Replacement Oil feed line for Greddy Turbo kit
Hey Guys, Just tried the search. Thought I would find more than I did. I can't find any info on replacement oil lines for the greddy kit. I see they are 1/8 BSPT, and I'd rather not order another crappy line from greddy. Can anyone point me in the right direction? Thanks!
if your want to change the lines, I would suggest changing all of the other fitting while you are at it. Change everyting to NPT an -AN fittings. You can get those kinds of fittings and lines anywhere in the US. SummitRacing.com will be your friend.
Well, Everything is BSPT already I believe. I could install a BSPT to -4AN adapter and then t-off and run premade -4an line to the turbos. But then I would need -4AN banjos. I'm gonna hit DSS in the morning and see what they have in stock. I'm pretty poor right now.
What oil return pan are you using. I opted for the AAM oil pan spacer to replace the lame oil pan supplied with the Greddy kit. Then i purchased the AAM Stainless Steel Oil Return Lines to replace the rubber hoses provided with the Greddy kit. I just didn't want to chance anything melting or coming loose. I have had it with oil leaks. At least these lines are secure. They also look pretty cool too. Overall it was a good decision. Your call though. Good Luck.
Edit.
OOOOOpps. I thought you meant oil return lines...Disregard.
Edit.
ETX...man I havent seen you post in ages. Yeah, we got sick of the brittle Greddy stock oil lines, that tend to leak/crack after a lot of usage, so we just made our own high pressure line upgrade kits. Call the shop tomorrow, and I can send you a set with the proper fittings and adaptors to make it all work.
custom your order with this guy. $39 shipped with quality parts. Just know your sizes and the length of the line and they'll put it together for you.
http://fast-turbo.com/
Sometimes, though, for the "lazy'er" individuals its often easier to just order a pre-fab kit that you know will fit, rather than taking chances on wrong size AN fittings, or too short of a hose, etc.... Like the ones sold at AAM for the Greddy oil return lines, or the high flow feed lines Sharif is coming out with...They work very well and you have no worries about fitment.
Originally Posted by rrmedicx
Wow, That's a pretty neat site.^^^ Lots of custom set-ups possible for a variety of lines. Good Find.
mkae sure you have the tools to cut the SS lines cleanly.
My AAM oil return lines were about 8" too long.
mkae sure you have the tools to cut the SS lines cleanly.Thread
liqalu04
Jan 2, 2022 12:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
