Dyno Dynamics to Dyno Jet comparison..
Old Nov 1, 2007 | 05:56 AM
  #121
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by MRC Motorsports
I dont think Berto was knocking your tuner at all, nor did he mean it that way. It just safer to make more power at lower PSI levels on pump gas. I generally make no more than 500DD HP on pump at 15-16 psi tops. The EGT's get to high otherwise.
+1 My comment was not meant towards an insult at all-both to you or your shop/tuner. I have cams, I guess your running stock cams, that def makes a difference. But look around to MRC/GTM/Forged they dont generally run more than 15/16psi on pump-its for a reason Regardless, your car makes good power and your happy with it. Thanks for the comparison...
Old Nov 1, 2007 | 06:28 AM
  #122
UnderPressure's Avatar
UnderPressure
Originally Posted by Alberto
Only one real way to find out! As you should have learned, even DD's can read differently-the difference between my DD from Forged and DJ was 7%, the difference between Julian's DD and local DJ was 13% so you never know until you compare.
Quick correction.
DD read within 1% repeatibility worldwide, it's kind of our standard. The DJ's are the ones w/ the variance in power readings. It's a pretty simple test, just run on a couple different DJs and see the numbers bounce around. Run on different DDs in shootout mode and all the numbers will be right on top of each other.
Old Nov 1, 2007 | 06:34 AM
  #123
USED's Avatar
USED
18 psi is a bit excessive on pump gas.It requires pulling alot of timing and increases EGT enourmously. I prefer the 15 psi range with some nice timing and A/F.I save the 17+ psi for higher octane gasses,especially on customers cars.
I totally agree with you. I typically tell customers to run at least a 50/50 mix of 100/93 octane for 18psi maps. Bulletproof is a well informed guy. His G has become a "shop car". We have very refined numbers in his UTEC. He's the type of customer that really listens to recommendations. There's no point for the 18psi map around town anyway...unless you like buying really expensive 19" bridgestones
Old Nov 1, 2007 | 06:43 AM
  #124
Bullitproof's Avatar
Bullitproof
I know you werent knocking my tuner, i was joking. I have scotts performance cams in the car. but with your compression ratio higher than mine, i expected you to make more power than me.
  #125
USED's Avatar
USED
Originally Posted by Bullitproof
...on my first 18psi pull, i looks like my clutch slipped. i did 2 runs a piece, 15 and 18psi. 539whp on 15psi(std correction, right?) and 573whp on 18psi. i was hoping to get a little closer to my original numbers but oh well. [B]it looks like the dynapack was higher by 2% and 4%, respectively.
DAMN TWIN CARBON! All other things being equal, I think you would have had even slightly higher numbers with a few more pulls. That clutch needs heat to get it holding properly.
Old Nov 1, 2007 | 06:56 AM
  #126
Bullitproof
Yeah man, i agree. i'll print out the numbers and bring them in later.
Old Nov 1, 2007 | 08:38 AM
  #127
Alberto's Avatar
Alberto
Cranky FI Owner
Not neccessarily true! Ive seen 8.5:1 cars at Forged make more power than me (at same boost-simialr set-ups) due to Sharif being able to run slightly more aggressive timing over my set-up. Every car is different, you cant speculate that a higher comp = more power.
underpressure-good info
Old Nov 1, 2007 | 09:58 AM
  #128
VitViper's Avatar
VitViper
You come up, I wont charge you.IF you bring donuts
I'll bring you donuts, you bring my car a TT kit. Sound like a deal?
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
