how much boost?
Old Oct 21, 2007 | 12:16 PM
Try&keepup's Avatar
Try&keepup
Default how much boost?
How much boost do you think a stock block with eagle rods and weisco pistons can handle? I'm just trying to get an idea as to whether i should go with a supercharger or a turbo. I also planned on adding an oil pan spacer.
Old Oct 21, 2007 | 12:25 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i would say 600-700...
Old Oct 21, 2007 | 12:29 PM
Try&keepup's Avatar
Try&keepup
Sweet 700 pounds of boost. What size injectors would i need?
Old Oct 21, 2007 | 12:42 PM
Zridder19's Avatar
Zridder19
500000000000.9 cc
Old Oct 21, 2007 | 12:43 PM
Zilvia's Avatar
Zilvia
search.........
have a lovely day look forward to your build
Old Oct 21, 2007 | 12:46 PM
Audible Mayhem
My350z
yeah 600-700 psi is what i meant, you will need stock injectors with a 600 to 1 ratio FMU. that will work..
Old Oct 21, 2007 | 12:47 PM
teh215's Avatar
teh215
LOL.
Old Oct 21, 2007 | 12:53 PM
Try&keepup's Avatar
Try&keepup
i searched but i didn't find a definitive answer, so i was wondering if any of you pros knew anyone with this setup and what they were runnin.
Old Oct 21, 2007 | 12:54 PM
bacalhau16's Avatar
bacalhau16
WTF! There is so many cool threads in this forum, that you will learn so much, then there are those like this, that just make you that much stupider! < See what I mean!
Old Oct 21, 2007 | 12:56 PM
rcdash's Avatar
rcdash
LOL. In all seriousness, 15-18 psi is the generally accepted limit for 93 octane fuel on the stock block, generating power in the hp range audible provided in his first response. Eagle H-beam rod hp rating for Nissan applications attached.
Old Oct 21, 2007 | 01:20 PM
Cube's Avatar
Cube
Originally Posted by Zridder19
500000000000.9 cc
That's FIVE HUNDRED BILLION point nine!!!
Cube's Avatar
Cube
So 1500 HP?
Old Oct 21, 2007 | 01:22 PM
Zilvia's Avatar
Zilvia
with a built bottom end (pistons and rods), some new APR studs and metal head gaskets
you can prolly hold 15-18psi.....depending
Old Oct 21, 2007 | 03:48 PM
rcdash's Avatar
rcdash
Originally Posted by Cube
So 1500 HP?
That's what Eagle claims - I snipped that out of their web page. For domestics that envelope may have been tested. I have not heard of an aftermarket rod failure yet for the VQ35, so...
Old Oct 21, 2007 | 06:29 PM
bacalhau16's Avatar
bacalhau16
Stop giving foolish information. This thread should be locked. 15-18psi on 93 octane? With what turbo? Where are you getting that from? So with a 60-1 or a T78 I will be able to run 15-18psi no problem on 93. Just stop that!
Old Oct 21, 2007 | 06:33 PM
Try&keepup's Avatar
Try&keepup
I think this thread was a mistake I'll just call an engine shop.
/thread
Old Oct 21, 2007 | 06:34 PM
bacalhau16's Avatar
bacalhau16
I agree, thanks!
Old Oct 21, 2007 | 06:35 PM
rcdash's Avatar
rcdash
With Greddy 18G turbos. Two of them:
https://my350z.com/forum/forced-induction/303889-601whp-603trq-at-18psi.html
Not sure why you are so agitated.
Yes, you obviously can run 15-18 psi boost at 93 octane on a built short block and there are so many examples of this. Jeez.
Old Oct 21, 2007 | 06:44 PM
Zivman's Avatar
Zivman
https://my350z.com/forum/showthread.php?t=303889
bacalhau16 relax....
I agree with rcdash. 15-18 psi is a good reference. When questions like this are asked, there is an assumption that we are generalizing. Thus we are referring to common kits such as the greddy, APS, jwt, etc. And as stated, 15-18 psi covers those kits. Personally I would stick to 15-16 psi on pump and if you plan on going any further, I would recommend 100+ octane
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
