Old Oct 3, 2007 | 05:57 PM
  #56
Shabib67's Avatar
Shabib67
Awesome hopefully you get that thing tuned soon. If the traction control is really does a good job and actually helping put power to the ground and making tcs/vdc a tool rather than an interfrence than the extra money for the Motec is well worth it over the F-Con. Also controlling the VTC is a huge plus!
Old Oct 3, 2007 | 06:08 PM
  #57
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I'd love to see some more pics of the EMS unit installed.
Looking at your pics, with that autosport harness, reminds me of the pain and agony it took to get my stupid a$$ greddy EU to work...
in any case, big props for trying something new. That is my kind of project!!
Old Oct 17, 2007 | 11:11 AM
  #58
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I'll post some pics soon, now that I am prepared to remove the fcon completely.
A quick update:
Will be tunign the car this Saturday, will keep all posted with a detailed write-up of our findings. Clint and I were messing with the Lmabda control settigns, and idle fueling/compensation tables.... and I gotta say, with GTm cams (which granted are very good at idle) we got hte car to idle INCREDIBLY smoothly... .I do not recall my car being this smooth except when it was BONE STOCK and NA. Unbelievable. I love the MoTeC!
Huge thanks to Clint (THX723), you are the man, buddy!
Old Nov 16, 2007 | 02:03 PM
  #59
Slick 6MT's Avatar
Slick 6MT
Any updates?
Old Nov 16, 2007 | 03:23 PM
  #60
THX723's Avatar
THX723
Yes quite a bit actually. Out of respect, I will let you all hear it from the horse's mouth, so you'll just have to wait.
