max power 440cc?
Old Jan 25, 2008 | 04:17 AM
  #41
jpc350z's Avatar
jpc350z
Originally Posted by Everybodywildou
before you were running the RFS you were still running the SSbox right? I will be running a utec.
Correct.. I now have a UTEC when I added the RFS..
Old Jan 25, 2008 | 09:49 AM
  #42
noer's Avatar
noer
I have APS TT with 440cc APS injectors. I hear that if you add another injector you can about 480hp or 500hp.. is this true?
Regards
Old Jan 25, 2008 | 10:01 AM
  #43
noer's Avatar
noer
Regards
Old Jan 25, 2008 | 10:27 AM
  #44
noer's Avatar
noer
Regards
Old Jan 28, 2008 | 09:36 AM
  #45
eez's Avatar
eez
Wow so its almost guaranteed that I'll run lean with the 9 lb pulley?
yeah, that was at 9.1 psi
check this thread for the dyno charts
https://my350z.com/forum/forced-induction/319940-yet-another-vortech-failure.html
Old Sep 28, 2008 | 07:12 AM
  #46
OldManZ350's Avatar
OldManZ350
Originally Posted by Mike@DW
In the past we (DeatschWerks) have rated our 350z injectors at 3.5 bar because that is the stock fuel pressure. But with our recent over haul of our VQ35 product line, switching from OEM cores to brand new Denso cores, we also switched back to 3bar like the rest of our applications. We used 3.5 bar because we thought it would make thing easier since that is the stock fuel pressure, but it really caused more confusion.
Our line up now consists of all Denso injectors rated at 3bar
440cc
600cc
850cc
custom sizes also available
Hope this helps
-Mike
Are you saying that all OEM core Deatschwerks 440cc were rated @ 3.5 bars
Old Sep 28, 2008 | 07:26 AM
  #47
OldManZ350's Avatar
OldManZ350
440cc
600cc
850cc
Hope this helps
-Mike
APS are also rated at 3 BAR. So whatever the flow rate says is the who you can expect.
So the sumation for flow rates @ stock fuel pressure and what power you can expect....
APS: As Advertised
RC: As Advertised
Deatschwerks Denso Core NEW*: As Advertised
Deatschwerks OEM cores: 550 (480-500whp), 440 (380-400whp), 650 (580-600) approx. at stock fuel pressure.
JET
Are you saying that, ALL OEM CORE DEATSCHWERKS 440CC WERE RATED @ 3.5 BARS MAKING THEM 400CC @ 3 BARS.
Old Sep 28, 2008 | 11:59 AM
  #48
athenG's Avatar
athenG
This explain why my deatschwerks 440cc is maxed out at 370whp. I'm about 95% IDC at 6500rpm.
Old Sep 28, 2008 | 06:59 PM
  #49
JonnyC's Avatar
JonnyC
athenG - you have the OEM Bosch cores? Those are the ones I just got...so I guess I'll be keeping this thing around 350 whp. You end up going with bigger injectors?
Old Sep 28, 2008 | 07:25 PM
  #50
athenG's Avatar
athenG
I just looked at the paper work that came with the injector. It has Bosch and tested at 51psi.... Looking at the correction at 3.40bar/50psi = 438cc and at 3.06bar/45psi = 415cc.
I'm in the process of retuning my car because winter is coming. At Temp below 60F I'm maxed out 98% IDC... I had to remove some timing up top and lean out my A/F, I also increased my Meth mix to 50% (I had 40% meth before) to give me some fuel. I'm almost done and I'm about 90%-94% IDC right now... In weather below 40F then I'll just cut down my boost 6-7psi. By the way this is A/F around 11.3-11.5 so it is still safe and there is still more room to cut fuel since I have meth....
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
samansharif
Sep 25, 2015 12:31 PM
